Nikon 70-200mm f/4 vs Tamron f/2.8 VC
Started Dec 4, 2012 | Discussions
Steve Koon
Steve Koon Junior Member • Posts: 36
I plan to buy one of these two in Shanghai.  Nikon USD1,400 and Tamron 1,550, which is a better choice with D600.
I shoot mostly family, portrait and street as hobby, not professional work.
Steve
Nikon D600
gl2k
gl2k Veteran Member • Posts: 3,232
Re: Nikon 70-200mm f/4 vs Tamron f/2.8 VC
Tamron lenses are prone to missadjusted aperture levers resulting in incorrectly exposed images.  IQ wise Tamron delivers mostly very good results. Often enough though Tamron lenses are sharper in the center than their counterparts but softer in the corners.
brightcolours
brightcolours Forum Pro • Posts: 12,469
Ignore brand generalizations
From the early samples and "test" reports, both are very fine lenses. The 70-200mm f2.8 VC USD can easily rival the Nikon 70-200mm f2.8 VR II, and the Nikon 70-200mm f4 VR seems to be a lovely beast as well.
So, base your decision on their 2 main differences:
* maximum aperture
* size and weight.
While the Tamron gives you 1 stop bigger max. aperture, it weighs almost 2x as much. 1.5 kilos is quite a lot to lug along, and the 800something grams of the Nikon can be a real advantage.
Personally, I would prefer the lens with the least weight. because I do like to take it along a lot.
Steve
slimandy
slimandy Forum Pro • Posts: 16,169
Based on reports both seem to have excellent IQ so it boils down to the extra stop verses the lighter weight. It depends how you intend to use the lens. I use the Nikon 70~200mm f2.8 and I like having f2.8 but I sometimes wish I had a lighter alternative. I'm going to stick with the f2.8 lens but if I was hiking regualrly I would get the lighter lens.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Fujifilm X-T1 Fujifilm X-E1 Nikon D700 Nikon D200
Brev00
Brev00 Veteran Member • Posts: 7,420
For portrait work, I would go for the Tammy and the faster aperture.  For street, I would definitely go with the Nikon and the lighter weight.  Going hybrid, I would think the Nikon could get you some nice portraits while I doubt you would often want to use the 2.8 zoom for street work.  Your style; you decide.  Don't forget, in terms of price comparison, the tripod ring is an added option on the Nikon and will add to your cost.
www.flickr.com/photos/brev00
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Tokina AT-X Pro 12-24mm f/4 DX II Sigma 17-70mm F2.8-4 DC Macro OS HSM Sigma 70mm F2.8 EX DG Macro +3 more
glo
glo Senior Member • Posts: 1,481
Steve
My preference is to go with 2.8, I like isolating from fore/backgrounds even when I'm not shooting portraits. Weight should be a non issue, getting the image you want should be worth carrying some extra weight. But the Tamron? ... spend a little more and get the Nikon vr2, it's awesome.
glo
 glo's gear list:glo's gear list
Leica M Monochrom (Typ 246) Nikon D3X Nikon D810 Nikon D4S Leica M-Monochrom +2 more
brightcolours
Steve
glo
The Tamron, with less breathing than the 70-200mm f2.8 VR II, is "awesomer", especially for you who likes to isolate.
DVSteve
DVSteve Contributing Member • Posts: 912
Steve
glo
It's a little more than a "little more."
Astrophotographer 10
Astrophotographer 10 Senior Member • Posts: 6,536
Not really. Tamron is around $1500 and Nikon F2.8 70-200 are going for as low as $1998 on Ebay.
The Tamron needs to come down. I'd get one at $1000 but $1500 is too close to the Nikon which is my trusted brand.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
dv312
dv312 Veteran Member • Posts: 3,145
leaning towards the Nikon
for it's much lighter
when you carry the lens around all day then the lighter weight makes a big difference
Bokeh on the F4 should be good enough for most cases (as seen in samples)
The lens is light enough the tripod mount is not needed
IQ wise they should be on par with each other
The extra stop can be easily compensated by the sweet ISO range on the D600
AF speed may favor the Nikon since it's proprietary and Nikon didn't provide specs to 3rd party
Cheers
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus 12-40mm F2.8 Olympus M.Zuiko Digital 25mm F1.8 Olympus 9mm F8 Fish-Eye Body Cap Lens +8 more
brightcolours
Re: leaning towards the Nikon
You probably mean blur, not bokeh. The amount of blur is good enough. Bokeh is the quality of the blur, not the amount.
That is debatable. The camera and lens mount will not break, sure. However, you will need to use a remote shutter and mirror lock up quite often, because the long lens will easily vibrate, even on quite sturdy tripods.
Cheers
engbert
engbert Senior Member • Posts: 2,484
A D800 weighs 900g, while the 70-200 f4 weighs 800g.
So it makes more sense to have the tripod mount on the camera which weighs more.
www.pbase.com/bertramm pbase & dpreview supporter
Glen78
Glen78 Contributing Member • Posts: 704
Not sure I agree with you. With a tripod mounted D800 + 70-200 f/4 the center of gravity is going to be much closer to where the lens collar mounts than to the mount on to the camera body. Mounting with the tripod collar will also dampen lens vibration.
 Glen78's gear list:Glen78's gear list
Nikon D600 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR +5 more
redwill
redwill New Member • Posts: 13
Closer in, the Tamron breaths less.  But at 30 feet or infinity, the Tamron is a 175mm lens while the Nikons are at about 195mm.
http://www.lensrentals.com/blog/2012/12/quick-resolution-tests-on-two-new-70-200s
