NEX 6 and pdaf samples
Started Nov 11, 2012 | Discussions
Jason E.
Forum MemberPosts: 63Gear list
Nov 11, 2012
I recieved my Nex-6 w/ 16-50 kit lens yesterday, so I put it through some initial paces. One recurring theme that keeps coming up on dpreview forums is how well the Nex-6 PDAF perform with movement perpendicular to the sensor (i.e., focus ability with quickly changing distance information).
First a few caveats:
1. This is a rudimentary test, not presented as a definitive professional exercise.
2. The NEX-6 was set to continous AF mode, PDAF enabled, center focus spot only, speed priority drive mode -- all while using the 16-50mm PZ kit lens.
3. The shots were indoor in my basement, with very poor lighting. Consequently, I had to bump up the ISO substantially (noise). Samples are JPEG, straight OOC, sharpness/contrast/saturation all set to "0." I've attempted to upload the native JPEGs from my computer, but I don't know if dpreview will degrade or down-res these images.
4. I kept the aperture larger than 5.6 (f number smaller than 5.6), to make sure that PDAF was enabled.
5. Given the lighting conditions, the shutter speed was suboptimal to freeze all motion optimally.
6. The test subjects, my boys aged 5 and 8, are pretty darn fast. I had them sprint as fast as they could towards the camera. I feel this is an accurate representation of the fastest speed you would likely need to capture most child related activities.
7. I pre-focused on the face, but did not actuate the shutter until after they started running -- to capture photos once movement had already begun. Because they are typical boys, they also skipped/jumped while running -- so the it was really hard to keep the focus point just on the face (probably on the chest a couple times).
8. I didn't spend all day setting up this test, I spent 2 minutes & these were the 1st samples I shot. With practice & improved conditions (and a more optimal lens), I'm sure things would improve.
9. I am migrating from the Canon EOS 40D, and my results are at least as good for straight-line movement as anything I ever accomplished with the Canon. Color me impressed, especially given the sub-optimal conditions for this test.
10. I realize that this test is very amateur-level, so please do not feel compelled to point out the many flaws of my technique or photographic skill. I realize that the high ISO causes noise, the shutter speed is too low to prevent some motion blur, and the focal lengths are sub-optimal. I offer this post simply because I do not see anything similar posted, and think other people on the fence may be interested.
Enjoy! -- other NEX-6 test photos posted here (mainly legacy Canon FDn glass):
https://picasaweb.google.com/100478217890567871686/RememberNovember
1st set: f/5, 30mm, ISO 6400, 1/4000
2nd Set: f/4, 18mm, ISO 1600, 1/400
cheers,
JSE
 Jason E.'s gear list:Jason E.'s gear list
Fujifilm X-T1 Sony a6000 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
Canon EOS 40D Sony Alpha NEX-6
Ronbeau
Forum MemberPosts: 90Gear list
Re: NEX 6 and pdaf samples
In reply to Jason E., Nov 11, 2012
Excellent.  Thanks for doing this.  I've got a nex 6 on the way and have been looking for this kind of test.  I've been planning to do something similar and compare it to my vintage nex 5.
 Ronbeau's gear list:Ronbeau's gear list
Sony a6000
Jason E.
Sorry for the typos -- it seems dpreview won't let me edit . . .
cheers,
JSE
Jason E.
In reply to Ronbeau, Nov 11, 2012
I'm pleasantly surprised and happy with the results.  Additionally, the low ISO images I'm getting with legacy glass have reassured me that I made the right decision to invest in the Nex system.
cheers,
JSE
Clem Nichols
Contributing MemberPosts: 815Gear list
Very helpful, and thanks for your work.  If you could it would be interesting to repeat your experiment at 50mm or an even longer focal length if possible.  Many thanks.
CN
Jason E.
In reply to Clem Nichols, Nov 11, 2012
I totally agree that a longer focal length would be best. Unfortunately, the only native e-mount lens I have is the kit PZ -- so I guess I could try the 50mm end.  It's raining here today, perhaps tomorrow -- since I am limited to f/5.6 at 50mm and I would want faster shutter speeds and a low ISO if possible.
cheers,
JSE
Bstevs
Regular MemberPosts: 137Gear list
Thanks for the experiment. Looking forward to others you do as I am also interested in freezing movement.
 Bstevs's gear list:Bstevs's gear list
Sony Cyber-shot DSC-RX100 IV Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 28mm F2 Sony Alpha NEX-6 +3 more
Keith Schmidt
Veteran MemberPosts: 7,052Gear list
In reply to Jason E., Nov 12, 2012
cute kids.  I don't think your test shows anything about the continuous auto focus though.  At such a wide focal length, pretty much everything in the scene is in focus.
Will be interesting to see how the test looks when you have some good light and can us e the 50mm end.
 Keith Schmidt's gear list:Keith Schmidt's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
malch
Forum ProPosts: 12,760
You couldn't be bothered to build a professionally equipped optical lab for lens testing? I thought that's what basements were for.
Just kiddin'
I think it's a very fine test and the results were, as you say, impressive for a small mirrorless camera. Thanks for posting.
Can't wait for my NEX-6 to arrive in a few more days.
Jason E.
In reply to Keith Schmidt, Nov 12, 2012
Very legitimate point, I really wish I had a telephoto AF lens.  I'll try to test this outside tomorrow at 50mm.
cheers,
JSE
Jason E.
In reply to malch, Nov 12, 2012
I tried to point out some methodological flaws myself, because I was worried I'd embarrass myself on the forum
There is just so much photographic talent that posts on dpreview!
cheers,
JSE
jpr2
Forum ProPosts: 14,650Gear list
Jason: many thanks - I'd be looking forward....
...to more tests of this kind - as your running/jumping kids are exactly right target - at 50mm and not too large shooting distance, and in a light good enough to fire at higher SS - unfortunately, wide open at 50mm with this PZ means f/5.6, so little chance to see a truly narrow DOF results of fast action N6 shooting
any chance for you to rent/borrow 22-210?
best, jpr2
andres76
Forum MemberPosts: 54
Nice test.
Thank you.
Sergey Borachev
Senior MemberPosts: 3,271Gear list
Thanks, Jason.
Does it have to be faster than f/5.6 for PDAF to work?  How about f/5.6?
S.A.
Veteran MemberPosts: 4,072
Thank you for the test. It looks as if AF tracking of moving subjects is now at least doable. Too bad the available zooms are too slow to take advantage of it without being completely wide open. Where is the G standard zoom Sony?
All these years of digital cameras and we are still wanting for dependable AF... Come on!
Scott A.
A few pics
Jason E.
In reply to Sergey Borachev, Nov 12, 2012
Sergey Borachev wrote:
Thanks, Jason.
From my nex-6 manual: "When the aperture value is greater than F6.3, Phase Detection AF is unavailable. You can only use Contrast AF.  Phase Detection AF is available only with compatible lenses. If an incompatible lens is attached, you will be unable to use Phase Detection AF."
I take this to mean the following:
1.  Aperture needs to be equal or larger diameter to F6.3 (i.e., f stop # 6.3 or smaller number).
2.  Use of a compatible lens (w/ updated firmware).
If the above criteria are satisfied, PDAF should be active.
my $0.02,
JSE
cheers,
JSE
Jason E.
Re: Jason: many thanks - I'd be looking forward....
In reply to jpr2, Nov 12, 2012
best, jpr2
I'm tempted to rent one, but can't justify pulling the trigger unless I have a dual purpose/event :-).
Actually, I think a fast prime (i.e., 50mm f/1.8) would approximate the DOF test for fast action testing -- I'm considering picking this one up.  The problem -- it's that loud silver & apparently the AF drive motors for this lens are not the fastest from what I've read on these forums.
cheers,
JSE
jpr2
re: currently the 50/1.8 is not on the list of PDAF compatible lenses...
best, jpr2
...so will not answer any questions abt. fast action shooting and tracking and it well might be that such compatibility is not in S's plans at all !!
jpr2
jpr2
re: currently the 50/1.8 is NOT on the list of PDAF compatible lenses...
best, jpr2
jpr2
quezra
Senior MemberPosts: 3,915Gear list
best, jpr2
cheers,
JSE
50/1.8 isn't PDAF compatible yet so hold on.
Nice shots though, cute boys!
 quezra's gear list:quezra's gear list
Sony Alpha 7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony Alpha NEX-5N Panasonic Lumix DMC-GH3 +10 more
