Canon 24-105 Lens Test - Sample Photos
Started Dec 16, 2012 | Discussions
Ben Jamin C
Junior MemberPosts: 26
Dec 16, 2012
I have the Canon 24-105 f4 which came with my 6D kit.  I am trying to determine if the copy I have is a "good copy" as it seems there are some that better than others from what I've read from others.  The two photos below were shot wide open at f4, one at 24mm and the other at 105mm.
There is definitely some softness, especially in the 105mm shot's far corners, less so in the 24mm shot it seems.  I know some of this is expected (in a zoom, in this lens), but wanted to see if the results are in line with the expected quality or if it needs some work.
If there's something else I should do to better test the lens and repost different examples let me know and I can do that as well.
I would love to have any thoughts on how the lens is performing - even at the good/bad/expected level.  Thanks!!
Canon EOS 6D
speterson
Forum MemberPosts: 57
Re: Canon 24-105 Lens Test - Sample Photos
In reply to Ben Jamin C, Dec 16, 2012
Seems like a simple process - that of testing the quality of a lens - but there enters a complex of variables that can complicate the process. First of all the interface between your target and the camera. They should be exactly parallel to one another. If the target or camera does not register precisely laterally or vertically then you will not get an accurate report (especially at the pixel peeping level). Secondly, would be your shutter speed. If it is too slow then that could issue movement/blur (although it would be constent throughout). Still it would be advisable to do mirror-up exposures.
Best general advise - take numerous exposures of different targets at different apertures. Best specific advise - get Lens Align or Focus Tune for more satisfying/accurate results.
Steve Peterson
rndman
Senior MemberPosts: 1,595Gear list
Just take normal  pictures instead of "finding" the problems.
If the normal photos are satisfactory, just enjoy them by taking more and more.
These tests and the frustrations are never ending..
 rndman's gear list:rndman's gear list
Rokinon 14mm f/2.8 IF ED MC Rokinon 8mm f/3.5 Aspherical Fisheye
BRUCEK56
Contributing MemberPosts: 858Gear list
In reply to Ben Jamin C, Dec 17, 2012
Hi,
..................................both shots exif indicate they were shot at F8 not F4..............that is a HUGE difference.
BRUCEK56
 BRUCEK56's gear list:BRUCEK56's gear list
Sony Cyber-shot DSC-RX10 Canon PowerShot G7 X Leica Q Canon EOS-1D X Canon EOS 7D Mark II +5 more
Ben Jamin C
In reply to BRUCEK56, Dec 17, 2012
BRUCEK56 wrote:
Hi,
BRUCEK56
Oops, yes you're correct...it was f8.  My mistake.  Better to test at f8 (sharper) to test the lens build?  Or should I do an f4 example also?  Any thoughts?
AOKH
Senior MemberPosts: 2,674Gear list
Ben Jamin C wrote:
BRUCEK56 wrote:
Hi,
BRUCEK56
Personally, I'd follow rdman's advise. All lenses exhibit some flaws and if it performs well under normal shooting, why get into what can quickly become an exercise of aggravation? However, if you are going to go through with it, better to do it wide open (as flaws are more obvious using max apertures).
Regards. Anders
 AOKH's gear list:AOKH's gear list
Canon EOS 5D Mark II Canon EF 35mm f/1.4L USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM +14 more
BRUCEK56
Hi,
Definitely test it wide open first. Be sure to check the corners that even if they are a little soft at F4 which is normal that it is somewhat uniform around the frame and does not extend too far into the picture frame.
I just went through HUGE problems with my 24-105 lens that I sent to Canon to get refurbished. It was 7 years old and needed to be refreshed.
I paid 408.00 and it came back in as new condition. However after testing it it was very sharp in the center but extremely soft in the corners that extended far into the frame.
To make a long story short I ended up sending it back a total of four times (twice with my 1DX body).
After getting special handling and a supervisor and their best lens technician at their Virginia facility it was determined they could not repair the lens. They ended up shipping me a new lens (actually a late model refurb).
The new lens was completely different than my original returned lens. It was up to factory specs and I am very pleased with it.
While it is true you need to go out and take "normal' pictures to see how it behaves I do believe the newspaper test is important.
My defective lens was extremely sharp in the center even at F4 but horrendous in the corners that extended too far into the frame. I do mostly portrait type work so it took me awhile to see the problem with the corners.
I only first noticed it with group shots where the the left and right people on the sides were very blurry and it finally took me to the newspaper test to figure out precisely what the problem was. I sent 100% crops of these examples to Canon each time I sent the camera in but they still couldn't fix it.
I will always do the newspaper test now before testing any new lens in the field just so I have a baseline understanding of how the lens is supposed to perform.
BRUCEK56
billythek
Veteran MemberPosts: 5,053Gear list
It looks about normal to me for the 24-105.  The CA looks familiar, too.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
Miguel Rodríguez
New MemberPosts: 20Gear list
In reply to Ben Jamin C, Dec 19, 2012
Looks very similar to mine. Not a great lens, just an ok lens for walkaround.
