Need a metal Leica-like Lens hood for XE!
Started Dec 8, 2012 | Discussions
Dave Cheatham Contributing Member • Posts: 951
Does anyone know where I can get a lens hood to compliment my new Fuji XE1? I want metal and the square looking product. The only one I saw at Band H was cheap plastic?
Dave C
Fujifilm X-E1
mrgooch2008 Regular Member • Posts: 495
Re: Need a metal Leica-like Lens hood for XE!
I have this one from Ebay.
 mrgooch2008's gear list:mrgooch2008's gear list
Fujifilm X-T1 Canon EF 14mm f/2.8L USM Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
DecisiveMoment
DecisiveMoment New Member • Posts: 5
Hello Dave,
I'm looking also for a lens hood for my X-E1 with the 18 - 55mm lens. The lens hood that came with the kit does cast a shadow on your image if you use the built in flash. The lens hood is a tulip design and is a defective design. I did email Fujifilm about the issue and hope to hear from them soon. Since the lens hood is of a bayonet design then a rectangular hood should work. If I come up with a solution I'll post it here. I want Fujifilm to come up with a solution regarding lens hoods for all their lenses for the X line of cameras.  -Frank
PhotoNut
 DecisiveMoment's gear list:DecisiveMoment's gear list
Sony Alpha 7R Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +1 more
adubg New Member • Posts: 10
Would this be a good lens hood for the 18-55 kit lens?
lnbolch
lnbolch Senior Member • Posts: 1,995
Straight hoods work great on primes, but are only effective at the widest end of a zoom. Were they effective at the long end, they would vignette at the wide end. The petal type is a working compromise and a pretty universal solution on zoom lenses.
On-camera flash with shadows cast by lens or hood is nothing new—pretty much a universal problem except with short lenses. No problem with my D700 if I am using my 105mm or shorter primes. Pretty useless with zoom lenses.
 lnbolch's gear list:lnbolch's gear list
Fujifilm FinePix Real 3D W1 Fujifilm FinePix X100 Nikon D700 Fujifilm X-Pro1 Nikon AF-S Nikkor 14-24mm f/2.8G ED +8 more
Astrophotographer 10 Senior Member • Posts: 6,581
I discovered that flash shadow last night.
Thinking about it - all you have to do is remove the hood when taking flash shots. You don't need it at night or dim occassions usually anyway.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
