Auto lighting optimiser and highlight tone priority
Started Jan 2, 2013 | Questions
DigitalNick
DigitalNick Forum Member • Posts: 60
I shoot almost exclusively RAW and refine in LR - do I need to bother with setting either of the above or do they effect post-processing in camera only? 60D by the way...
-Nick-
Canon EOS 60D
fortwodriver
fortwodriver Regular Member • Posts: 167
Re: Auto lighting optimiser and highlight tone priority
I don't see the point if you're shooting RAW.  All of the sensor data is loaded into the file.  You can do essentially everything those functions do using the curves and shadow-highlight adjusters in your RAW processing software.
I even turn off Peripheral Correction.  I find these features that "correct" issues actually flatten the image a bit - it kinda removes the character of the lens you're using anyway.
-Nick-
Cheerio...
Frank...
DigitalNick
DigitalNick OP Forum Member • Posts: 60
OK, I guess my question was do either of these tools affect the RAW image capture at all (for example, does 'Highlight Tone Priority' just under-expose by say 1/3 stop and therefore affect the RAW capture)?
-Nick-
Karl Gnter Wnsch
Karl Gnter Wnsch Forum Pro • Posts: 11,408
It's worse than that. ALO does nothing to the RAW but influences the way the camera meters to a small degree. HTP on the other hand is a major change in the way the amplifiers on the sensor are operated (bright areas are less amplified by one full stop) - and it's one that LR can't properly handle.
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
DigitalNick
So I can't ignore them then, I really do need to turn both to 'Disable'?
-Nick-
bluestreakrem
bluestreakrem Regular Member • Posts: 144
regards
Karl Günter Wünsch
So if we're not post processing images or shooting RAW...........I guess we should enable both settings?
davinci953
davinci953 Regular Member • Posts: 215
Per Canon's Chuck Westfall, HTP does affect RAW data as well as in-camera JPGs; ALO does not affect RAW data.  He doesn't elaborate how the RAW data is affected.  If you're shooting RAW, ALO can be turned on or off in DPP.
Topaz
Topaz Contributing Member • Posts: 588
Karl, I have one question for you.   Are you sure LR can't handle RAW files encoded with the flag for HTP?
I've heard this statement many times, and I always took it as gospel.  But I have some spare time this morning, so I just tried loading an HTP RAW file into LR.  To be honest, this is purely academic for me, and it's the first time I enabled HTP since I bought my 7D three years ago and decided I had to play with every feature
But anyway, to me it looks like LR is handling it perfectly.  Am I missing something, or is it possible Adobe enhanced LR to handle HTP, without announcing it?
DigitalNick
Great, thanks, that was the answer I was looking for. Guess I'll turn both off for now then have a look under controlled conditions at some point in the future.
-Nick-
Karl Gnter Wnsch
Anything is possible and I wouldn't put it past them to do just that. My confidence level in this regard though is low as LR has numerous problems processing Canon RAW files - so much so that for example the free RawTherapee thoroughly trashes the current LR in quality...
regards
Karl Günter Wünsch
Topaz
Thanks Karl.  I would have expected that if LR was completely ignoring the HTP flag, the files would have imported looking 1 stop darker than non-HTP files.  But that's not happening, as far as I can tell.
On a side note, you have me very curious about RawTherapee now.  I'm going to have to have to go try it out!  (my poor google skills prevented me from finding much discussion comparing it to LR4 for any camera raw formats, let alone Canon).  I'm going to blame you for destroying all my spare time if I end up motivated to go re-process several years of RAW shots
KariP
KariP Veteran Member • Posts: 4,060
Still something about HTP....
Shooting RAW in special circumstances with HTP ON  gives better results. IMO
I am spending part of my time by the sea. On a sunny day the light is contrasty and my cameras (7D) dynamic range is not quite  wide enough - HTP seems to add some headroom to the highlights.
And since it affects RAW files (not just flagging them-doing something with the curves and sensor amplification - Canon does not tell exactly what)  my software Aperture  works normally with it.  I have not made any science about this but HTP seems to preserve some highlights better... without any side-effects.
Kari
SLR photography started in 1968, 40D since 2007, and now 7D !
60.21 N 24.86 E
 KariP's gear list:KariP's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS 7D Fujifilm X-E1 Fujifilm X-T1 +11 more
Karl Gnter Wnsch
Re: Still something about HTP....
That's what it's supposed to do and it makes sense to utilize this function if you are encountering the proper conditions to warrant it's use. If the conditions don't necessitate it's use then don't use it!
regards
Karl Günter Wünsch
