New Sigma 17-50 f2.8 OS on D7000. Backfocus?
Started Dec 16, 2012 | Discussions
gen123
New MemberPosts: 4
Dec 16, 2012
Hi all,
I just bought a new Sigma 17-50 f2.8 OS from Amazon and did the battery test to see if there were any front/back focus issues.
I used a tripod + timer, and focused on the second battery from the left. The third battery appears to be more focused at 17mm and 26mm, while the correct battery is in focus at 38mm and 50mm.
I also took photos of a lens test chart, where again it appears to be backfocusing at 17mm.
I'm fairly new at all of this, so I'd like to get your opinions. Do you guys see a backfocusing issue as well? Would I be able to correct this using the AF fine tune in my D7000? Should I exchange the lens / send it to Sigma for calibratoin?
Any help is appreciated!
17mm
17mm crop
26mm
26mm crop
38mm
38mm crop
50mm
50mm crop
17mm
50mm
Nikon D7000
SteveL54
Senior MemberPosts: 2,668
Re: New Sigma 17-50 f2.8 OS on D7000. Backfocus?
In reply to gen123, Dec 16, 2012
gen123 wrote:
Hi all,
Hi Gen,
Welcome to the forum!
It does look like the lens/camera is back focusing at the short end of the lens's focal length.
Have you tried the new lens on larger subjects further away? The reason I ask is that lens focus errors can be influenced by target distance. Both of these tests are good for close-in AF testing but they often exercise the lens near its minimum focus distance. I'm not familiar with this Sigma lens, but characteristics of a few lenses interact with the camera's phase detect AF unit and cause it to mis-focus only at close-in distances.
If you send the lens in for AF calibration the test rig used by the service center will be set up to test the lens in the neighborhood of 40 times the lens focal length.
I recommend a test like this that is carried out at a further distance.
http://www.pbase.com/slockhart54/auto_focus_test_procedure
I notice from the EXIF that you are using a D7000. There have been reports that the ambient light color temperature influences the AF accuracy. These reports have mentioned that incandescent or low color temperature lighting causes back focusing. I don't know if it's been confirmed, but it's worth trying tests outdoors or with higher color temperature daylight CFLs to see if that influences the AF test results.
The AF fine tune may help if it corrects the AF at the short end of the focal length without affecting the long end as much. I have noticed this with a couple of my zooms, so AFFT worked well with my lens that had a tendency to back focus at the short end, but not at the long end. But it's best to fine tune at the distance you intend to most use the lens.
The problem could be the lens or the camera. Have you tried the camera with another lens under similar conditions?
Even if I was sure it was the lens (not the camera) causing the BF problem I'm not sure which course of action to recommend here. If you send the lens off for calibration then your window of opportunity to return/exchange the lens will close should the lens not be fixed to your satisfaction. If you exchange, then it's another roll of the dice.
Steve
HSway
Veteran MemberPosts: 3,026
I wouldn’t worry. You are not likely to be shooting at 17mm at 2.8 these ranges. For similar scenarios especially and on tripod the LV (focus) is also an alternative.
You can fine tune a zoom lens and in case of different values at various FL settings, you can optimize for the best result in general or for your preferred setting. If you are getting results you simply are not happy with, or it shows a bad variation, exchange the lens.
In case your lens and camera is Nikon and both still within the warranty – you can send it in, Nikon must adjust it whether it’s a body or the lens.
But I mainly add to very good advice of the above poster because I had 2 of these Sigmas and both were spot on d7000. but I think I didn’t even go up to 17mm. My 24-70 Nikkor for example (quite recent purchase) was also spot on on d600 from 70 to 35 @2.8, at 24mm it was off. I didn’t mind it at all. That is quite good for a zoom, I have seen much more peculiar results for this sort of variability and at the same time many zoom lenses that were easy to fine tune using the camera.
Guidenet
Forum ProPosts: 15,232Gear list
Doesn't look bad to me. If you don't like it, fine tune it a smidgin.
But look here. What in the world are you doing? Get out there and take real pictures. Enjoy that excellent camera and lens and quit fussing around. I know of few people who take battery pictures. It would bore me to death. It should you as well.
There's a lot of crazy measurabators on these forums who don't ever seem to be into photography but into super testing glass. I don't know why. If you're not into photography, I can't see why it matters. If you are into photography fine tune it or work around it. No lens/camera combination is perfect and you don't know what might be a very slight bit off. Sending it back over and over again would be an effort in frustration and further detract from the primary goal of having a good time.
The best tests on new glass is to try them out in real situations to see if they perform well. If they do, keep them. If not trade them in. If you're trading more lenses than keeping, something is wrong with you. This is supposed to be fun.
Good luck and have a great holiday season taking real pictures and creating real images.
Cheers, Craig
Follow me on Twitter @craighardingsr : Equipment in Profile
 Guidenet's gear list:Guidenet's gear list
Canon PowerShot G1 X Nikon D300 Nikon D700 Nikon D3S Nikon D800 +30 more
gen123
gen123 OP
New MemberPosts: 4
In reply to SteveL54, Dec 17, 2012
Thanks for the welcome and reply!  I've been lurking around these forums for a long time, and have always been impressed by the helpfulness of folks like yourself :).
I brought the lens out today to take some pictures with bigger subjects in both natural and artificial light.  To be fair, these were hand-held, thus user-error can always come into play... but the results have been fairly consistent as far as I can tell.  I always used the center focus point, and did not do any focus-and-recomposing.  Check out these photos:
17mm, the drink is not in focus at all.  it's possible that the camera locked focus on the wrong thing though.
17mm (not LV), appears that the poster behind the subject is in focus (I put the AF point in between her eyes)
17mm (LV), subject is in focus
I tried a couple other FL, and to me, it seems the backfocus persists from 17mm to about 28mm.  From 28mm to 50mm, the focus was more or less correct.
I did the battery test again this morning in natural light, with similar results.
I also using my Nikon 35mm f1.8 and Tamron f2 60mm, and both were spot on with the focus.
Steve
gen123
gen123 OP
New MemberPosts: 4
In reply to Guidenet, Dec 17, 2012
I agree that we should all be taking real pictures rather than boring battery tests.  However, given some of the stuff I've read about this (and other) lens, I wanted to make sure I did my due diligence on it by testing it with as few variables as possible.  In regular usage, I find that it's not always easy to tell whether a shot is bad because of user error or because of the hardware.
In this case, I wanted to consult with the more experienced users on this forum to see whether the lens I got is a "bad copy".  As you said, no lens/camera combination is perfect, but some are worse than others.  I really don't know the extent of how bad these camera/lens issues can get, and I figured it wouldn't hurt to have a few more people to look at it.   It's hard to have a good time taking photos when things don't work the way you want them to!
Cheers, Craig
Guidenet
In reply to gen123, Dec 17, 2012
That's true and I understand, my friend. There's a good article over at Lens Rentals about this point you might want to read. Basically, it said that you just can't tell what the cause is for a little front or back focus. Just being a few putzometers off in the mirror box or mount can affect a lens but not another. It might not be the lens at all, but the combination of factors you just can't control. The most perfect lens in the world might not be so on your camera.
Moreover, the tests change a little based on humidity, pressure and other factors from time to time. You might be correcting something that really doesn't exist. Like I said, your shots looked ok to me in most cases. A little fine tuning might get you as close as possible with your camera. I don't know. Also, there are work arounds we've delt with for years. After a while you know where your lens / camera combination likes to be. You learn to be at that sweet spot.
Finally, a good compelling image with good composition trumps most any fine tuing to the lens you can do, providing the lens is pretty good anyway and yours certainly seems to be. Afterall, cheaper cameras can't fine tune and these minor issues are worked around or ignored.
The problem is you can never get it perfect. If you try, you just get frustrated. When you get frustrated with a lens / camera combo you lose confidence in it and if that happens, might as well sell it all and start over. You'll never be happy. That's why I say it might be better to only test under field conditions. Don't look for corrections that can never be perfect. Don't let it ever get to that point. Everything will eventually become a "bad copy." Blame bad images on yourself only. That's the real culprit anyway.
I recently bought that lens you just bought for my daughter who's a wedding pro and still shoots DX. The Nikon 17-55 f/2.8 is just too heavy for her to love it. She loves the Sigma and creates wonderful images with it.. absolutely beautiful.
Good luck and have a wonderful holiday season.
Cheers, Craig
SteveL54
In reply to gen123, Dec 18, 2012
These photos do tend to support the battery and slant chart tests that the AF error extends to normal distances, but by themselves are not that conclusive. This is typical of many "real" subject photos. On the other hand, if these two mis-focused photos are typical of nearly all your shots between 17-24mm then I'd say there's a calibration/adjustment problem with the AF system. Unfortunately it doesn't narrow the source to either the lens or the camera body.
In the first photo it's possible that the high contrast grout line on the tile background influenced the PDAF system's correlation function. It's close enough to the selected target (cup) to possibly show up on the central sensor. The AF sensors are influenced by high contrast detail immediately outside of the brackets in the view finder. As a rule of thumb I try to have a buffer which extends 1/2 the width of the marked bracket around all sides of the selected AF bracket. If there's anything in that buffer that's high contrast and not at the same distance as the desired AF target then there's an increased risk of AF error.
The poster is not in focus either. The best focus is behind the woman's face but in front of the poster. The woman's face is framed in the photo such that it covers a greater area for AF sensors than the cup in the first photo so I think the issue described above is less likely in this case, but the very dark jacket hood which forms a high contrast rim against the light poster might also influence the AF system if it's in the central AF sensor's area of influence. The rim which extends behind her head is better focused than her face.
But these are just elements of the supplied photos that might influence the AF. Chances are slim that these issues come into play in all the other photos you've taken between 17-24mm. Even if you do get a very occasional in-focus photo at these settings does not prove you don't have an error either. Sometimes things happen that cause a canceling error and you end up with an in-focus photo. (A few errors occur even when the system is properly calibrated.)
At least that seems to eliminate the old color temp question.
The reason I recommended the type of test in the link above is that if one follows the procedure and the lens back focuses, it's hard to come up with a "user error" excuse for the result. The test uses an ideal AF target. If significant AF errors occur with that test then the AF system (body and/or lens) needs adjustment.
Do you have access to another lens in the 17-24mm focal length range? How about another camera body?
If not, then I suppose you could exchange for another new lens before your exchange privilege runs out and see how it behaves.
edit: Almost forgot to ask if you tried AF fine tuning?
Steve
gen123
gen123 OP
New MemberPosts: 4
In reply to SteveL54, Dec 18, 2012
Steve
I have a 18-105mm and a 18-200mm (which I want to sell and replace with the Sigma) that I can take some shots with. I've had a limited time shooting with them in the past (the 35mm f1.8 stays on most of the time), but I haven't noticed any obvious focusing issues. I'll definitely try both of them in the 18-24mm range now that you mention it though.
As for AF fine tuning on the Sigma 17-50... I played around with it last night in increments of 5, and seemed to get the sharpest (handheld) photos with a AF fine tune of -20. Strangely, even the shots at 50mm became slightly sharper with the adjustment. I wonder how much of a difference AF fine tune makes across different FL? I plan on testing more systematically (i.e. with tripod and inanimate subjects) to see if I can get the focus even better. My concern is that the proper AF fine tune is inconsistent across the zoom range, or that the ideal AF fine tune adjustment is more than -20.
I came across this guide regarding AF fine tuning. Would you happen to have any other resources to recommend on this subject?
Again, thanks for your reply and advice  .
rhlpetrus
Forum ProPosts: 24,104Gear list
Same with mine
In reply to gen123, Dec 19, 2012
It can be an amazing lens, but it needed +20 AF finetune to work alright. All my Nikkors work spot on with AF FT = OFF.
I will never, likely, buy 3rd party lenses again.
Renato. http://www.flickr.com/photos/rhlpedrosa/ OnExposure member http://www.onexposure.net/ Good shooting and good luck (after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
SteveL54
Steve
Those two lenses should give you an idea if the body is significantly contributing to the AF error at 18-24mm. They aren't f/2.8 but they should be f/3.5 to f/4.0 in that range. That should provide a DOF shallow enough for a comparison.
I imagine the Sigma has a distance scale on the lens. That helps speed the AF fine tuning against a live view benchmark distance. See the shortcut section near the bottom of my procedure. The one thing to watch out for when comparing image sharpness between settings is any mirror slap or vibration. Cheap tripods -- especially their heads -- can be suseptable to vibration. Using the lens distance scale to check AF takes this potential variable out of the picture -- so to speak.
If you want to consider another type of rig for AF tuning Mako has recommended this procedure:
http://forums.dpreview.com/forums/post/50199802
If your systematic testing indicates -20 is required (or more) then something definitely needs to go in for service or be replaced.
BTW I just checked the setting I have in my 18-200mm. It's -4. That value isn't perfect throughout it's entire range of focal length and focus distance, but I've been happy with its performance on my D300. My 28-70mm f/2.8 uses an AF tuning setting of -5.
Steve
motobloat
Regular MemberPosts: 497
In reply to SteveL54, Dec 19, 2012
Steve
Indeed. Steve's result of -4 or -5 AF Fine Tune (AFFT) are what you would normally see with a "healthy" lens and camera combo.
If the problem is with the camera body, you'll tend to need AFFT values of more than what is allowed (i.e. less than -20 or greater than +20) and almost all lenses will need the same correction AND the correction will be in the same direction.
If the problem is with one lens, you'll only need AFFT on that lens, and it won't be correctable with -20 or +20, AND - this is crucial - all other lenses you test on the body don't need a severe AFFT correction. If you have this issue, Sigma will correct the lens for you under warranty, but you will probably want to send your camera body to them so that they can match the lens perfectly to your body (they usually ask for the body from what I've heard).
My D7000 is at the Nikon service center right now to get the backfocus issue fixed. It used to focus pretty well, but in the last few months it has become worse and worse, to the point where nine different lenses all needed -20 or more AFFT (except for one, which only needed -18 lol). So I sent it in a few weeks ago. The repair bill was $155. Still waiting for it to come back.
You can read other people's results after sending their camera in for repair all over the place, but here are a couple of threads that were easy to find.
http://forums.dpreview.com/forums/thread/3287410#forum-post-50108572
http://nikonrumors.com/forum/topic.php?id=5557
The D7000 back focus issue is a real thing - although there are certainly people who claim to have a back focus problem where none exists, and they just don't know how to set up their AF settings. If it is a camera issue, it can be corrected at the repair center with an adjustment of the AF Sensor and the mirror. Or at least, most repair tickets for back focus issues contain one or more of these items:
- ADJ MIRROR ANGLE
- ADJ AF UNIT
- ADJ AUTO FOCUS OPERATION
- RPL MIRROR DRIVING UNIT
- RPL AF GEAR SHAFT
kay4401
Regular MemberPosts: 394Gear list
In reply to gen123, Nov 27, 2014
To the OP... did you ever get this issue resolved? I've had a D7000 since it came out in 2010, and I never had any focus issues with any lens... until now. I just just the Sigma 17-50 f/2.8 OS lens, and, wow, major focus issue! So, I did a search for this issue. Please tell me if you got this resolved or not.
 kay4401's gear list:kay4401's gear list
Nikon D7000 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Sigma 50mm F1.4 EX DG HSM Nikon AF-Nikkor 80-200mm f/2.8D ED Tokina AT-X Pro 11-16mm f/2.8 DX II
Robertomendo
Contributing MemberPosts: 548Gear list
In reply to kay4401, Nov 27, 2014
I had nothing but frustration with the D7000/Sigma 17-50 combo. Finally resolved the issue by selling both camera and lens and moved to the D600 and Nikon 24-120. Problem solved.
 Robertomendo's gear list:Robertomendo's gear list
Canon PowerShot G1 X Nikon D810 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 70-200mm f/4G ED VR Sigma 24-105mm F4 DG OS HSM +1 more
Jim Holtz
Contributing MemberPosts: 969Gear list
Have you adjusted the microfocus of the D7000/17-50mm? If you have and can't get it sharp, contact Sigma service in New York if you're in the US and they'll get it straightened out very promptly. I'm also assuming you're shooting AF-C, A3 set to off?
I have this combination and it's splendid. Check my gallery for examples.
Good luck!
Jim
 Jim Holtz's gear list:Jim Holtz's gear list
Nikon D610 Nikon AF-S Nikkor 24-120mm f/4G ED VR Tamron SP 24-70mm F2.8 Di VC USD Nikon AF-S Nikkor 70-200mm f/4G ED VR Nikon D7000 +3 more
kay4401
In reply to Jim Holtz, Nov 27, 2014
I have tried adjusting the autofocus fine-tune. Strangely, no matter how far + or - I adjusted it, there appeared no change at all. I have an e-mail in to Sigma. Being Thanksgiving Day at time of this writing, I doubt I'll get a response back today. Thing is, I bought the lens used on eBay, so I doubt any repairs that might be needed will be covered under any warranty. Technically, I had the camera in AF-A mode, but I will try AF-C. And yes, A3 was set to off. I will try to post a pic or two for reference.
Good luck!
Jim
kay4401
Couple of pics.  The red square was the focus point I was using.  I had focused on the closest object of the three on the table (the one on the left, it's an athsma inhaler), but the middle object (the Morton popcorn salt) was more in focus.
Here's the same pic with the autofocus points turned off.  Remember, the object on the left is what I had focused on, but the middle object appears to be what turned in focus.
Jim Holtz
Good luck!
Jim
Here's the proper settings and procedure to adjust the camera/lens. Give it a try;
Jim
From Jonikon;
After a good amount of testing different AF settings of my D7000, I have settled on some settings that give me the most versatile AF mode with the most accurate results. I find this method superior to the AF-ON mode.
Set AF mode to AF-C
a1 - AF-C priority set to Focus for stationary objects
a3 - Set to OFF.
a6 - Number of focus points = 11
f5 - Assign AEL/AFL button to AF lock only.
I choose the number of AF points based on the requirements of my subject.
· 1 point for static objects.
· 9 points for slow or predictable direction moving subjects.
· 21 points for erratic moving subjects (like hummingbirds), that only fill a small portion of the scene.
With this AF set-up, keep your shutter button half pressed so the lens continuously adjusts focus until you actually fully depress the shutter. Focus and re-compose is accomplished by pushing and holding down the AFL button after subject focus is achieved.
I hope some will find these AF settings suggestions helpful to achieve more reliable AF results.
Best regards,
Jon
To fine focus the camera/lens, try Dot-Tune 1;
http://www.youtube.com/watch?v=7zE50jCUPhM&hd=1
If Dot-Tune doesn’t satisfy you, the complete fine focus process is listed below;
What is the best way to use the Micro Focus Adjustment?
The question is simple enough, but the answer really depends on the lenses you're using and the way you use them. The point of focus can be adjusted up to +/- 20 steps in 1-step increments. Also in both cases, any adjustments you make apply only to the specific camera body in question; lenses themselves are never modified by the camera's AF micro-adjustment settings. The amount of focus adjustment per step is proportional to the maximum aperture of the lens, with the goal being to increase the precision of the adjustment with large aperture lenses since they have a smaller depth of focus. With all that as a preamble, here the procedure for selecting and using an AF micro-adjustment setting:
  1. Mount the camera to a sturdy tripod.
  2. Position a reference target for the camera to focus on. The reference target should have sufficient contrast for the AF system to read, should be flat and parallel to the camera's focal plane, and should be centered with respect to the picture area.
  3. Print out either this Siemens Star Focus Chart or this Focus Test Chart on regular letter size paper. You can print it on a laser printer or inkjet (doesn’t really matter). Make sure to print on regular paper, not anything glossy like photo paper.
  4. Scotch tape or some other adhesive material to keep the focus chart on the wall.
  5. Lighting should be bright and even.
  6. Camera-to-subject distance should be no less than 50 times the focal length of the lens. For a 50mm lens, that would be at least 2.5 meters, or approximately 8.2 feet.
  7. Set the lens for AF and the camera for One-Shot AF, and manually select the center focusing point.
  8. Shoot at the maximum aperture of the lens via manual mode or aperture-priority AE, and adjust the exposure level if necessary to achieve an accurate exposure of the reference target. Use a low ISO setting to reduce noise.
  9. If the lens has an image stabilizer, shut it off.
  10. Use a remote switch and/or the camera's self-timer to release the shutter. Use mirror lock as well.
  11. Take three sets of images at micro-adjustment settings of -5, 0 and +5, i.e, three consecutive images at -5, three consecutive images at 0, and three consecutive images at +5. Then take a live view image for comparison.
  12. Examine the resulting images on your computer monitor at 100% pixel magnification and compare each image to the live view image.
  13. Take additional sets of test images at different micro-adjustment settings if necessary until the sharpest image is achieved and most closely matches the live view image.
  14. Save the corresponding micro-adjustment settings in the camera.
Here are a few additional precautions to observe:
• Do not attempt to autofocus on an angled chart, because doing so will degrade the consistency of the camera's focusing measurement. Keep in mind that the camera's AF sensor is comprised of multiple pairs of linear pixel arrays. If you attempt to autofocus on a single line in an angled focusing chart, only a few pixels from each active pixel array will "see" the target. Ideally, the contrast in the reference target should cover the entire area of the camera's center focusing point, and the reference target should be perfectly parallel to the camera's focal plane.
• For best results, manually set the focus on the lens to infinity for every exposure before allowing the camera to autofocus the reference target.
• Expect some minor variations in focusing accuracy within each set of three test images, even though they were all taken at the same micro-adjustment setting. This is completely normal, and is due to the tolerances of the camera's AF system.
• Expect smaller micro-adjustment settings to have a greater effect with telephoto lenses, and vice versa for wide-angle lenses.
• If you are attempting to set micro-adjustments for a zoom lens, it is important to realize that the camera's setting may only be accurate for the focal length setting you test. The instruction book suggests testing at the longest focal length of the lens, but you may find it more efficient to choose the focal length you use most often.
• Some cameras and some zoom lenses may require more sophisticated calibration than the in-camera AF micro-adjustment settings can provide. In such cases, it may be necessary to have calibrations performed at a Factory Service Center.
kay4401
Thanks, Jim.  I went through the steps with the focus chart.  Just you can see what I am dealing with, none of them are even close.  Totally off.  Crazy off.  I'm at a total loss.
Autofocus Fine-Tune at -5:
Autofocus Fine-Tune at 0:
Autofocus Fine-Tune at +5:
Jim Holtz
Do a liveview image for comparison. Liveview is perfect every time since it focuses off the sensor.
Also, try the Dotune method. It's quick and easy. It's also very accurate.
Jim
