FZ200 in dim light.
Started Dec 21, 2012 | Discussions
kryzt Regular Member • Posts: 236
FZ200 in dim light.
I wanted to show you what can do a very small sensor like we have with the FZ200 in dim light, a day with no sun and very cloudly.
All the 3 images are come from JPEG and all 3 are 50% croped from original and of course there are pp.
Sparrowhawk distance: 17 meters.
Squirrel distance: 10 meters
Blackbird distance: 15 meters
 kryzt's gear list:kryzt's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-FZ1000
Tootsall
Tootsall Senior Member • Posts: 1,284
Re: FZ200 in dim light.
That is nice.  I'd have to jack up the ISO and then do some noise reduction with the FZ150 under those conditions.
"Kites rise highest against the wind - not with it." - Winston Churchill
 Tootsall's gear list:Tootsall's gear list
Panasonic Lumix DMC-FZ150 Canon PowerShot D10 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +5 more
tbaker Regular Member • Posts: 434
Excellent shots, really shows off why the FZ200 is the best camera Panasonic ever made, fact!
Arjun G Regular Member • Posts: 443
Looks really good on my screen. The soft light is quite nice.
Did you use a tripod and was it at maximum zoom?
Arjun.
Check out some of my bird photos with the FZ 200 and FZ 38 on
http://picasaweb.google.com/100483235973839984776/Birds
Some of them were shot in dim light too.
kryzt OP Regular Member • Posts: 236
Arjun.
Thanks for comments,
I didn't use tripod only hand hold and it was all at 600mm.
The major difficulty was the very poor light and to get i clear focus because of the distance and all the branchs so i didn't expected to get a clean shot because of the tiny sensor.
Maybe the key is to hold the camera so stable that you help your shoot a lot.
FZ150GUY
FZ150GUY Forum Member • Posts: 99
Arjun.
Thats amazing for a full 600mm shot, you must have steady grip
 FZ150GUY's gear list:FZ150GUY's gear list
Panasonic Lumix DMC-FZ150 Kodak Pixpro S-1 Adobe Photoshop CS6 Samsung Galaxy S III Apple iPad 2 WiFi +1 more
Ronomy
Ronomy Senior Member • Posts: 3,741
What helps me sometime is use the 2 second shutter delay timer so that when you press the shutter button you stop moving before the shutter is opened.  Helps you get the best hand held shots at long zoom.
 Ronomy's gear list:Ronomy's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Canon PowerShot SD800 IS Canon EOS 7D Sigma 18-35mm F1.8 DC HSM Art +6 more
manthasfamily Veteran Member • Posts: 6,402
Very nice shot.  I also like the soft feeling of the shots.
Karen
If it pleases you then to hell what everyone else thinks!
NS 1 New Member • Posts: 3
Was there a reason to use f/3.2 in the first shot, and 2.8 in the others? Great photos!
Jerry045
Jerry045 Senior Member • Posts: 6,469
Those were great shots. Very nice and sharp for hand held. My taste would have lightened them slightly. I am amazed you got the focus so well with all the branches in front of the birds. Good job!!
Jerry
 Jerry045's gear list:Jerry045's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-ZS20 Sony a6000 +7 more
Thanks for your comment , i don't remember why i put it to f3.2 but i don't think it will change anything to be f2.8 or f4.0 with the long distance from the subject.
Jerry
Thanks Jerry for your comment. Yes you right i miss some light during this day i took them and i use the tiny spot focus on subject or if not good enough i try manuel focus too. The key if take your time and shot more than one picture each time to be sure to have good one.
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 16,747
Jerry
About 1/2 of the commentors here seem to forget that this and other Panasonic cameras haveVERY GOOD Optical Image Stabilization, and as such a steady hand & 'good grip' aren't all that important at 1/125th second.
I think you have put your finger on it, Jerry, the focusing is brilliant.
And - I, too think lighter would be better:
What I AM wondering about are the strange "ISO 160" & "ISO 125" which I'll bet were chosen by the camera - what's up with this? I am finding the same thing on my ZS19 and at first I thought it had to do with +/- EV settings, but that doesn't seem to be the case.
-Erik
'He who hesitates is not only lost - he's miles from the next Exit.'
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
sherman_levine
sherman_levine Forum Pro • Posts: 10,038
Erik Ohlson wrote:
Jerry
-Erik
Do you have i.Dynamic active?
Sherm
 sherman_levine's gear list:sherman_levine's gear list
Panasonic Lumix DMC-FZ1000 Nikon Coolpix P900
Erik Ohlson
Sherm
Huh? Is this question for me or the OP?
I, myself, have never heard of "iDynamic" and Google finds it to be something on the G@, but does have a suggestion about using it in similar circumstances.
As far as what I posted - levels & a bit of unsharp mask.
-Erik
sherman_levine
Sherm
-Erik
Erik,
I think i.Dynamic is called i.Exposure on your camera.
It changes contrast on a per-image basis, and as part of that can nudge the ISO above the selected value.
Sherm
Marek Podmaka New Member • Posts: 14
For FZ200 that is possible with setting "ISO Increments" in the Rec menu to 1/3 EV. It will then choose from [100]/[125]/[160]/[200]/[250]/[320]/[400]/[500]/[640]/[800]/[1000]/[1250]/[1600]/
[2000]/[2500]/[3200]/[H4000]/[H5000]/[H6400]. And also you can then manually choose from these options when setting ISO manually by the "up arrow" button.
I think default setting was 1 EV, which brings only [100]/[200]/[400]/[800]/[1600]/[3200]/[H6400].
 Marek Podmaka's gear list:Marek Podmaka's gear list
vikingo
vikingo Regular Member • Posts: 150
I've seen beautiful pictures in that link ... with very little light, wow, the 200 behaves Fz wonders ..
www.flickr.com/photos/mirjamvanklaarbergen/8371984991/in/photostream
LUMIX FZ 50 , ahora FZ 200, conociendola....
