Nex M39 adapter
Started Nov 13, 2012 | Questions
peeterpeeter New Member • Posts: 2
Nex M39 adapter
Hi
I have a problem with my M39/L39 adapter i just got from mail. I've tried four different
lenses on this adapter and non of them focus correctly (old russian lenses). I'm getting blurry
photographs from all distances with all the lenses. The blurrines isnt minor, its like the distance from the sensor is all wrong. What am i missing? I thought the difference between the L39 and M39 is barely noticeable and can be corrected with the adjustable inner ring on the adapter.
the product i ordered:
http://www.ebay.ie/itm/Leica-L39-M39-Lens-Sony-NEX-E-Mount-Adapter-NEX-3-NEX-5-NEX-7-NEX-C3-DC109-/180748714749
so what kind of lenses i could use with this adapter?
thanks
p
Jim Parsons
Jim Parsons Contributing Member • Posts: 754
Re: Nex M39 adapter
That adapter is intended for use with L39/LTM Leica mount rangefinder lenses. This mount is also sometimes referred to as M39.
The M39 mount can have two registration distances, depending on which camera is involved. It would appear that you have lenses that are not compatible with the rangefinder registration distance.
Which particular lenses do you have?
See discussion here: http://forum.mflenses.com/viewtopic.php?t=51968
Jim Parsons
flint-hill Senior Member • Posts: 1,215
Re: Nex M39 adapter
Following on to what Jim said, if these are Zenit M39 lenses, you'll need an M39-to-M42 adapter and an M42-NEX adapter.
peeterpeeter OP New Member • Posts: 2
Re: Nex M39 adapter
thanks for the quick replies, i was trying them out in a market, i cant remember all the lenses but one of them was Mir-1, which actually focused on a very close subject, but no infinity.
i cant understand what lenses i can use with this adapter? any suggestions?
thanks
p
Jim Parsons
Re: Nex M39 adapter
thanks
p
Do a ebay search for Leica, L39, or LTM lenses and you'll get an idea what you need to look for.
Jim Parsons
D Cox Forum Pro • Posts: 13,610
Re: Nex M39 adapter
A better option is the M39 Helicoid adapter. It is listed as "Leica M39 L39 lens to Sony E mount NEX adapter Macro Focusing Helicoid 17-31 mm" on eBay here in the UK.
That comes out at the right thickness for Zenit lenses, and if the focus screw on the lens is stiff, you can use the one in the adapter.
Pretty much any of these will work ...
If you have good access to Russian lenses, any of them that are intended for FED or Zorki cameras will work fine. Just stay away from lenses intended for the Zenit camera.
Here's a list of some with US prices ...
http://fedka.com/catalog/index.php?cPath=24
A more exhaustive list is here:
http://camerapedia.wikia.com/wiki/39mm_screw_lenses
Re: Pretty much any of these will work ...
There's no need to stay away from them. You just need the right adapter.
We're answering different questions, I think.
The OP asked:
So I recommended lenses with a standard Leica registration distance.
Stujomo
Stujomo Senior Member • Posts: 1,271
Re: Nex M39 adapter
thanks
p
If you can focus very close but no where near infinity then the adapter is to long and is likely for M39 SLR lenses. To work with LTM rangefinder lenses you need the correct adapter for L39 thread mount lenses.
Oleg L K Regular Member • Posts: 201
Re: Nex M39 adapter
Yes, you most probably have Zenit lenses ("Mir" series - for sure).
For lenses that aren't too heavy you can use your (rangefinder) M39 adapter and M39 extension rings. In most cases it's even better than having the original rangefinder lens - when the same lens came in both rangefinder and SLR variants, the latter has smaller minimum-focus distance.
