X-trans RAW conversion blog post
Started Nov 7, 2012 | Discussions
David McGaughey
Senior MemberPosts: 2,246
Nov 7, 2012
http://www.dmcgaughey.com/2012/11/07/fuji-x-trans-raw-conversion/
Yes, I wrote this.
I discuss and compare Fuji's JPEG versus Adobe Camera Raw, Silkypix, and Raw Photo Processor converted RAW files in dealing with the "watercolor" effect.
I also have a comparison where you can see how the Fuji Provia JPEG compares to the three RAW converters.
I thought it'd be useful to have a comparison where all of the settings are explicitly described. If anyone's confused about what I did, let me know and I'll make it more clear.
boinkphoto
Contributing MemberPosts: 944Gear list
Re: X-trans RAW conversion blog post
In reply to David McGaughey, Nov 7, 2012
Seems a good write up. Should note that DxO also doesn't support the X-Trans and supposedly, though I haven't tried it, Helicon Filter 5 does.
 boinkphoto's gear list:boinkphoto's gear list
Fujifilm X-T1
Adamant
Contributing MemberPosts: 593
Great post and very helpful.  Have you tried converting in SilkyPix and importing the TIFF into LR for additional processing?  Several people have suggested this as the current "best practice" for dealing with problematic images.
baobob
Veteran MemberPosts: 6,960Gear list
Thx David for this contribution
I have excatly the same result I don't use RPP but Helicon with rather similar results
As you stated, it makes the WF not so simple
Your shots cleraly demonstrate the weaknessse of the Adibe products (LR, ACR, PS)
Fujifilm FinePix X100 Sony RX100 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
Randy Benter
Veteran MemberPosts: 3,113Gear list
In reply to boinkphoto, Nov 7, 2012
To be clear....
Helicon Filter 5 does not natively support X-Trans raw files.
Helicon Filter 5 uses Adobe DNG converter to convert X-Trans raw files, then processes the DNG.
You could convert your X-Trans file to DNG using Adobe's converter, then open that DNG in any software for the same level of support offered by Helicon Filter 5.
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Nikon D7200 Fujifilm X-T10 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
baobob
In reply to Randy Benter, Nov 7, 2012
To be clear....
Not excatly: you get the choice between DNG and DCRAW
Using DCRAW gives much better results than DNG
abelits
Contributing MemberPosts: 677Gear list
In reply to baobob, Nov 8, 2012
baobob wrote:
To be clear....
But what is the point of that? If you have to use two pieces of software, why not just use Silkypix with "proper" conversion algorithm instead of DCRaw with its "zipper" artifact that then the rest of software is trying to filter out?
I understand that for some images DCRaw produces better results (very sharp image), and I guess, some may like to combine DCRaw-converted imaged with OOC or Silkypix JPEGs, but those have to be exceptional situations, not the rule.
Maybe it's all specific to the images that are scaled down to 1/3 or lower resolution?
 abelits's gear list:abelits's gear list
Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R APD +11 more
framus
Contributing MemberPosts: 847Gear list
In reply to David McGaughey, Nov 8, 2012
Thanks this is very good.
For myself I'm praying that Adobe improves their RAW converter.
I'm encountering the WC effect only rarely and don't want to complicate my workflow.
I'm shooting RAW & jpeg and having a fine old time.
-Framus
 framus's gear list:framus's gear list
Fujifilm X100S Fujifilm X-T1
Chris Dodkin
Veteran MemberPosts: 6,575Gear list
David - why would you believe that the default and totally generic settings in ACR would be suitable for converting an X-Pro1 RAF file?
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
David McGaughey
Your way is only a little better
In reply to Chris Dodkin, Nov 8, 2012
Chris@1D-Images.com
Your approach (53 amount / 1.7 radius, right?) is only slightly better. ACR just can't handle detailed greens.
David McGaughey
In reply to Adamant, Nov 8, 2012
I wrote (nearly) exactly that in the blog post. Just substitute "Photoshop" for "LR"
David McGaughey
Added some info to the post
Chris@1D-Images.com
I forgot to put the settings in for the last conversion. I tried to optimize the "sharpness" for each workflow. I actually used a wider radius for the ACR image, which I think is one of the things you recommend.
Chris Dodkin
Re: Added some info to the post
That's a start, but you also need to adjust other components such as black levels and especially clarity in order to get the most from the X-Pro1 raw files.
It's a complex subject, and there's no preset at this time, other than in-camera
The lack of a preset workflow for X-Pro1 raw files is a major component of peoples 'issues' with the file post processing
Chris@1D-Images.com
David McGaughey
We disagree
Chris@1D-Images.com
ACR sucks for detailed green subjects. You can see in the samples I used - it's almost as if ACR is blurring the color information. Leaves and needles become monotone. Tweaking black point and clarity won't help that.
I believe the WC issue is overblown, but you aren't helping the "cause" by claiming it doesn't exist and posting down-sized images (though beautiful) of non-foliage scenes as proof.
Chris Dodkin
Re: We disagree
David, you illustrated my point perfectly in your blog - you posted a blurred image from ACR, and led people to believe that the issue was purely to do with X-Trans conversion. Even though you'd only done the conversion using the generic ACR settings...
I have never said that the issue doesn't exist - again, you're over simplifying the situation in order to try and make a point.
I have clearly said that this has been a non issue for me, and that I believe that many people have not learned to get the most out of the myriad PP options in ACR.
Your jibe about down sized images is rather lame - but I understand that it's more of an emotional response, based on your posts here.
Chris@1D-Images.com
abelits
Re: We disagree
Actually it's very much valid, because if you scale X-Trans sensor to 1/3 of its size, it becomes an equivalent of Bayer with extra subpixels.
David McGaughey
ANNOUNCING THE RAF PROCESSING CHALLENGE
I've posted the two RAF files on the blog. If you think you can do better (Mr. Dodkin?) take a crack and send me the full-sized JPEG. I'll do a follow-up blog post if there's any interest.
David McGaughey
I disagree
I said over and over that ACR blows and that the Fuji in-camera conversion as well as two different RAW converters did a fine job. How could you construe that as blaming X-Trans for being "blurry?"
Anyways, since you are implying I can't use ACR (which may be true), check out my "RAF Processing Challenge" in the post. It's your chance to show everyone what a chump I am.
Chris Dodkin
Re: I disagree
X-Trans conversion - that's a conversion from X-Trans, not just the X-Trans
You're jumping down my throat having mis-read the post
Chris@1D-Images.com
David McGaughey
Re: I disagree
Yep. Egg on my face (not being sarcastic).
I do believe that I'm fairly demonstrating how ACR works.
