Cactus V5 set with Canon 580exii and Yunguno 560ii.. The Yung won't fire.
Started Nov 11, 2012 | Discussions
Damianicus
Damianicus Regular Member • Posts: 122
Hello all,
I recently tried to buy a Cactus V5 duo set and my mega online store was sold out so I bought 2 single Cactus V5 figuring they would all work with each other put on the same channel and set properly RX and TX.
It is annoying you can't use them as a camera trigger unless you get a special cable. So I got a special cable for my 60D to try this out.
Tx in my hand and Rx on the camera it fired. So I knew things were working.
Put the camera in Tx and stuck the Rx V5 under my new Yunguno 560ii and it wouldn't fire in any mode, M S1 S2 or Multi.
I put the V5 under my Canon 580EXii and it fired, and I can set the Yunguno in S1 and the Exii in Master and the Cactus V5 camera will fire both.
Any idea why the Cactus V5 didn't work with the Yunguno?
 Damianicus's gear list:Damianicus's gear list
Canon EOS 5D Mark III
Canon EOS 60D
Damianicus
Damianicus OP Regular Member • Posts: 122
Re: Cactus V5 set with Canon 580exii and Yunguno 560ii.. The Yung won't fire.
Nevermind, got the Yongnuo to work. Must have had it in the Cactus V5 backwards the first time, lol.
