Olympus XZ-2, Panasonic Lumix DMC-LX7 or Sony RX100?
Started Dec 19, 2012 | Discussions
Jerra Junior Member • Posts: 44
Just read this review and I'm still not sure which camera to purchase:
http://www.dpreview.com/news/2012/12/18/enthusiast-zoom-compact-roundup
Just tell me if you had the chance to compare these cameras yourself or what you (dis-)liked in general, e.g. which type of user should choose what camera.
Tahnks
Sony RX100
Chris R-UK Forum Pro • Posts: 15,307
Re: Olympus XZ-2, Panasonic Lumix DMC-LX7 or Sony RX100?
The Conclusions page of the review pretty well sums it up.
I suggest that you decide which of the three groups you fall into (small size/zoom range/general purpose) and them go into a camera store and try them out for yourself.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Jerra OP Junior Member • Posts: 44
"Much as we like the Panasonic LX7, the longer lens, excellent JPEGs and engaging user interface make the XZ-2 stand out for us. The XZ-2 is one of the nicest cameras in this group to use, featuring extensive customization inherited from Olympus's PEN-series interchangeable lens cameras. This is a serious enthusiast camera and easily one of the best of its type that we've encountered. Really the Olympus's strongest competition comes from the Sony RX100 - which at least matches it for image quality but doesn't quite offer the sense of engagement that we appreciate in the XZ-2's operational ergonomics."
I would like a RX100-sensor with XZ-2 ergonomics
___________________
I'm not sure how to compare the LX7 in relation to the XZ-2 ...
May anyone just please contribute anything else to the topic?
Richard Butler
Richard Butler dpreview Admin • Posts: 2,207
The LX7 and XZ-2 are both very nice, but I enjoyed using the XZ-2 more and the JPEG engine is rather better at producing pleasingly coloured images, for my tastes.
The LX7 is cheaper, but the XZ-2 is worth it if you can stretch (we have to assume it'll drop in price).
Richard - dpreview.com
earful Senior Member • Posts: 1,170
i have an rx100 and it's really a marvel in its own way. but i wouldn't mind trying the xz-2 - i believe it has a slightly longer reach and a brighter lens, but the rx100 has the advantage of a larger sensor. it might depend on your usage as to which is better for you.
Jim Marshall4057 Regular Member • Posts: 145
I'm in a similar position-mulling over either the XZ2 or the RX100. The alleged superior Sony sensor is an attraction but from the DPR studio results, there is not a lot in it.
My 2p: If you routinely do giant prints or are a dedicated pixel peeper then the Sony may swing it ( but bear in mind the possible soft corners with the Sony lens)
If you need a pocket cam, then the Sony is streets ahead.
If you need the best all rounder, and value the flip up screen, hotshoe and add on EVF, the Oly wins.
Eddaweaver Senior Member • Posts: 2,231
Take a look at some pictures they produce
http://www.flickr.com/groups/rx100/pool/
http://www.flickr.com/groups/1564797@N25/pool/
http://www.flickr.com/groups/1915414@N21/pool/
People have been able to buy the LX7 for alot cheaper than the other two.
It may sound counter-intuitive but the RX100 is alot smaller and lighter than the other two.
The Olympus E-PM2's body (excluding lens) is smaller and and lighter than the LX7 and XZ-2. So it may be worth considering if you're not specifically after something pocketable.
http://www.flickr.com/groups/2075497@N25/pool/
The RX100 has a 3:2 aspect ratio sensor while other cameras discussed are 4:3. That may be an influence on you if you like to do prints.
I think I'm droping the RX100 and will decide between the XZ-2 and LX7.
XZ-2:
+Tilting touch-screen
+Better user-interface
+Longer lens
LX7:
+Brighter lens
+Wider lens
+Maximum shutter speed
I just can't decide.
Cy Cheze Senior Member • Posts: 2,028
One could look forever at the cameras and, from the sole vantage of specifications, remain undecided.  Might pricing be a factor to consider?
All three cameras (and the S110) are good cameras.  The RX100 is pocketable, but the price eats a hole in that pocket.  Have any German retailers offered discount prices?  In the US, the LX7 has been cut to $299, intermittently.  That is an inducement sufficient to offset the other competing distinctions.  For less than half the price of an RX100, one gets a very good coat pocket camera, capable of some tricks the others lack: time lapse and 720 120p video.
In some markets, the 1" Nikon and certain m4/3 devices are also offered at rather low prices.
Sometimes low prices are a warning, rather than an attraction.  Not in this case.
Sadly there is no discounted offer available in Germany, but apart from that I just want to know which advantages of each camera are more likely to be usefull.
ryder78 Contributing Member • Posts: 616
Tahnks
The review has pretty much summed up everything nicely.
I guess the choice will be dependent on the user's preferences and criteria which will vary with individuals. Since you've asked, if it was me I would have probably gone with the RX100 for its larger sensor, better low light performance. Olympux XZ-2 would be my 2nd choice(I do not like the looks of the LX7, which is something personal). In the end, all are good capable cameras.
Good luck.
Question is if someone needs these features:
XZ-2:
+Longer lens
LX7:
+Brighter lens
+Wider lens
Is the user-interface worth it or the brighter lens? etcpp
Tahnks
Good luck.
JanJac New Member • Posts: 1
It is strange, but after 2,5 years the question seems still to be valid (not for Jerra though). XZ-2 is discontinued, but I happened to buy a new one online. Waiting for delivery. It is now priced on par with LX7, RX100 Mk I being still a bit more expensive (not to mention Mk II and Mk III which are way to costly for the purpose, IMHO). I did an extensive research through multiple reviews, sample images, analysis and forums. Did play with Sony and Lumix on store shelves too.
My answer would be: as it goes for image quality, bokeh, autofocus speed, lens speed, versatility - all of them are "equally" good (still best in class, or I missed something), i.e. their small variances from the mean in detailed performance measures average out finally. All are capable of making stunningly beautiful pictures.
It may be that your liking for a particular brand prevails.
But if you feel tilting screen, multifunction lens ring and optional 1.7x zoom and macro lenses will make you happy then the Oly is yours (hurry up!)
But #2 I will do miss the Lumix's 60fps full HD progressive and 720p 100fps slo mo video recording modes.
But #3 if your pocket camera needs to fit into pockets nicely only the Sony will do.
But #4 according to optyczne.pl Olympus lens introduces least distortions of the three and its RAW's are not processed to denoise in camera - this is what bought me finally, not that it would influence final image quality noticeably, but I do like things to be done in proper way.
Where are successors? Are compact cameras with good optics and sensors too expensive to produce?
