Hensel 500 pro plus modeling light malfunctioning?
Started Dec 11, 2012 | Questions
deerpark243
deerpark243 Junior Member • Posts: 28
I have one last question about my Hensel. I replaced the Modeling light and it still didn't work. So I replaced the fuse for the modeling light, it works now but not like it did before it went out. Now when I go to change increments, each 1/10th the lamp goes completely out for about a second then comes back on again. I know it's recharging each time but I don't think it's suppose to do that and I replaced the fuse with the same type of fuse.What could be wrong? I've had my "Kit" for about 5 years now and only used it sparingly but I use it quite a bit now.
Deerpark243
bestairet Junior Member • Posts: 49
Re: Hensel 500 pro plus modeling light malfunctioning?
Did you inadvertantly  turn on the flash check button when you changed the modeling light? That would account for the modeling light going out while the unit is charging. Call Bill Moretz at Pro Camera in Charlottesville VA ph# 434.979.1915, He sells and repairs Hensel. If anyone knows it is him or one of his staff if you still have problems.
Peter Berressem Forum Pro • Posts: 10,647
I agree, that's likely the reason.
cheers, Peter
Germany
