Full 24mp image from Tokina 12-24mm on a D600???
Started Dec 12, 2012 | Discussions
schaf Contributing Member • Posts: 731
I am a bit perplexed. My dad has recently purchased a D600. He has used the Tokina 12-24mm with it, which is a DX-format lens. He has the camera set to use DX crop mode. Yet the images I have seen from this combo are coming in as FULL 24mp images (as indicated by the EXIF data) with NO vignetting. Detail, color and contrast are precisely what you would expect from this lens.
This makes no sense at all to me. How is this even possible?!?!?!? Theses should be the roughly 10mp or so DX cropped images, not 24mp images. Ok...not like he is complaining about it though.
Is anyone else using this combo? Are you getting full 24mp images?
Thanks in advance,
Schaf
Nikon D600
gobiassumcoffee Regular Member • Posts: 155
Re: Full 24mp image from Tokina 12-24mm on a D600???
Thanks in advance,
Schaf
I'm not familiar with that lens specifically but many DX wide angle zooms will cover the FX sensor at the longer focal lengths.  Are the pictures closer to the 24mm end than 12mm?  It shouldn't cover the frame at 12mm.
schaf OP Contributing Member • Posts: 731
I will have to check on the focal length. My dad is in another state for the winter and I "iChat" with him on the Mac and share his screen when working on images with him in Aperture and this is how I discovered he was getting full 24mp images. I will check on the focal length. I should have him shoot some at 12mm and some at 24mm and see what happens
Thanks,
Schaf
Mako2011
Mako2011 Forum Pro • Posts: 20,140
How...
How are you determining that the images are the full 24mp? Do the show a 6016 x 4016 resolution or 3936 x 2624 (DX Crop) ?
onlyfairways Forum Member • Posts: 50
Thanks in advance,
Schaf
Hi Schaf.
I've been using the Tokin 12-24 f/4 DX on a D800E with the camera set to auto DX-crop mode. The D800 does not see the Tokina as DX lens so it works as though it was an FX lens. The vignetting appears and increases as you widen the focal length to 12mm but does not seem significant at 24mm. I manually set the camera crop to DX mode so that there is no vignetting at any focal length.
B.Taylor
 onlyfairways's gear list:onlyfairways's gear list
Nikon D800E
Re: How...
The EXIF data, as displayed by Aperture, is showing a pixel dimension of 6016 x 4016. And this is what has me perplexed.
Schaf
I will have to have my dad take some shots at different focal lengths to see where the lens starts to vignette. That said, I am still perplexed by the fact that he claims to have set the camera in DX crop mode. He is using the original Tokina 12-24mm lens without the BIM so perhaps there is something with the data the lens is sending the camera that is amiss here?
Schaf
caspianm Senior Member • Posts: 2,132
That lens can be used in FF mode from 18-24 w/o vignetting. You will get full pixels.
 caspianm's gear list:caspianm's gear list
Nikon D800E Sony Alpha NEX-3N Sony Alpha 7 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +13 more
shaunly Contributing Member • Posts: 541
17mm without filters and hood. I use it on my D800. Great lens.
www.flickr.com/shaunly
mais51
mais51 Senior Member • Posts: 1,704
So is the Nikon DX 12-24mm - full FX images from 16mm to 24mm.
 mais51's gear list:mais51's gear list
Canon PowerShot S120 Nikon D300S Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +8 more
verybiglebowski
verybiglebowski Veteran Member • Posts: 3,773
It's more like 17-18 to 24.
tankahn Regular Member • Posts: 280
I got the Tokina 11-16 DX. Vignetting is not an issue at 16mm.
moving_comfort
moving_comfort Veteran Member • Posts: 8,203
Examples - 12-24 on FF
If it really was 24MP, then it was shot in FX mode, and if it was in FX mode it couldn't have been wider than about 18mm. So it could be possible from 18mm to 24mm, although I think 19-24 is more likely if a hood was used, if you saw no vignetting.
Here are some examples from my Tokina 12-34 on my D700 from a couple years ago:
12mm
15mm
18mm (with hood)
19mm
20mm
Here are a few of my favorite things...
---> http://www.flickr.com/photos/95095968@N00/sets/72157626171532197/
 moving_comfort's gear list:moving_comfort's gear list
Pentax K20D Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 20mm f/2.8D +10 more
krikman Regular Member • Posts: 404
Yes, I tried tokina 12-24 (screwdrive) and found it is usable from 15 mm with 4:5 ratio or 1,2x crop but with  some corner shading.
After 19 mm there is fullframe coverage with no visible vignetting at all and surprisingly good image quality in center and acceptable corner quality.
Even single 77mm filter adds visible vignetting.
So in emergency you can use 12-24dx as 18-24fx lens.
