Comparison Sigma 30 vs. Sony PZ 16-50 @ f5
Started Nov 11, 2012 | Discussions
bloomoose
Veteran MemberPosts: 3,222Gear list
Nov 11, 2012
Shot on a tripod at ISO 1250, Exif of the Sigma image intact as I pasted the Sony image into it.
You can view and download the image here:
http://www.bloomoose.de/images/Sigma_Sony_30.jpg
 bloomoose's gear list:bloomoose's gear list
Sigma DP2 Merrill Sony RX1 Sony Cyber-shot DSC-WX300 Panasonic Lumix DMC-LX100 Olympus PEN E-PM2 +18 more
creeker
Senior MemberPosts: 1,449
Re: Comparison Sigma 30 vs. Sony PZ 16-50 @ f5
In reply to bloomoose, Nov 11, 2012
Hello bloomoose
When you want to post a link to a site don't paste it directly into your reply. Click on the little "chain link" icon at the header of the reply page and paste the link there. Posting using the link icon allows your link to be active and will be able to be viewed.http://www.bloomoose.de/images/Sigma_Sony_30.jpg
Regards, Ed
straylightrun
Senior MemberPosts: 1,251Gear list
Wow, the 16-50 stands up pretty well against the Sigma prime. Impressive for an ultracompact zoom!
 straylightrun's gear list:straylightrun's gear list
Sony Cyber-shot DSC-HX90V Sony Alpha 7S Canon EF-S 18-200mm f/3.5-5.6 IS Sony E 16mm F2.8 Pancake Sony 70-200mm F2.8 G +16 more
creeker
Hello Bloomoose. Your images appear to be crops of the original images. Can you post the original size images. Many consumer grade lens do quite well in the centers, but not as good to the edges. Not seeing the images to the edges doesn't give a true comparison of the two lens. The Sigma 30mm is well known to give good results to the edges. An original size image with the Sony 16-50mm would give us a better idea of how this lens performs. I would like it to be good as it's a great size for walk around. Thank you for sharing your results.
Ed
maurus_e
Senior MemberPosts: 1,655
Interesting. While sharpness on the PZ seems OK, the transitions between contrasting areas OOF look rather strange (around the ears, or from the blue cushion to the white wall). Much better on the Sigma. Is this a result of in camera processing, or an optical property?
Jawed
Senior MemberPosts: 1,484
depth of field varies
The focus distance is not the same for these two shots. The Sigma focus is closer.
bloomoose
Re: depth of field varies
In reply to Jawed, Nov 11, 2012
They were shot on a tripod and I didn´t move it.
bloomoose
In reply to creeker, Nov 11, 2012
Thanks for the hint!
martindesu
Senior MemberPosts: 1,245Gear list
creeker wrote:
Hello bloomoose
Regards, Ed
Even better, embed the photo itself:
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
bloomoose
In reply to maurus_e, Nov 11, 2012
I think it is an optical property, but could be my copy and I did use some highlight recovery when processing. So it´s too early to tell.
I do see this a lot in the 16-50´s OOC corners.
bloomoose
Yes, I could post the images in original size, but there is nothing meaningful on the borders, they´re oof. So I would have to shoot somethin in plane focus, a brick wall maybe for you to judge the edges.
rogatsby
Regular MemberPosts: 466Gear list
A landscape photo would be helpful.
 rogatsby's gear list:rogatsby's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sigma 30mm F2.8 EX DN +3 more
flint-hill
Senior MemberPosts: 1,215
Thanks for doing the work.
Well-thought-out from-a-tripod comparisons have been very scarce with the new lens.
If I recall correctly, you have the Sigma 19mm.  How does it compare at landscape distances with that lens or with the 16/2.8 E?
maurus_e
Thanks, bloomoose.
About the OOF transitions: Hm. Please go on with sharing your experiences with this comparison (and with the PZ in general).
Jawed
That doesn't help with anything because the ​focus​ still has to be set after you have changed lens.
bloomoose
AF point was on the left eye, so if focus differs between shots, I can´t help it.
To me, though, it seems as if focus is correct. What I believe you think you see, is something else, it´s what someone called funny transitions in OOF regions in the 16-50.
ec1k
Regular MemberPosts: 167
Exact same ISO and shutter speed?  The PZ seems to have better contrast.
maurus_e
In reply to ec1k, Nov 11, 2012
Most probably, the PZ had in camera corrections applied (we don't know what parameters are affected, do we?) while the Sigma had no such corrections applied. This makes all conclusions about the lenses alone a bit problematic. Better contrast could also be the result of software corrections...
GaryW
Veteran MemberPosts: 8,018Gear list
In reply to straylightrun, Nov 11, 2012
Pixel peeping, I see more detail in the fibers in the Sigma. Colors are more saturated on the Sony. Not bad,I suppose, but I'll wait for more samples before jumping to conclusions.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Cyber-shot DSC-HX5 +11 more
bloomoose
No camera corrections were applied, as I developed the RAW files exactly the same, aperture, ISO were all set equal.
