Canon G16 and RAW
Started Dec 29, 2012 | Discussions
njga83
Forum MemberPosts: 54Gear list
Canon G16 and RAW
Dec 29, 2012
It's my understanding that the Canon G15 does multiaspect-RAW, but when I look at the folder all I see is jpg. Am I misunderstanding what multaspect RAW is?
 njga83's gear list:njga83's gear list
Canon PowerShot G15 Canon EOS 1000D Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 IS +3 more
Canon PowerShot G15
Dale Buhanan
Veteran MemberPosts: 3,975Gear list
Re: Canon G16 and RAW
In reply to njga83, Dec 29, 2012
The aspect ratio on the G15 is a seperate setting from RAW and jpb. On the func menu you can select 16:9, 3:2, 4:3, 1:1 and 4:5. The next line down lets you select RAW or jpg or RAW+jpg. The next line down lets you select Superfine, or fine, L, M1, M2, or S size. So you need to select which combination appeals to you. Make sense?
I have not tried any of the other aspect ratios in camera.  I shoot the full 4:3 and then crop as desired in post processing.  But I am shooting L size and superfine setting.  I'm quite pleased with the results.  Seems like a pretty versatile camera.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 7D Canon EOS 70D +34 more
njga83
njga83 OP
In reply to Dale Buhanan, Dec 29, 2012
Thanks.
MisterPootieCat
Veteran MemberPosts: 3,085Gear list
Canon G15, RAW, and Multi-Aspect Ratio
kind regards
Dale
Shooting full resolution using JPEG would be a good idea but the multi-aspect settings behave differently when shooting in RAW mode. The camera still captures the 4:3 ratio image and simply adds a crop window visible in DPP. So you get the on-the-fly cropping without the downside of reduced resolution, and any aspect ratio selected in the camera can be backed out in DPP afterwards. This G15 is an interesting little animal.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon PowerShot S2 IS Canon PowerShot S5 IS Canon PowerShot G10 Minolta DiMAGE Z1 Konica Minolta DiMAGE Z2 +19 more
Dale Buhanan
Re: Canon G15, RAW, and Multi-Aspect Ratio
In reply to MisterPootieCat, Dec 29, 2012
MisterPootieCat wrote:
kind regards
Dale
Thanks for the further info, Pootie.  That's really about the only way you could do it.  The RAW file is not yet an image,  It hasn't been through the demosaic process yet, and is simply an array of voltages dumped from the sensor photo-diodes.  Until it goes through a conversion process there is no image to crop, so about all you can do is say  "cut here".  :))  I'll have to give it a try and see the window in DPP.  That would be fun.
kind regards
Dale
jrscls
Veteran MemberPosts: 5,911Gear list
In reply to MisterPootieCat, Dec 30, 2012
Does the same when processing RAW images in Lightroom, with the image already cropped at the selected aspect ratio. I kind of like it as I can change the crop later if necessary.
 jrscls's gear list:jrscls's gear list
Sony Cyber-shot DSC-RX100 IV Canon EOS 6D Canon EF 135mm f/2.0L USM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 35mm f/2 IS USM +1 more
MisterPootieCat
In reply to jrscls, Dec 30, 2012
Good to know, I was thinking it might just be a DPP thing.
David Hurt
Senior MemberPosts: 1,374Gear list
Will the G15 shoot RAW+ Jpeg??
 David Hurt's gear list:David Hurt's gear list
Canon PowerShot G7 Canon PowerShot G15 Canon EOS 30D Canon EOS 50D Canon EOS 300D +9 more
MisterPootieCat
In reply to David Hurt, Dec 30, 2012
Yes, it will.
