Foveon colors
Started Dec 3, 2012 | Discussions
guzzibreva1 Contributing Member • Posts: 951
Foveon colors
I have noticed that my Sigma cameras have the ability to differentiate subtle changes in in color better than my Bayer cameras. I notice it mostly in greens. My SD15 also seems to be a bit more color accurate than my Pentax and Sony cameras.
This is difficult to understand since it is known that the color separation of the foveon chip is not as efficient as the Bayer color filter. Most all reviews of Sigma cameras also talk about the great colors, IQ, and saturation at low ISO.
My only guess is that the broad spectrum sensitivity of each layer helps differentiate color at the expense of color noise at lower exposure levels. This could be achieved with the Bayer filters also but then the noise would be similar to the the Foveon. Overall public acceptance of higher speed must be more important than outright IQ.
Sigma SD15
Laurence Matson
Laurence Matson Forum Pro • Posts: 11,594
Blitzmerkur
It is a shell game over in Bayerland. A well-done one in most cases, but still . . .
Laurence
laurence at appledore-farm dot com
Sometimes, life is going to hit you with a brick. Don't lose faith.
Steve Jobs
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
xpatUSA
xpatUSA Senior Member • Posts: 7,374
Re: Foveon colors
Your experience is opposite to mine but on the SD9 whose color inaccuracy is documented ad nauseam in this forum. I sold mine in despair at those brown reds under artificial lighting which are still evident in the SD1 review on this site. Later, I bought an SD10 which seemed greatly improved in that regard. Meanwhile, my humble Nikon D50 produces very accurate colors in RAW/ACR (camera neutral profile). According to the MacBeth card, anyway.
According to a paper by the Foveon guys, the sensor does not suffer from "color noise" (actually color aliasing).
Public definitely seems to  prefer huge resolution, enormous ISOs, ultra-high frame rates and now HD movies with stereo recording and not forgetting Wi-Fi, Bluetooth, Android with live touchscreens. All that for just a buck or two. Excuse me, while I puke
Best Regards,
Ted.
Sigma DP2s Panasonic Lumix DMC-G1 Sigma SD10 Sigma SD14 Sigma SD1 Merrill +8 more
SigmaChrome Veteran Member • Posts: 8,036
Re: Foveon colors
No puking on the forum -- if you don't mind!
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
guzzibreva1 OP Contributing Member • Posts: 951
Re: Foveon colors
"According to a paper by the Foveon guys, the sensor does not suffer from "color noise" (actually color aliasing)."
This is not correct.
The Foveon colors suffer at high ISO because there is a lot of common mode information in the color channels. This requires more amplification to extract chroma information. When the signals are small, the noise from this amplification noise shows up as hue shifts in the form of blotches.
The up side to this seems to be that the sensor is equally sensitive to all colors whereas the bayer approach favors the primary colors of the array. My Pentax K5 produces images where the greens tend to all look like the were all painted with the same color brush. The highlights lose saturation before clipping also. This is why some people have said the colors look "thicker" in the foveon images.
Jim Beverlin Veteran Member • Posts: 3,309
Re: Foveon colors
Interesting post.  I have 3 Pentax cameras and have just taken images of our highly decorated Christmas tree with a K-05 and a K-01.  Want to try shots with both my 1st D and DP2X too.
With all settings at default I was surprised how much better the K-01 handles reds than the K-5.
Will try the other cameras over the weekend and advise.  I have a number of limtied primes that are used with the K-01 and am really amazed at the quality that I get from this much maligned camera.
JRB
xpatUSA
Re: Foveon colors
I was referring to the content under "Color Aliasing" in this paper:
http://www.foveon.com/files/CIC13_Hubel_Final.pdf
It says this, and more:
"In cameras that employ color filter array (cfa) mosaics aliasing
occurs in the three color planes at different locations. This artifact,
referred to as color aliasing, appears as brightly colored fringes in
locations of image detail at a particular spatial frequency."
Can't see anything incorrect there . . .
Best Regards,
Ted.
ArvoJ Senior Member • Posts: 1,287
Re: Foveon colors
I think that guzzibreva meant that color noise and color aliasing are different things. Foveon concept suffers from relatively high color noise, but not from color aliasing.
Arvo
Sigma/Foveon information collection and little galleries:
http://www.stv.ee/~donq/sigma.htm
http://www.stv.ee/~donq/images.htm
 ArvoJ's gear list:ArvoJ's gear list
Sigma SD14 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 105mm F2.8 EX DG Macro +1 more
