A new Canon 50mm f/1.2 L?
Started Dec 20, 2012 | Discussions
Moogles Regular Member • Posts: 159
I own a 5D2, a 16-35mm f/2.8 L II and a 70-200mm f/2.8 L IS II. My wife has the NEX 6 with its kit lens, 16-50mm f/3.5 - f/5.6.
Initially, I had plan to ditch all my DSLR gear for mirrorless but photos from the NEX 6 was below satisfactory. The results from NEX 6 is OK, nothing fantastic. So, I hold off the thought and decided to keep my DSLR gear.
I am not a fan of rumors but when Canonrumors.com posted something about the new 24-70mm f/2.8 L II, Canon really made one. Now, the new rumors is that Canon will be creating a new 50mm f/1.2 L. Source: http://www.canonrumors.com/2012/12/patent-a-new-canon-ef-50-f1-2-suggestion-of-a-full-frame-mirrorless/
I am wondering if now's a good time to get the current 50mm f/1.2 L famous for back-focusing and some said it's not, or should I wait. I am not in a hurry but I'm thinking of selling my Canon 16-35mm f/2.8 L II to fund for a 50mm f/1.2 L. What's your advice?
Canon EOS 5D Mark II
JohnMatrix Regular Member • Posts: 337
Re: A new Canon 50mm f/1.2 L?
If all you want to do is collect new lenses then yes, I would wait for the 50/1.2L II, due to be released sometime between 2013 and 2020, for approximately 50% more than the current cost of the 50/1.2L.
If you want a 50mm lens to take photos with now, then get the 50/1.2.  Nothing much wrong with it if shooting at wide apertures is your thing.
BTW, replacing an ultra-wde angle zoom lens with a 50mm prime seems like an odd thing to do.  I presume the 16-35 doesn't get much use?  Will you miss having a wide-angle?
PS.  the 50/1.2 doesn't suffer from "back-focusing", it's "focus shift"
Moogles OP Regular Member • Posts: 159
Well, I'd like to think like you but my brain doesn't allow me to, which is why I started a topic like this to get advice from more experienced photographers on what to do.
Yes, I don't use the 16-35 very much, I could have lived with a 17-40 f/4. I dont think I shoot anything more than 24mm on my 5D2. I have the NEX 6 to compensate most of the group photos which don't happen very often either. I am thinking of the 50mm as my walk around lens.
Marco Nero
Marco Nero Veteran Member • Posts: 4,391
Canonrumors.com are chock-full of garbage.  That site is awash with false stories published by trolls looking to get a rise out of the camera communities.  Anyone can write in and make claims of a new lens or camera whenever they want to and the vast majority of these claims are FALSE.  The rumor about a new 50mm replacement is based on patents lodged by Canon earlier in the year from a camera that I believe is likely to be from the EOS-M series.  It's FAR more likely when looking at the patent application that it's a lens that might be released alongside the pro-version of the EOS-M than a DSLR.  The description on the patent even implies this.  Take a look at the 135mm L lens... it's an older lens and there's been rumors of a replacement... but think about that for a moment because the rumors of a replacement for this lens have been circulating for 7 years now.  SEVEN YEARS!  Sure, there might be something next year.  Or the year after the next.  But there might not be either.
The 50mm f/1.2L is a specialized lens.  MOST people claiming the camera had back-focus were actually shifting their lens forward as they squeezed off a shot.  It's especially common for people who recompose their shots to complain of back-focusing when this is NOT the case.  Canon claims that the concerns with that of backfocussing are minor and only occur at the minimum focusing distance which is 4 feet from the sensor itself and only at specific apertures.  They also claim that this is a feature of this particular lens. Most people won't notice it and it's NOT there when Manual Focus is used.  In a nutshell, it's not a problem.  You could likewise argue that the 35mm f/1.4L lens is likewise inferior to others in the same ballpark but to do so would be to dismiss the ocean of spectacular images it produces.  I own the 50mm f/1.2L lens and it is a very decent lens with a practical field of view for portraits or related imagery.  Canon know how sought after the 50mm lens is but that the price makes it prohibitive.  So any new release would mean that the cost is certainly going to go up by at least a third to 50% more and that will kill off a lot of interest.  What more can they do?  Well, the only thing people seem to expect on a new lens is Image Stabilization but that doesn't make sense on a lens so fast.  Especially when you consider that newer DSLRs are capable of such noise-free images these days when coupled with higher ISOs.
I own the EF 16-35mm f/2.8L II as well but I tend not to use that lens as often as I would like to.  I do find the bokeh on the 50mmL to be extreme and this amount of bokeh simply possible on the 16-35mmL.  It depends what you want to shoot.  I use the 16-35mmL for landscapes and architecture because it's a wide lens.  The 50mmL is a specialized lens although you could use it as your only lens if you wanted.  The shallow DOF inherent with this lens makes it ideal for separating the subjects from the background.  It's got a tight view if you're not using it on a full frame camera.  But it's about the fastest lens I have ever used.
The 50mmL is a unique lens with some of the strongest bokeh you'll get in a portrait lens without an unusable focal length in a prime like 135mmL or the 85mmL.  Those too have extreme bokeh but they tend to have too much zoom to be as flexible as the 50mmL.  My wife uses the 50mmL as her on-the-camera-all-the-time lens.  I use mine on an EOS-M that I've been playing with although it's normally on one of my DSLRs.
Marco Nero.
www.pbase.com/nero_design
 Marco Nero's gear list:Marco Nero's gear list
Canon PowerShot G1 X Canon PowerShot S95 Canon EOS M Canon EOS 60D Canon EOS 5D Mark III +9 more
robbert100 Contributing Member • Posts: 508
Hi Marco,
You are spot on!!
The EF 50-1.2L is a great lens provided if one knows how to use it to make the most of it's characteristics.
(still considering to buy one to fill the gap between my EF 24-1.4mkII and EF 135-2.0L the latter more and more replaced by my EF 100-2.8L IS)
Best regards,
Rob
geckophoto.zenfolio.com
 robbert100's gear list:robbert100's gear list
Canon EOS M Canon EF 8-15mm f/4L Fisheye USM Canon EF 100mm f/2.8L Macro IS USM
TheoC Contributing Member • Posts: 770
Liveview on the 5d2 is very good and the lens is a joy to use. I also use it with adapter on the Nex (Nex 5n) and it is fantastically good wide open. I do not even use the focus peaking feature of the Nex, when focus is acheved the evf starts flickering ever so slightly and it helps. I tried peaking with different colours and it was not for me. There is no point in stopping down a lens like this, the 50/1.4 EF would be the better choice. I quite like the fact that the Eos to Nex adapter has no aperture iris and I use the lenses only wide open. I hope you find a reasonably priced 50/1.2L. failing that, there are quite a few old 55 or 50 1.2 fd lenses that can be adapted to the Nex with a simple adapter. With aperture, to boot.
Theo
tim73
tim73 Regular Member • Posts: 446
That's a rather odd set of lenses.  Two fairly specialised zooms, and nothing at all in the "standard" focal lengths.
And the 50mm f1.2 is another specialised lens. The sort of lens you'd buy only if you knew what you wanted it for.
My advice is, that if you need to ask, then this lens is not for you. Look at your favourite pictures, and see what focal length you used. Then decide if the picture is lacking anything technically, and let that guide your purchasing.
lighthunter80
lighthunter80 Regular Member • Posts: 394
I got the 16-35L II and the 50L myself on a 5Dmk2. I'd never sell the wide zoom. It is too versatile and even for me as a mainly 'people shooter' a good mix in the portfolio if not all images are taken at 50/85/135.
The 50L is a great lens. I read so much about it. Negative and positive but after all I am always impressed when I see the results at f1.2. It's jus so different from any other 50mm lens. I owned the Canon 50 1.8 II and 1.4 and Sigma 50 1.4 but none gave me this wow experience. The Sigma was relatively close with a nice bokeh but not as sharp wide open.
I can definitely recommend the 50L if you need/want this focal length and if you shoot it wide open.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS 5D Mark II Olympus PEN E-P5 Canon EOS 6D Sigma 85mm F1.4 EX DG HSM Sigma 35mm F1.4 DG HSM Art +3 more
Thomas Kachadurian
Thomas Kachadurian Veteran Member • Posts: 3,150
It's a lens I wanted to love and have bought and sold twice for severe focus problems. I am currently using a Sigma 50mm f1.4 that I checked and outperformed my 50F1.2L at everything but shooting at f1.2.
Sometimes the red ring is just trim.
Tom
www.kachadurian.com
Call me crazy. I happen to like photos of cats.
lighthunter80
Tom
www.kachadurian.com
Interesting... I bought my 50L in 2011 and I had the Sigma 50 and the Canon 50 1.4 at home at the same time. It was a good opportunity to test them against each other and the Sigma was noticeably the softest at 1.4
Funny thing is that the Canon 1.4 was a tad sharper than the L but with less contrast and not so nice bokeh. I gave back the Sigma and sold the Canon 1.4 and am happy with the L ever since.
Rick Knepper Forum Pro • Posts: 13,222
Not a rumor, it's a patent
There have been many patents filed which never come to fruititon.
Rick Knepper, photographer, non-professional, shooting for pleasure, check my profile for gear list and philosophy.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R +2 more
You've got this mostly wrong but then you are not the first.
The following is not a technical discussion but rather it is more of a historical perspective of this form.
The 50L does not have the same corrective measures for spherical aberration that other Ls employ from the 100L to the 24L. Within ten feet AND stopped down up to f4-f5.6ish, the lens will shift focus, one of the symptoms of spherical aberration. Beyond f5.6, DoF will cover any shifts. At super wide apertures other than wide open, even a shift in focus onto a tiny closer or further surface of say the face will create the resemblence of a back focus. Not back focus as we common think of it, but a shift of focus. Shooting wide open should not produce the focus shift phenonmenom.
By the way, all lenses have spherical aberrations because their elements are rounded.
Having said this, there was a batch of 50Ls that indeed back focused wide open (as we commonly think of back focus) and if we had had MA back in the day, this probably would not have been a matter of concern. The hysteria of this issue was exaserbated by the focus shift issue and eventually melded into one issue by folks truly ignorant of lens design (and with reading comprehension problems because the following link was posted dozens of times by myself and others).
Common hardware corrections for focusing at close distances are aspherical lenses and floating elements. Every L lens from 24mm to 100mm has a floating element (including the original 50L) except for the current 50L. In fact, it is rare for 50mm lenses from any manufacturer to have floating elements.
Common non-hardware corrections for lenses without floating elements and the need to focus on subject matter that is closer than eight to ten feet are 1.) don't use it like this, 2.) learn how your lens shifts and correct for the shift before the shot or 3.) stop down past the DoF needed to bring the area into focus including the surrounding humps and bumps.
So what do you think the conclusion should be for someone considering the purchase of this lens and knowing that it does not have a strong correction for focus shift when close focusing? If you want to buy this lens to take a head shot of your newborn from 3 feet away, what would be your conclusion about the 50L. Not the right tool maybe? Better choice: the 85L maybe and step back, or the 35L and crop.
Here's the technical description of spherical aberration and focus shift that helped end my ignorance of this particular lens design and allowed me to see that my 50L wasn't defective, I was just using it incorrectly or not as the manufacturer intended.
http://toothwalker.org/optics/spherical.html
Do I wish Canon had included a floating element in this lens (which we take for granted in the other Ls from 24mm to 100mm)? Yes, I do but that's the design choice Canon made which has produced the seemingly endless controversy fueled by ignorance of course.This forum can't even discuss solutions because there aren't enough folks that understand the issue and that being, would a floating element detract from other elements of the lens IQ and would one pay the extra cost? It's similar to the controversy of IS in the 24-70 II (though much better understood by users). But if we were to simulate the same kind of ignorant discourse on the 24-70 II that we've seen on the 50L, we'd see complaining that 24-70 II is too soft and prone to shake. At least here, most folks know why they think this. Now you know the why fors of the 50L.
__
lighthunter80
Re: You've got this mostly wrong but then you are not the first.
__
Thanks Rick for this clarification. I use my L since about 1.5 years now and never noticed any focussing issue. I shoot it mostly between 1.2 and 1.8
I was skeptical when I bought this lens but never regret it. Prices at least here in Australia are 20% down compared to early 2011. The 85L is not an alternative to me, it's an addition. In my case I got the Sigma 85 1.4 and saved a lot with the same image quality.
William DIllard Senior Member • Posts: 2,481
lighthunter80 wrote:
Rick Knepper wrote:
__
The Sigma is very very good because you don't have to get so close to your subject to get really good background blur but I found that I had to lessen the contrast in camera in order for me to feel comfortable with it. If you notice a lot of pictures with the Sigma 85 seem stiff. I think Sigma was out to compete with Canon so they made the lens overly contrasty but they did not have to do that because the lens is sharp as it is and fast focusing too. I reduce the contrast by -1 and it is perfect !
 William DIllard's gear list:William DIllard's gear list
Tokina AF-X Pro 16-50mm f/2.8 DX
