Operational aspects of D800+Samyang 14mm/2.8 (chipped)
Started 5 months ago | Discussion
mibadt
Senior MemberPosts: 1,038
5 months ago
Hi,
I tend to buy the above (chipped) lens as a WA solution to my D800. As, so far, I haven't used any non-AF lens, I'd appreciate if somebody can enlighten me as to the following operational aspects:
  1. Will the D800 be able to measure exposure in matrix and CW modes?
  2. Will the D800 (in matrix and S mode) automatically adjust the lens aperture?
  3. In A mode, can I adjust the aperture from the camera?
  4. Will the correct aperture, lens model, and focusing distance appear in the EXIF data?
  5. Will the D800 (in matrix exposure mode) correctly control a TTL/BL flash (e.g., SB800)?
  6. Am I correct assuming that since this is a "chipped" version, there is no need to enter focal distance and minimum aperture (as a regular non-cpu lens)?
  7. Any additional operational aspects (Besides the obvious lack of AF capability)?
Regards, Michael Badt Photos gallery: http://www.flickr.com/photos/mibadt/
A Owens
Senior MemberPosts: 1,882
Re: Operational aspects of D800+Samyang 14mm/2.8 (chipped)
In reply to mibadt, 5 months ago
mibadt wrote:
Hi,
I don't know what you mean by a chipped version (is the chip there to pass exif data?) so here are my responses for the version I use on  D800e.
1. yes
2. No
3. No
4.No
5.Yes
6.No
7. Use the camera in aperture priority setting the aperture on the lens, camera chooses the appropriate shutter speed. Or use in manual mode and set the shutter speed on camera. Focus manually through LV or viewfinder. Works like a charm. Lens sharp to furthest corners (as long as you are focussed at the corner). I do not get lens exif data from mine (only shutter speed) but maybe that chipped version you speak of does that.
Enjoy!
Alistair Owens
http://www.alistairowensphotography.com
mibadt
In reply to A Owens, 5 months ago
Thanks for your insight.
Just to clarify, I'm referring to this lens.
Anybody else?
michaeladawson
Veteran MemberPosts: 6,674
Anybody else?
I am somewhat mystified by the answers given in the previous response.  If I read the questions correctly the answers were almost all wrong.  Maybe I should go back and see if the questions were asked in the negative.
The chipped version of the Samyang lenses give you complete automatic (or electronic) control of the lens. The lens will behave just like any modern day Nikon lens except that it is manual focus.  The answer to almost all your questions is 'yes'.  I have the 85mm Samyang.  The 14mm chipped version of the lens should behave in the same way.
Mike Dawson
5tve
Contributing MemberPosts: 623
mibadt wrote:
Hi,
A couple of links you may find useful
http://www.samyang.co.uk/samyang-14mm-f28-if-ed-umc-nikon-ae.html
http://www.ephotozine.com/article/samyang-14mm-f-2-8-ed-as-if-umc-lens-review-19621
from the review
The version tested here includes a metering chip with electronic contacts so matrix metering is supported on all Nikon cameras. This means the lens has to be left at f/22 to operate normally on modern Nikon cameras, but no lock is provided to hold the aperture in this position. No such issues should be encountered with the basic version, as no metering information is transferred to the camera.
Ralf Ronander
Contributing MemberPosts: 728
Q 1 to 6 = YES
Q 7: the lens focusses way beyond "infinity", i.e. if you set the lens to infinity on the distance scale everything will be blurry. In my experience - as well as others - setting the lens at ~3m will result in sharpness out to infinity.
nelsonal
Senior MemberPosts: 2,238
Re: Q 1 to 6 = YES
In reply to Ralf Ronander, 5 months ago
On the fish eye, that's something you can adjust at home with a screwdriver (I don't remember if it's phillips or flat.
ADMint
Regular MemberPosts: 484
In reply to michaeladawson, 5 months ago
Anybody else?
Mike Dawson
Correct. And I have the 14mm Rokinon (chipped) version.  And for those that don't know, the "chipped" version means the lens has a CPU chip to work with the auto exposure system of the camera. Everything works other than auto focus as this is a manual focus lens.
As for Exif data...
Dreamwalk, D800E, Rokinon 14mm lens (chipped). Color Efex soft filter applied
New to this forum, not to forums!
ADMint
Re: Q 1 to 6 = YES
True; however, you can always use the green focus dot in the view finder. That's what I do, and I have no problems. But yes, the infinity side seems to be off a little. Other than that, it's a great lens for the money, and it's plenty sharp.
gobiassumcoffee
Regular MemberPosts: 155
Re: Q 1 to 6 = YES
The quality control on this lens is poor and from what I've read the focus scale can be all over the place.  Some people say infinity is infinity, some say it's at 2m, and plenty in between (including 3m like you have).  I had one that initially seemed tilted (left side of frame infinity was beyond infinity on the focus scale, middle was ~ 3m, right side of frame was ~2m) but opened it up and tinkered with it a bit and now it's pretty spot on.
Verkku
New MemberPosts: 18
Anybody else?
Mike Dawson
My lens works like mike wrote above. The previous answers are wrong.
V
NPU.member
gobiassumcoffee
In reply to Verkku, 5 months ago
Anybody else?
Mike Dawson
V
NPU.member
Probably just confusion between the chipped/non-chipped version of the lens.
ADMint
Anybody else?
Mike Dawson
V
NPU.member
To be clear, you might want to clarify/specify what "previous answers" you're talking about. I, like you, agree with Mike - that the chipped version gives full electronic auto exposure.
Thanks.
Edited 5 months ago by ADMint
Meganrogers
Regular MemberPosts: 248
Re: Q 1 to 6 = YES
In reply to gobiassumcoffee, 5 months ago
Is it an easy fix? Like changing the position of a limit screw? If so, I may try to fix mine!
Ralf Ronander
Thanks for the tip
In reply to nelsonal, 5 months ago
I´ll try that
xrdbear
Veteran MemberPosts: 3,533
Just chipping in to say...
In reply to Meganrogers, 5 months ago
This is a great lens. Admittedly my first copy was decentered but it was replaced immediately with one that is perfect.
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
gobiassumcoffee
Re: Q 1 to 6 = YES
Not particularly; I wouldn't have bothered if it was just a miscalibrated focus scale but the tilt on mine was a real issue that needed resolving.  I hear lots of people complaining of decentering with this lens but I wonder if it's not actually a tilt issue like mine had.  The defects can look somewhat similar; i.e. the edges being blurry when the center is in focus.
If your only issue is a miscalibrated focus scale and optically the lens is fine then I wouldn't bother.  There are ways to tweak that but I don't think it's worth the effort.
A Owens
In reply to ADMint, 5 months ago
Anybody else?
Mike Dawson
V
NPU.member
Thanks.
Are you all saying that the chipped version controls the aperture from the camera? So you can use it in Shutter priority and the camera will work the aperture? If so disregard my answers. As I said they refer to the version I have which is a Samyang ED AS IF UMC made in Korea!
Alistair Owens
Edited 5 months ago by A Owens
mibadt
Re: Q 1 to 6 = YES
Thanks all of you for the detailed responses which helped me decide to go for it!
gobiassumcoffee
A Owens wrote:
Anybody else?
Mike Dawson
V
NPU.member
Thanks.
Have you guys read the questions? Lets go through them again slowly:
  • Will the D800 be able to measure exposure in matrix and CW modes? Yes, I think we all get that.
  • Will the D800 (in matrix and S mode) automatically adjust the lens aperture? No, aperture must be set on the lens. There is NO connection between the camera and the aperture of this lens. None, Zip, Nada.
  • In A mode, can I adjust the aperture from the camera? Again NO. Slowly one more time. Aperture must be set on the lens. There is NO connection between the camera and the aperture of this lens. None, Zip, Nada.
  • Will the correct aperture, lens model, and focusing distance appear in the EXIF data? NO. And I have looked at the link the OP sent regarding the chip on the lens and I do not believe this will give Exif data to the camera but stand to be corrected by someone who has actually used the lens and knows what they are talking about. You will still get non-lens exif such as ISO, shutter speed etc.
  • Will the D800 (in matrix exposure mode) correctly control a TTL/BL flash (e.g., SB800)? I believe so but if someone has used this flash with this lens on a D800 lets hear from them if they disagree.
  • Am I correct assuming that since this is a "chipped" version, there is no need to enter focal distance and minimum aperture (as a regular non-cpu lens)? I assume the OP is asking whether the camera needs this to make a correct exposure with 3d metering etc. NO, there is no need to enter this information. However it has nothing to do with the chip or lack thereof. The camera will meter the scene based on the amount of light coming through the lens which in turn is determing by the aperture SET ON THE LENS. Subject distance will not be factored into the exposure calculation.
  • Any additional operational aspects (Besides the obvious lack of AF capability)? I have already stated how I use the lens on my D800e.
Now which particular response do you feel is wrong?
Alistair Owens
I have the chipped version of the lens. I set the lens to f/22 and the camera controls aperture. The aperture shows up in my EXIF. You clearly do not have the chipped version of the lens, or perhaps yours is malfunctioning.
Check the EXIF - I promise you I did not alter it.
Edited 5 months ago by gobiassumcoffee
