What monitor to buy
Started Nov 26, 2012 | Discussions
JDeKock
JDeKock New Member • Posts: 1
What monitor to buy
I read a lot on the internet about monitors and i'm about to buy the Dell U2410.
But now i'm not sure if this is the best for me.
I edit photo's in photoshop cs6 but don't print them my self. I send the photo's to shops or to my customers. Also i publish my photo's on internet. I'm also going to buy a spyder 4 elite to calibrate the monitor.
First i was looking at the Nec PA-241W. But this cost my around 950 euro. Than someone said that i had to look at the Dell U2410 because of its price (444 euro).
Is the Nec so much better than the Dell, because it's cost twice at much.
Thanks.
 JDeKock's gear list:JDeKock's gear list
Nikon D700 Nikon D300S Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +2 more
Pictus
Pictus Veteran Member • Posts: 5,565
Re: What monitor to buy
The Nec is a Pro monitor and the Dell consumer class.
The PRO line from NEC(P/PA) , Eizo(CG/SX) and QUATO have a programmable hardware internal LUT(14 to 16 bit) and it is much better than using the graphics card LUT(8-bit).
The Dell U2410, U2711 and U3011 they got a NON programmable hardware internal LUT(12-bit)
at least it is better than nothing, but the calibration curves still in the graphics card 8-bit LUT.
LUT= LOOK-UP TABLES
The calibration in the PRO monitors do not lose tones
Do not confuse the LUT thing with the 10-bit output
First decide if need wide gamut monitor or not, check
http://forums.dpreview.com/forums/post/42376724
and http://www.youtube.com/watch?v=n0bxSD-Xx-Q
Then check the reviews:
TFT Central
FlatpanelsHD
PRAD and the more updated German version
In the Prad reviews pay attention to:
-The UGRA test (download the PDF)
-The panel brightness distribution
-The gamut coverage (good place to compare)
-Profile accuracy and the calibration curves, the good ones are in 45º
-The contrast is the least important as any monitor have more contrast than any paper print
-Give preference to monitors that does not use PWM
-Only choose monitors with IPS/PLS panels and avoid TN panels!
TN panels have less than 178º viewing angle
-Give preference to 8-bit or 10-bit panels and avoid 6-bit
Complementary info:
http://forums.dpreview.com/forums/post/40306131
http://forums.dpreview.com/forums/post/42063694
Reviews for calibration devices:
http://www.drycreekphoto.com/Learn/Calibration/MonitorCalibrationHardware.html
http://www.gamutprints.com/2012/04/i1display-pro-vs-spyder-4-and-spyder-4-quick-review/
To calibrate a NON PRO monitor I prefer to use the FREE and super excellent Argyll + dispcalGUI
Twilight35 Senior Member • Posts: 1,016
I bought a Dell U2412M three weeks ago from B+H Photo for $299.00. I do Photoshop and Gaming with it and for me it's just GREAT. Most monitors are 16x9, but htis one is 16x10. It gives you more scrolling room. Check it out.
Fred
kcbeatty Senior Member • Posts: 1,761
I can't add anything to what pictus said. I have a Dell U2410 and have used it for almost a year. Haven't had any issues with it, I use ColorMunki Display to profile it. So far I am pleased with this monitor for my work.
I wise man once told me that "Practice does not make perfect. Only perfect practice makes perfect "
Kevin
malch Forum Pro • Posts: 13,126
Had mine for almost a year and love it.
DonA2
DonA2 Senior Member • Posts: 2,659
6 months and can't fault it.
Don V. Armitage
 DonA2's gear list:DonA2's gear list
Canon PowerShot SX10 IS Canon PowerShot SX40 HS Canon PowerShot S2 IS Canon PowerShot S100 Canon PowerShot SX50 HS +1 more
DVT80111 Senior Member • Posts: 2,186
I suggest this $399 27 inch LG S-IPS panel
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Fujifilm X-E1 Canon EOS 70D Canon EOS 6D Sony Alpha 7R II
(unknown member) Contributing Member • Posts: 946
LUT= LOOK-UP TABLES
Do you mean all graphics cards are only 8-bit? Or, some are capable of 10-bit (Quadro/FireGL)?
Pictus
All are 8-bit per channel, the exception are the FirePro/Quadro details in the link http://www.imagescience.com.au/kb/questions/152/10+Bit+Output+Support
I remember its press-release said this monitor used 10 bit look up color table.
http://www.asus.com/Display/LCD_Monitors/PA248Q/
The 27 inch model says 12 bit color.
I contemplated buying one of them, but picked a Dell 24" IPS (refurb deal)
I cannot find any reference about the color bit anymore. Apparently it didn't help them selling product because not too many people want to pay $200-$300 for a newer graphic card.
Mikeobe Contributing Member • Posts: 757
Re: I suggest this $399 27 inch LG S-IPS panel
BJN
BJN Veteran Member • Posts: 5,057
Don't get the Dell
I just posted a topic about returning a Dell U3011 which had poor color and tonal consistency. If you want a display that's very consistent over the entire display area, get a display engineered for critical use. Dell doesn't make that kind of display. NEC and Eizo do. If you choose an NEC model that's designed for color critical work, you won't regret paying more for a much better tool.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Panasonic Lumix DMC-GM5
No. If it is not saying IPS, it is not IPS panel. Even if it says IPS, you need to know what type.
Try this one
http://www.amazon.com/PA248Q-24-Inch-Super-IPS-Professional-Graphics/dp/B008DWH00K/ref=sr_1_2?s=electronics&ie=UTF8&qid=1354065140&sr=1-2&keywords=asus+IPS+panel
thanks, I'll check it out!
Pictus
rrrremus Regular Member • Posts: 113
That is very informative. Thanks.
Do i need a special video card? I know display port is preferred, but can DVI output more than 8bit per color channel ?
 rrrremus's gear list:rrrremus's gear list
Nikon D800 Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR
Pictus
Glad to help, no DVI can not.
Anyway, 30-bit is very trick
Only works with Photoshop CS6/CC + Windows 7/8 + FirePro/Quadro Card + DisplayPort.
Photoshop CC is or was buggy and was not enabling 30-bit for FirePro cards, I do not know if is fixed now.
bronxbombers4 Senior Member • Posts: 3,385
Re: Don't get the Dell
BJ Nicholls
SLC, UT
Some of the Dell Premiere color models do have uniformity compensators too. Apparently with some of the older ones that mode doesn't work if you calibrate the screen yourself, but for instance, on the UP2414Q it does.
