Will we ever get a small FF body?!? i mean D90 size....
Started Dec 13, 2012 | Questions
radul New Member • Posts: 1
I was waiting so long to get an FF and still i need to carry all this weight...
Nikon D600 Nikon D90
ayt Contributing Member • Posts: 698
Re: Will we ever get a small FF body?!? i mean D90 size....
the D90 is 620 grams body only.  the D600 is 760 grams body only.  very little difference in weight between the two.
what will be the difference in terms of weight will be the lenses.  larger image circle means a larger lens, which has more glass and thus weighs more.  they are usually built to higher standards too, adding to the weight.  you won't see FX DSLR lenses go down to the size of DX lenses unless there are serious reductions in specifications, which is a bad trade-off.
I think the D600 is just the right size for the lenses it will use.  one day we might see a full-frame in a D90-sized body (it isn't impossible) but it doesn't make too much sense to me.
 ayt's gear list:ayt's gear list
Sigma DP2 Canon PowerShot S95 Olympus E-1 Olympus E-500 Olympus E-620 +38 more
itcrashed
itcrashed Regular Member • Posts: 164
Sony RX1
 itcrashed's gear list:itcrashed's gear list
Fujifilm X-T1 Nikon D4S Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-20E III +5 more
rhlpetrus Forum Pro • Posts: 24,480
I had a D80, updated to the d7000, and have held the D600. It's only slightly larger and heavier than either, which are close to D90. Have you tried it? And that's the way it should be otherwise most FF lenses would feel quite unbalanced with it.
Renato. http://www.flickr.com/photos/rhlpedrosa/ OnExposure member http://www.onexposure.net/ Good shooting and good luck (after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
jkjond
jkjond Veteran Member • Posts: 7,824
There's a brill site for comparing camera sizes, though it only shows current/recent models.
Take a look at this:
http://camerasize.com/compare/#243,289
Have a play with the drop down menus to compare the physical size of a host of cameras.
Its clear that a major size reduction could be achieved going mirrorless, but other than that it could be a long wait for space saving technologies to get back to the size of a film slr. There is an F6 film camera on there, its interesting to see how that compares with a D700.
http://camerasize.com/compare/#193,181
UK wedding photographer in the Lake District
http://www.johnleech-weddingphotography.co.uk
For my landscapes and fine art photography:
http://www.johnleechstudio.co.uk
Catalana Senior Member • Posts: 1,257
That's Pentax territory. Or at least that is what Pentax owners are hoping for....
 Catalana's gear list:Catalana's gear list
Pentax K-5 Nikon D600 Pentax smc DA 15mm F4 ED AL Limited Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sigma 70mm F2.8 EX DG Macro +10 more
PK24X36NOW Senior Member • Posts: 1,570
Honestly? Are we really going to continue to hear this whining about a miniscule size difference?!
http://camerasize.com/compare/#179,378
nathantw Senior Member • Posts: 1,366
itcrashed wrote:
Sony RX1
It's too bad we can't be saying Nikon 1 or Nikon 1 V2 instead.
http://www.flickr.com/photos/nathantw/
Always have a camera with you and make sure you use it.
John Motts Veteran Member • Posts: 5,091
Yes. The D600.
There won't be anything else for the foreseeable future.
krikman Regular Member • Posts: 402
I had try D600 and found it is very D90-ish feel in hand.
That is positive and negative. It depends on situation.
Lance B Forum Pro • Posts: 28,904
Mirror box/pentaprism issue
Unfortunately, the mirror box needs to be larger to allow for the larger mirror and pentaprism than an APS C DSLR like the D90, so that negates any idea of it being as small as the D90. The D600 is only 150gms heavier than the D90, so what's the big deal?
 Lance B's gear list:Lance B's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +16 more
57even
57even Senior Member • Posts: 9,232
Re: Mirror box/pentaprism issue
I agree, the body is not much bigger or heavier, but most FF lenses are pretty heavy. Anything smaller than a D600 gets unwieldy with some larger lenses like the 24-70 and most of the weight I carry around is FF glass.
One of the reasons I bought the 24-120. It does save a lot of weight compared to multiple lenses.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
4x5 Guy Senior Member • Posts: 1,341
From what I hear, you will be happy come June 31, 2013.
shigzeo
shigzeo Senior Member • Posts: 1,725
No. Nikon stopped making small 35mm size cameras in the 90's. Well, the FM3 is small, but it is basically the same FM design that begun in the 1970's. Every Nikon Automatic everything camera is large, heavy, and includes a grip. Some people love grips. I don't.
My FE is smaller than my wife's D5000. It has a bigger viewfinder and is made much much better. All controls are external and labelled, so that you never have to turn on the camera to see what shutter speed you are at, and since lenses that work with it are all Ai and pre-Ai class, you can see aperture right on the lens.
Nikon will never make another small SLR. Their current DSLR range is still massive in comparison to older film cameras. It's just how it goes. Auto everything needs bigger batteries, can't house as thin bodies because they want to throw everything in there - even things that most people will never use.
The day someone brings out a digital FE, I'm dropping my D800.
 shigzeo's gear list:shigzeo's gear list
Nikon D200 Fujifilm X-Pro1 Nikon D800 Leica M Typ 240 Sony Alpha 7R +9 more
wy2lam Veteran Member • Posts: 3,082
It's only when you don't really care about DOF equivalence. On an FX body, a small and light 28-105mm f/3.5-4.5 gives roughly the same composition that requires a 17-70 f/2.8 lens on DX, usually large and heavy.
 wy2lam's gear list:wy2lam's gear list
Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R +5 more
