Sony A99 (and RX1) raw file issue? An investigative report...
Started Dec 27, 2012 | Discussions
tesilab
Senior MemberPosts: 2,511Gear list
Dec 27, 2012
What I found in the RX1 file (A99 is similar, but the particular file was a bit worse):
 tesilab's gear list:tesilab's gear list
Sony RX1R II Sony Alpha NEX-5 Olympus Air Panasonic Lumix DMC-GX8 Panasonic Leica D Summilux Asph 25mm F1.4 +13 more
Nikon D3 Nikon D600 Sony RX1 Sony SLT-A99
topstuff
Senior MemberPosts: 1,208Gear list
Hyperbole is the best thing in the Universe ever !!
In reply to tesilab, Dec 27, 2012
While I can't pretend to offer an explanation ( although no doubt this will not stop plenty of people commenting on your post who pretend to know something but in reality know nothing ! ) , but I think that if there IS a problem, then the digital photo testing community would have spotted it by now.
Take DPR for example, if the A99 was NOT producing 14 bit files I am quite certain they would have told us.
So before you post potentially hysterical hyperbole ( "scandal", really??) I think it would be sensible to check, check again, and check that again. And then check it again.
Like I said, DPR have been examining A99 for a long time and have minutely examined that camera's files. And they have found nothing to corroborate your thesis.
The logical assumption to make is therefore that you got it wrong.
Still, I am sure the "Scandal" !!! headline will make this a nice long thread, full of the usual suspects.
Have fun. Knock yourself out.
tesilab
tesilab OP
Hyperbolic title, but sincere and double checked content.
In reply to topstuff, Dec 27, 2012
Well, it is a little fun to get some attention on the thread, but truthfully only interested in attracting the attention of someone who really can explain this. I have a long digital imaging background, BTW, though I will own up to misunderstanding data. But Rawdigger histograms of raw files dumped into CSV files are pretty straightforward, unless they are only decoding low bits of information and the rest of the bits are hiding somewhere else where they cannot decode them. But I haven't seen anything to that effect.
I invite you to try it for yourself, and see if you have a different interpretation. There is a stark difference in the histogram data. I never claimed it would produce a noticeable visual difference in most situations. However one who wants the most tonal data to work with must explain this discreprency to his satisfaction.
I will be delighted to be corrected, since I like my camera otherwise, and just want to become master of its tone curves.
steelhead3
Veteran MemberPosts: 6,126Gear list
Re: Hyperbolic title, but sincere and double checked content.
Don't know about rx1, but the 99 only shoots 14 bit in single shot mode; all other modes are 12 bit.
 steelhead3's gear list:steelhead3's gear list
Sony a77 II
VirtualMirage
Veteran MemberPosts: 3,659Gear list
Re: Sony A99 (and RX1) raw file scandal? An investigative report...
I think the best person to ask is Iliah Borg.  He normally resides around the Nikon FX forums but if I recall correctly he knows quite a bit about RAW files and played a part (or sole credit, not sure) in the open source LibRaw.  He seems quite knowledgeable in topics such as this and might be the best person to inquire with.
Paul
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
topstuff
In reply to steelhead3, Dec 27, 2012
Could this explain it?  Presumably 14 bit is restricted in an effort to increase fps?
tesilab
tesilab OP
No, use only single frame mode files.
I only checked single shot drive mode files. Not interested in high FPS. Especially given I've been doing some exposures at 30 secs. (Though my definitive tests were with daytime ISO 100 shots to be safe).
I've put in an inquiry with the author of RawDigger to see what he has to say on the subject.
Waardij
Forum MemberPosts: 66
It has to do with the Sony compression. The idea is there is much more resolution in the highlights than ever needed. As an example, half of all the possible values in 14 bits, are present in the highest bit (so from 011111111111111 to 10000000000000). there is no way that the human eye can distinguish such small step, not even after severe post processing. and also the noise in that last bit will be much more than smallest values. In the above 14 bit example, there are 2^13=8192 values in the range from 13 bis on to 14 bits on. The smallest step for the shadow is only 1 value. Sony equalizes this extreme unbalance  bit, saving on the amount of data that has to be stored. I do not know of an example where its is shown that there is any disadvantage in this method. in the a900 one could choose to compress or not, an I have never found an advantage in not using the compression.
tesilab
tesilab OP
For single shot HDR, or strong exposure shifting it is distinguishable
In reply to Waardij, Dec 27, 2012
If one wants to accentuate local details (as in HDR) or do extreme highlight shifting into the middle tones, these values would of course make a difference. Aside from longer exposures where noise increases over time, I'm not sure it is near correct to say that this highlight information is noiser than shadows. If anything, it should be the opposite.
Also please try to explain how the  actual storage requirements of a D600 are only very slightly greater than the A99/RX1 at the same resolution. Did Sony just "forget" to compress this optimized data?
Eric Perez
Regular MemberPosts: 110
Wow, just read the entire thread. I am glad I didn't go the sony FF route. I do a lot of underexposing and HDR, post work that needs DR. My K5 can shoot 7FPS @14 bits without a LPF, not bad for $1300. I find it odd that sony does not disclose any of this info, scandal indeed...
Ralf B
Veteran MemberPosts: 7,556Gear list
In reply to Eric Perez, Dec 27, 2012
According to DXO, DPR and Photoclubalpha, no shortage of DR in the a99 at low ISO. Your reply misses the factual point attempted to be discussed here.
You have a PM, Eric.
Ralf
www.ralfralph.smugmug.com
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +13 more
Eric Perez
In reply to Ralf B, Dec 27, 2012
Ralf
Ahh ok, well I guess I missed out there. And yes thank you for the message.
Ralf B
Sony A99 (and RX1) raw file issue? An interesting read ...
In reply to tesilab, Dec 28, 2012
http://www.photoclubalpha.com/2012/12/27/sonys-alpha-99-mastery-wrapped-in-dilemma/
Quote:
The 14-bit raw file has great flexibility for shadow and highlight adjustment from raw without losing colour values or subtle tones. I’d rate it as one of the best raw file formats I have worked with, at normal (100-800) ISO settings.
end quote.
The above linked review is from a team of Nikon/Canon/Sony shooters with ongoing use of the a99, D600 and 6D. Too bad but it seems they won't add the RX-1 to their line-up to see hoe that would be judged by photoclubalpha.
Ralf
tesilab
tesilab OP
Don't jump the gun... I'm just asking about the data
In reply to Eric Perez, Dec 28, 2012
There is an explanation for everything. I tried to state that in the end, it may make no practical difference for most purposes. The layperson's expectation of what the data should look like, doesn't mean his expectation is correct--even if that layperson is a software engineer with an imaging background.
I'm waiting for some more authoritative answer on this. I naively expect 14 bits to mean that, depending on the image and exposure, it is possible to get get samples that exercise a fair portion of the 14 bit data range. This expectation seems to be supported by other raw files from other manufacturers.
tesilab
tesilab OP
Still there is something that needs to be understood about the data
In reply to Ralf B, Dec 28, 2012
I actually wrote this in response to one user drew a hasty conclusion, but this response makes sense here too, so sorry to repeat, but I quote myself:
Of course, if it were not possible to deliver very high quality images that work well in practice, Sony wouldn't do what they do with the data. But it is fair to wonder if this leads to consequences with certain edge cases in processing. Single file HDR is one, other types of tone curve manipulation is another. I was experiencing some banding when manipulating a raw file--which could be for a host of unrelated reasons, but that is what prompted me to start digging into the files.
mick232
Contributing MemberPosts: 791Gear list
Re: Don't jump the gun... I'm just asking about the data
That is not a naive expectation. Generally, if I buy an audio CD, I also expect to get true samples and not some MP3 re-converted to 16-bit 44.1kHz PCM and burned onto a disc. It will take some very aggressive tests shooting all kinds of gradients to find out if the lossy RAW compression has any practical effect (posterization) or not. Only if it does, I would call it a (mini) scandal and demanding a firmware update would be in order.
 mick232's gear list:mick232's gear list
Sony Alpha NEX-5 Sony SLT-A99 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sony 75-300mm F4.5-5.6 Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +19 more
tesilab
tesilab OP
Hyperbole dealt with, plus a small anecdote...
In reply to topstuff, Dec 28, 2012
And anyone else who comes late to the thread wonders, the thread title has been helpfully corrected to something more appropriate.
Just one anecdote for you:
I used to be responsible for a digital imaging technology that attracted FujiFilm's attention in the 90's. They sent their engineers, who were interested in licensing the technology. They sent very sharp people, who started to shake their heads a bit as they realized during my exposition, that certain, ahh, liberties were taken in our image impressive image compositing system that was known for exceptional speed. (The company was called Live Picture, for those who recall--we inspired Photoshop to add layers to their application!) Anyway, I saw that we were losing a sale, so I had to explain our shortcuts in an acceptable way to them, so I said:
"Look, you can go with Microsoft, and they will give you a classic computer science based approach to imaging. But we, at Live Picture, have a imaging approach to computer science!"
This little turn of phrase seemed to make all the difference. They went from shaking to nodding. We had a major sale! I ended up building a postcard creating application for them that was bundled into image cd's that Fuji used to create for their film processing customers in Japan.
Michaels7
Contributing MemberPosts: 504Gear list
Re: Sony A99 (and RX1) raw file issue? An investigative report...
From Photoalpha.com
"It took me a few days and some digging to find out that the 14-bit readout on the A99 only applies one shooting mode – single shot. Any other mode you select, including Lo 2.5fps continuous and all multishot or JPEG only modes, uses 12-bit readout from the sensor. This was already documented in the literature about the A99, but what Sony omit to say is that the 14-bit mode causes a noticeable pause between the shot being captured and the restoration of EVF viewing. This pause is around 1/10th of a second longer in single shot mode than the blackout which happens during 2.5fps or the first frame of any faster sequence, and totals 200ms or 1/5th of a second."
 Michaels7's gear list:Michaels7's gear list
Sony SLT-A99 Sigma 85mm F1.4 EX DG HSM
tesilab
tesilab OP
But I use single shot mode
In reply to Michaels7, Dec 28, 2012
None of the files I checked should have been of the burst mode variety.  I don't have my own A99, just an RX1. I took the A99 samples off of imaging-resource.com.
My findings should be easily reproducible by anyone. I checked only base iso single captures at zero EV compensation (and purposely overexposed files), loaded them into Raw Digdownload savehosting full histograms as CSV files, and examined the resulting data, every blessed row.
Iliah Borg
Forum ProPosts: 19,031
Re: Hyperbole dealt with, plus a small anecdote...
In reply to tesilab, Dec 29, 2012
"imaging approach to computer science!"
goldene verter
