Inkpress ICC profile
Started Dec 6, 2012 | Discussions
lukaw Regular Member • Posts: 298
Inkpress ICC profile for Luster paper, Epson 3800 isn't available on Inkpress website.
Does anyone have a profile for the above?
Thanks.
Hugowolf Forum Pro • Posts: 12,545
Re: Inkpress ICC profile
I can't imagine the 4880 profile being that different, I think it is the same ink set.
Brian A
jtoolman
jtoolman Veteran Member • Posts: 5,599
Ramonn Regular Member • Posts: 114
Inkpress also suggests using Perceptual rather than Relative Colormetric rendering intent when using their profiles.
lukaw OP Regular Member • Posts: 298
jtoolman wrote:
It is right there!
http://www.inkpresspaper.com/profiles.asp?PaperID=40
Yes, I'm aware that it suppose to be "right there", however, there is no profile when you click to download it, nada.
The same applies to Epson 4800 profile.
MrPhotoBob
MrPhotoBob Senior Member • Posts: 2,913
I had the very same problem from Inkpress with needing a profile, but I got on the phone with them and told them my problem, then next day they e-mailed me the profile that I needed for my printer.
 MrPhotoBob's gear list:MrPhotoBob's gear list
Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +2 more
Thanks for your reply.
An email has been sent.
lukaw wrote:
jtoolman wrote:
It is right there!
But the 4880 profile is there, I don't think the 4800 profile would do you much good.
Brian A
jtoolman
When you clip on it you should get the normal Run - Save, at the bottom. If it does not show as I just verified, it means it is not available. The PRO 3880 is as it shows the download - run or save options. Maybe they can email it to you.
Joe, when I get there, I don't see the 3880 profile. Plenty of others, but not the 3880. Strange, but that is my experience.
Brian A
Petruska Veteran Member • Posts: 7,553
I see the 3880 profile...
and can download it.
The OP is looking for the 3800 profile, that's for the non-vivid magenta ink set, the 3880 and 4880 use the vivid magenta ink set.
Bob P.
jtoolman
Joe. the OP is looking for the 3800
profile, not the 3880.  He is using the non-VM ink set.
Bob P.
Re: Joe. the OP is looking for the 3800
Ah so, my apologies. The 3800 profile is indeed readably available.
Brian A
No, the 3800 is not available....
It's listed, but no download.
Re: No, the 3800 is not available....
Exactly.
supahdotcom New Member • Posts: 1
hey there - were you ever able to find this icc profile? (Inkpress Luster paper / Epson 3880)
I'm looking everywhere, I emailed the company and since it's the weekend I don't really expect to hear from them, though I was trying to do some printing this evening.
Hoping someone can point me in the right direction. Thanks!
