Edit S100 RAW under Windows 8?
Started Dec 30, 2012 | Discussions
Redlegvzv
Regular MemberPosts: 110
Dec 30, 2012
The software disk that came with my new S100 will not install under Windows 8.  Can anyone recommend a freeware or non-freeware program that will edit Canon RAW photos under Windows 8?  Thanks!
Olga Johnson
Forum ProPosts: 22,215Gear list
Re: Edit S100 RAW under Windows 8?
In reply to Redlegvzv, Dec 30, 2012
Have you tried the updated Canon software?
http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_s100#DriversAndSoftware
I don't have Win 8 so I cannot confirm that it works, but I think it's worth a try.
Olga
 Olga Johnson's gear list:Olga Johnson's gear list
Canon PowerShot G3 X Canon EOS Rebel T4i Canon EOS M Canon EOS Rebel SL1 Canon EF 15mm f/2.8 Fisheye +17 more
wa2n
Regular MemberPosts: 171Gear list
I ran into the same problem on Win8 with my S100. Download software from the canon website and save it to disk (don't install yet):
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_s_series/powershot_s100#DriversAndSoftware
Now modify your windows8 registry so the software will install using the Windows 7 instructions at the link below:
http://www.canon5dtips.com/photo-and-camera-software/how-to-install-eos-utility-if-you-lost-the-disk/
Next install each software application.  One that's missing handles the GPS tags, I had to install it from the disk on an xp computer and then copy the files over to the Win8 computer and create a desktop shortcut to the .exe file.  It worked fine on Win8.
Wayne
Redlegvzv
In reply to Olga Johnson, Dec 30, 2012
Thank you for the link.  Unfortunately no Windows 8 utility yet although there is a Win 8 Camera Window program.  I'll periodically check this link; perhaps Canon will eventually have a Win 8 program.
Redlegvzv
In reply to wa2n, Dec 30, 2012
wa2n wrote:
I ran into the same problem on Win8 with my S100. ....
Thanks for the info, Wayne!
Redlegvzv
OK, this seems to have worked:
1.  Go to the Canon site that Olga showed me and download the updater.  There is a Windows 8 option.
2.  The updater prompts you to insert the CD Rom disk.  (This disk would not install on Windows 8).
3.  The updater then insalls and updates "Digital Photo Professional" and it seems to work.
Hope this helps someone.
