Watermarks is a way of cheating.
Started Nov 8, 2012 | Discussions
CG33
CG33 Regular Member • Posts: 121
I know it is not against this challenge rules, but showing a name or watermark is the best and cleanest way of cheating. especially when the host allows it. Don't you think?
Please post your comments.
http://www.dpreview.com/challenges/Entry.aspx?ID=677387&View=Results&Rows=4
Victor Engel Forum Pro • Posts: 16,473
Re: Watermarks is a way of cheating.
What is your point? What cheating is going on here?
Victor Engel
http://victorspictures.com/blog
Also please check out my new game blog
http://swarmsgame.blogspot.com
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 600D Canon EOS 5DS Canon EF 50mm f/1.8 II Canon EF 135mm f/2.0L USM Canon EF 300mm f/4.0L IS USM +8 more
CG33
CG33 OP Regular Member • Posts: 121
On an ANONYMOUS challenge, showing the name of the participant breaks the anonymity.
That is very unethical. That is C H E A T I N G, especially when you have family and friends that can help you with the 5.0 stars.
Slynky Senior Member • Posts: 2,434
It would seem to be the case. Given that it isn't more clearly stated by DPR (more like it is inferred), it's why I specifically prohibited it in the challenges I ran just to be clear.
/A veteran is someone who, at one point in their life, wrote a blank check made payable to their country for an amount of "up to and including my life"./
(...from the generation that still uses capital letters and punctuation...)
 Slynky's gear list:Slynky's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 18-200mm F3.5-6.3 OSS Sony E 50mm F1.8 OSS +3 more
I don't see where this challenge is an anonymous challenge.
And they wouldn't be able to help without the watermark? The submitter is clearly visible for this entry. It would be visible with or without a watermark. The submitter could email his friends/relatives a small photo of the picture with no watermark. Who needs a watermark to identify a picture when you have a thumbnail?
I must be missing something.
Oh, finally, back when the Canon DSLR challenge was still ongoing, for a significant number of the regulars, it was usually possible to tell which pictures were shot by whom, just because they had developed a distinctive style.
Victor Engel
CG33
I think you are not missing anything, you are just plying "smart guy".
From your point of view these challenges are not anonymous.
Then, it does not make any sense, any sense at all, to hide the participant names on the data of each picture during voting time.
Don't you think?
By the way, I doubt that any of the participants (you included) can differentiate my pictures from the rest of the bunch without looking at them first.
That can be done in a small group of selected of photographers, but not here, where thousands of photographers and non-photographers show their stuff.
Victor Engel
The submitter is only visible AFTER voting has completed. Before that, it's not known--unless the person watermarks it or somehow "autographs" it or attaches a copyright.
So, to clarify, yes, you are missing something. I see you've voted, so you must have forgotten.
boar
boar Regular Member • Posts: 119
I perfectly agree with you... Apart in DPR, in every challenges in which I took part,the most important thing was the anonymity (in order to avoid fraud during the voting).
Watermarks,for me,should not be allowed (even if,unfortunately,there are a lot of other methods to manipulate the voting)
(unknown member) Veteran Member • Posts: 3,214
If I watermark my entries with my name, it's not cheating...
It's called voting suicide!
 ConanFuji's gear list:ConanFuji's gear list
Fujifilm FinePix F500 EXR FinePix S1 Canon EOS 40D Sony Alpha NEX-5
Victor Engel
I can't forget that which I didn't learn. When I voted, I took pains to make sure the pictures were full frame Before I started voting.
one final comment. The watermark on this particular photo doesn't identify the photographer directly. It is just a URL. A viewer would have to either know the URL or type it in to make use of it.
Victor Engel
RaptorUK Veteran Member • Posts: 3,266
So it isn't CHEAting . . .   sorry but it is very, very simple.  It's also not against the DPReview Challenge rules . . .  but then nothing is because there aren't any DPReview Challenge rules . . . except for the Ts & Cs and according to Scott they are meaningless and can be ignored.
Take a look at my album . . . www.F1Album.com
 RaptorUK's gear list:RaptorUK's gear list
Fujifilm FinePix S2 Pro Nikon D1X Nikon D2X Nikon D3 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +7 more
The very reason I said it's inferred/implied. Given the fact that DPR keeps the submitter(s) anonymous during the submission and voting stages, it's implied that anonymity is a requirement and desired condition of the challenge. Once again, DPR doesn't come right out and say it but infers it.
Deleted pending purge Senior Member • Posts: 1,197
Since it seems that the competitive aspect of Challenges requires very precise rules to keep entries within the intended frames of particular Challenges, it is quite usual for the entrants to notice when something has not been specifically forbidden. If watermarks and/or other means of image identifying is not explicitly forbidden, it can then be regarded as allowed, right?
So in order to accept anonymous entries, this should be specified in a separate rule, carefully worded, in order to avoid misunderstandings. This, then, has to be controlled (by the host), and enforced (by DQ).
As to whether it is ethical to enter images with identifiable origin in anonymous competitions, that's another question. In all cases the outcome depends upon host's decision.
Fil
It is inferred,  I agree,  I have had the very same discussing with ConanFuji . . .  but running Challenges based on inference is not a good place to be at,  not for the Entrant, not for the Host and not for DPReview . . .   and what it means is that at the end of the day the benefit of doubt has to be given to the Entrant.
If something is made explicit there is no wriggle room and there is clarity for all to benefit from.
I know it would take thousands of Man hours and probably millions of $s to add some general DPReview Challenge rules . . .  but I think it just might be worth doing
We're that the case, then comments would not be allowed, but they are.
Victor Engel
It is most certainly is the case . . .  at one time the Camera details were shown before voting,  I think they were removed to try and prevent people voting by brand . . .  I don't know if this was also the case with Entrants IDs or if they were always hidden.
Comments are mostly posted by people other than the Entrant,  in an ideal world comments would be allowed but not shown until after voting is complete.
barb_s
barb_s Contributing Member • Posts: 701
Agree,  but I think DPR does not want to have generic rules that it can't enforce when photo's are uploaded, so I don't think they'll even state no watermarks. I do wish they would hide comments though. sometimes people reply and give away who they are but don't realize it.
Barb
 barb_s's gear list:barb_s's gear list
Panasonic Lumix DMC-ZS3 Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-6 Canon EOS 70D Nikon D500
DPR wouldn't need to enforce Generic rules,  that could be done by the Host and other DPR members via the Complain button.
DPR need to give Hosts the tools,   and part of the tool kit includes generic rules.
pixelless Contributing Member • Posts: 612
Some of us just don´t care about the "competition" side of challenges.
I´ve entered a couple challenges in the past, and just recently entered another one after a long period. I didn´t see anything on the rules about watermarks, so I entered a photo that has one. It´s just my normal workflow and I didn´t even think about the "cheating" thing. Hell, I don´t think any of my friends and family even know (or care!) that I visit this forum! Besides, I only enter challenges to see how others percieve my photos... nothing else.
Re: Some of us just don´t care about the "competition" side of challenges.
Exactly. Before the challenges even existed here, they were on pbase. The purpose of the challenges on pbase (at least the ones I participated in) was mainly to learn from each other. Comments on the photos was a huge beneficial part of the process. Sometimes a picture would be modified and re-submitted to the challenge in response to the posted comments. This is the way it should be, in my opinion.
Victor Engel
