X10 Filter Solutions
Started Nov 4, 2012 | Discussions
widick Forum Member • Posts: 80
1.) Use dedicated Fujifilm filter adapter/hood with 52mm filters. Drawback:Slots in adapter ring limit the effectiveness of a UV filter as a lens protector.
Note: The filter adapter/hood will fit the dedicated Fujifilm x10 camera case only without                the hood attached.
2.) Use Marumi 40 mm filters.  Drawbacks: While these work, the selection appears to be limited, I question how good they are, and they are an odd size which probably won't fit any other lens you may have.
3.} Use and S&W CO 40-46 mm adapter ring and standard 46mm filters,
Note: The adapter plus filter will fit the dedicated Fujifilm x10 camera case,.
I could not detect any discernible additional vignetting using any of the above approaches.  I'm going with number 3.) because I already have a number of 46mm filters which I can use on the X10 in addition to the lenses for which they were purchased.
Fujifilm X10
bixgomez New Member • Posts: 4
Re: X10 Filter Solutions
where can I find one of these rings?  I've done a search for "S&W" and can't find it anywhere...  Thanks!
Ah, here it is!
http://www.amazon.com/HeavyStar-Dedicated-Metal-Stepup-40mm-46mm/dp/B0084TM1PG/
Just ordered one... fingers crossed it works as well as its single reviewer says it does!
Here is a guide to doing this:
http://www.fujixseries.com/discussion/1514/fuji-x10-filter-here-is-the-solution-i-have-it-and-it-works-perfectly.../p1
I have the 40-46 on order... I'll report my findings...
Karel Osten Contributing Member • Posts: 690
Thanks for the post, I'll be interested to see how you go. I have a similar issue with the Fuji adapter but using it for a CPL. The slots let in light behind the filter and you can't rotate the filter with the lens hood attached. Seems a a strange (silly?) design all round.
Karel
 Karel Osten's gear list:Karel Osten's gear list
Olympus Stylus XZ-10 Konica Minolta Maxxum 5D Nikon D7000 Sony SLT-A57 Olympus OM-D E-M10
