PIX 2015
with low light performance of the 5n, what is the appeal of full-frame?
Started Nov 10, 2012 | Discussions
ennemkay
Senior MemberPosts: 1,293Gear list
Nov 10, 2012
is the dof difference really that significant?
 ennemkay's gear list:ennemkay's gear list
Olympus Stylus Tough TG-850 iHS Sony Alpha NEX-5N Olympus PEN E-PM2 Sony RX100
sean lancaster
Veteran MemberPosts: 6,256Gear list
Re: with low light performance of the 5n, what is the appeal of full-frame?
In reply to ennemkay, Nov 10, 2012
DoF is pretty significant. But FF also has bigger pixels so even though the 5N handles noise well, it doesn't compete with the current FF Sony sensors. Also, FF's bigger pixels allow for higher dynamic-range. And there are more benefits related to using FF lenses.
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 OnePlus One +2 more
FuzzyQball
Senior MemberPosts: 1,328Gear list
I have no experience with FF, but I would think it depends on what you are going to do with your photos.  I can see pros wanting one.  The vast majority of the rest of us have no real need. IMHO.  Poster size prints would benefit, but I wonder how many of us do that?
Glenn
 FuzzyQball's gear list:FuzzyQball's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
sean lancaster
In reply to FuzzyQball, Nov 10, 2012
I guess I don't think I'll do it with any shot I take purposefully, but I like having the option when I get ones that I really, really like . . . like this one I put up last week:
I'd rather keep my options open than close them off completely just because I don't print this size often. That being said, I was able to accomplish this with my 5N so there's that, too.
I don't even think it needs to be a pro versus amateur issue . . . some of us enjoy the hobby enough to just want the best quality we can afford. I gain great satisfaction in being able to shoot the image that I visualize in my head when setting up a shot even if most of my photos are just being posted to Flickr.
ennemkay
the reason i bring it up is that, when comparing the m43 vs. nex, even though dof and iso differences are only about a stop, the two systems are the same price, so choosing nex for that extra stop still makes sense. but ff systems are WAY more expensive, so that extra stop and a half of dof and iso doesn't seem to have proportionate value.
blue_skies
Senior MemberPosts: 8,695Gear list
1 1/3rd stop for APS-C, 5 stops for FF.
DoF is very different too. As is FOV for legacy glass.
Aside from being a lot more expensive, FF gear is also bulky = heavy.
An FF Nex takes the bulk out of the camera, especially the metal frame bodies. Adapters weigh very little.
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +31 more
RicksAstro
Veteran MemberPosts: 3,503Gear list
ennemkay wrote:
... but ff systems are WAY more expensive, so that extra stop and a half of dof and iso doesn't seem to have proportionate value.
Not if you are comparing similar capabilities as far as IQ goes.    I went from a gripped (for ergonomic purposes) EM-5 with the Panasonic 12-35 f2.8...total cost $1000+$300+$1200 = $2500
I went to a Nikon D600+24-85 f3.5-4.5= $2600
The 12-35 is equivalent to a 24-70 f5.6, so about one stop less DOF control on average compared to the Nikon kit.    I compared the results of the 2 cameras and the Nikon's optical quality and sharpness was at least on par across the frame, usually sharper.   Anyone who looked at the results from the 2 cameras would choose the D600 at any reasonable output size, not even accounting for any DOF differences.
And the Nikon 85 1.8G is a superb lens on the D600...perfect for portraits!    The Olympus 45 f1.8 is great too and about $100 cheaper , but it would be equivalent to stopping down the 85 2 stops as far as DOF control, which is a large amount.   And the D600 85f1.8G frankly is magical in comparison.
If you are willing to sacrifice optical quality on m43 or Sony, then you can get a better value proposition.   I just picked up a NEX6 + 16-50.   It's awesome and compact and gives decent image quality, but that lens isn't in the same ballpark as the previous 2 mentioned.   Is it good enough?   Only you can answer that.    I'll certainly take it places that I wouldn't have taken even the Olympus combo above, which wasn't that small.    The D600 is probably the nicest ergonomically if you don't mind the bulk and weight (and conspicuousness).
The best native zoom I've had for the NEX system was honestly the original 18-200, but the weight and off-balance handling (and ridiculous looks) left a lot to be desired.   I hope Sony comes up with a quality 2.8 zoom for the NEX system like Panasonic did...then it can be considered a high quality option, but again it won't be cheap.
coudet
Veteran MemberPosts: 3,847
Some thoughts (I speak as a Nikon user, btw)..
DOF, yes. So is the low light performance. Sony's crop sensors used in NEX are very good, but FF is in a different league. Overall performance of the camera, a good FF DSLR does pretty much anything. OVF. Handling. Battery that lasts what seems like forever. Lens lineup offered for full frame systems. And to make it all even sweeter, when you factor in equivalence, FF system is cheaper too. Pay less, get more. Not a bad deal, huh?
coudet
No, FF is actually cheaper.
Look at 24/1.8 for NEX, for examplel. NEX user pays $1,100 for a slow 35mm equivalent. How much does (would) an equivalent lens cost for FF, a very slow 35mm? Peanuts? RicksAstro, above, wrote a good post. MFT users have it really bad.
Ed Rizk
Senior MemberPosts: 1,722Gear list
Proportional value is not a common factor is most products.  A Ferrari costs four times as much as a Corvette, but it doesn't go four times as fast.  You reach a point in the quality of everything where you have to pay twice as much to get 10% more.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 60D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS II
RicksAstro
In reply to coudet, Nov 10, 2012
Exactly...if you need the shallow DOF, you pay dearly for it on the smaller formats.    If you don't, then yes the crop cameras are a good alternative.
It's not to say that FF cameras are "better".   If you need a smaller system, then certainly the FF cameras are worse.   But to me, FF cameras can cover all your bases (shallow DOF, wide DOF) and be a more flexible system than the crop format if you don't mind the size.
All cameras are a compromise of design.   It's awesome we have such great choices that just about anyone can find a camera that checks off their individual boxes.
NEXFULLFRAME
Regular MemberPosts: 281
In reply to RicksAstro, Nov 10, 2012
Dynamic Range, ought to be better as well. The ability to expose and keep color in the sky, then push the shadows to bring out the detail.
dquangt
Senior MemberPosts: 1,388
In reply to sean lancaster, Nov 10, 2012
I printed a 24x36 that I took with my 5n and it looked fantastic.
DuncanDovovan
Senior MemberPosts: 1,277
I think differences are mainly DOF and extreme high ISO (>6400) performance.
Check it out yourself at: http://www.dpreview.com/reviews/sonynex5n/14
Note that a FF NEX will be a problem, because the NEX e-mount lenses will not perform well in the corners I guess.
Lenses will be bigger and more expensive.
I'm a peaceful person looking for clarity and harmony and willing to help. If you believe my post had the intention to harm you in some way, you are probably wrong. =;-) Please verify first before assuming something bad happened to you. I can be a bit too brief at times. =;-)
sean lancaster
In reply to dquangt, Nov 10, 2012
I believe that image I printed is 48" x 36" from my 5N, so it can be done. But not if you need to crop much. That being said, it gets very expensive if you use a decent to good online service and I am sure I could have gotten quite a bit more quality with a Nikon D800 (I just don't know that I could have taken this same shot from the ground without a flip up LCD). Heh.
EWR72
Regular MemberPosts: 313Gear list
Just wanted to say that the canvas print you made Sean looks fantastic. I have a Canon Full Frame camera that produces wonderful photos but the little Sony Nex-C3 that I own with its flip-up screen gets shots that I would not be able to compose quickly enough with my Canon. Furthermore for A3+ prints the Nex is very capable.
 EWR72's gear list:EWR72's gear list
Panasonic Lumix DMC-LX3 Ricoh GR Digital Sigma DP1s Fujifilm X20 Canon EOS-1Ds Mark II +5 more
ennemkay
that's more an milc vs dslr, mass production thing. if you compare canon aps-c to ff, then it's a different story. all other things being equal the ff lenses have more glass and should cost more. in other words, i'm speculating that an milc ff camera will be extremely expensive (both body and lenses).
rustdream
Junior MemberPosts: 37
In reply to DuncanDovovan, Nov 10, 2012
Full frame in NEX cameras is a no-no to me.
Currently, the worst issue on this platform is the lack of quality telephoto lenses, without IBIS helping with vintage gear.
sean lancaster
In reply to rustdream, Nov 10, 2012
Well, I rarely need to use my 55-210 so I don't mind if a FF NEX emerges with a gap in telephoto (or with only non stabilized Alpha telephotos). But I think the worst issue is the AF speed and that's why I canceled my RX1 pre-order until I hear real world results from users.
losangeles
Contributing MemberPosts: 655Gear list
Your arguments are sound, and they really resonate with what I've been thinking myself these past few weeks. Thanks for summarizing it so nicely.
One thing I'd like to add is the versatility of having a single walkaround lens that "covers all bases" as you say it. For FF, it would be the kit you went for, the 24-85 mm lens. It should offer shallow enough DOF for most situations. But a similar lens on NEX (the new 12-50) doesn't, as I has DOF comparable to a point-and-shoot with fast lens like the new Lumix LX7. So in practice I end up having to carry around (and invest into) more lenses, easily bringing the total above $2k and the same territory as the D600 with kit lens. And the FF alternative will still beat the NEX IQ.
In my mind, the only way NEX (and m43 for that matter) can prevail is by building affordable&high IQ&fast lenses. If the Nikon 24-85 can be had for $500 above body-only, there needs to be a 12-55 f2.3-f3 option for NEX for the same price (same DOF control, similarly sized optical elements, hopefully same IQ as the Nikkor).
