Integrate a UV filter into your DA 21mm 3.2 LTD
Started Dec 29, 2012 | Discussions
DAVID MANZE
DAVID MANZE Veteran Member • Posts: 3,384
Prototype until I find a coated UV filter
Super happy with my replaced DA21mm 3.2 Ltd lens from Pentax (they tried to repair it and their lens testing jig refused to work so they kindly sent me an almost new copy FOC and it's spot on) It's a lovely lens, but one of it's shortfalls is that you cannot use a UV filter and a lens-hood at the same time.  So I decided to try to fit a filter in the lens-hood itself, I found an old 46mm skylight filter and measured the glass diameter,42.7mm, but the lens-hood needed a 42mm glass to fit neatly inside,out came the flat diamond file and lubricated with water I took off the offending 0.7mm and it slipped into the lens-hood nicely,four spots of superglue and it was good to go.
It's only a temporary job until I can find a decent coated UV filter, preferably a (45mm filter to save the hassle of diamond files and the risk of scratched coatings. I put a few drops of water on the filter so it's visible.
Dave's clichés
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Pentax K-01 Nikon D7100 Pentax K-3 Nikon D750 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +19 more
citrontokyo
citrontokyo Contributing Member • Posts: 812
Re: Integrate a UV filter into your DA 21mm 3.2 LTD
I find the 21, much like the DA 40mm with hood attached, is perfectly safe from bumps and scrapes, so I don't use anything with it. Just my opinion, but I don't want anything else, except maybe a polarizer or ND filter in front of that lens.
Still, that's a pretty neat trick you did.
 citrontokyo's gear list:citrontokyo's gear list
Pentax K-5 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc FA 43mm F1.9 Limited +4 more
phil_t
phil_t Forum Member • Posts: 72
Not to ruin anyone's fun...
But I have found that the B+W 43mm UV Haze SC 010 Filter (F-Pro Series), Mfr# 65-070074, fits the internal threads on the inside of the lens shade, while being thin enough to allow the shade's bayonet mount to engage.
No fitting or gluing required.
 phil_t's gear list:phil_t's gear list
Pentax 18-50mm F4.5-5.6
DAVID MANZE
DAVID MANZE OP Veteran Member • Posts: 3,384
Re: Not to ruin anyone's fun...
Hi Phil t,
OK, yes indeed there is an internal thread inside the lens-hood and the lens-hood is marked MH-RBA 43mm, so your call is a good one,does it not however, cause a bit of vignetting?there is not a lot of room for the frame.
Dave's clichés
phil_t
No, the filter ring is entirely outside of the rectangular shade opening, as well as being between the front element and the shade.
Tyler Monson
Tyler Monson Senior Member • Posts: 1,451
Another Approach
My DA21 lens has been my daily companion since 2007—first on a K10, then K20, now K-5. Either around-my-neck, over-my-shoulder, or loose in the bag, I don't use any filter, but either the stock lens shade or, in foul weather, a 49-to-58mm step-up ring with an old Pentax 'normal' lens shade.
That shade (with step-up ring) is one-inch deep and I have no problem with vignetting.
Among the joys of the DA21 lens is the small diameter of the front element and its rather deep mounting. Both obviate the need for any protective (UV) filter, in my book (and, in the way-back, all of my Hasselblad lenses had OEM UV filters mounted).
Tyler
More Original Refrigerator Art
DAVID MANZE
Re: Just shows how many ways there are to skin a cat.
Hi,
Well ,we all have our own ideas and here it shows that we all achieve the same result differently!
Dave's clichés
volosong
volosong Veteran Member • Posts: 4,311
I've been using a Hoya Digital 43mm UV filter mounted on the internal threads since I first purchased my copy.  No vignetting, no adverse effects.
Steven
GMT -8
KentG
KentG Veteran Member • Posts: 4,269
I assume you do know that a DSLR sensor does not need a UV filter like a film camera does? And you are using it as "protection" instead, I guess.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-S1 Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +1 more
DAVID MANZE
Kent Gittings
Correct!  It's for protection when I've the camera on my back while cycling!
Dave's clichés
