D800 in Canada - went though 4 units before found a good one
Started Nov 4, 2012 | Discussions
KG2002 Regular Member • Posts: 334
Just to report that good working D800s do come to Canada once in a while after all. I almost gave up when I had to go through 3 unit all with the same Left AF issue. Old batch, new batch - didn't matter. Finally found a unit with 50076xx S/N which works great. I did see people reporting here same S/N as defective so I suppose the batch is irrelevant or S/N is not representing when the unit was manufactured.
Interesting fact - my local dealer has contacted Nikon after I returned 3 units and as expected Nikon was in denial the issue exists. Nikon also has directed my dealer not to exchange cameras any longer but rather to send to Nikon for under warrant repair. We've settled on refund as I refused to accept a defective product and had a better luck at different store. I actually have a feeling they are not happy with Nikon position either.
Nikon D800
(unknown member) Senior Member • Posts: 1,053
Re: D800 in Canada - went though 4 units before found a good one
I'm also in Canada and recently purchased a D800E with a serial number in the 5002xxx range that appears to be within spec.
 The Andy G's gear list:The Andy G's gear list
Nikon D800E Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 85mm f/1.8D Nikon AF-S Nikkor 35mm f/1.4G
marinaside Regular Member • Posts: 129
What store did you order from?
 marinaside's gear list:marinaside's gear list
Nikon D800 Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +2 more
JBP Senior Member • Posts: 1,014
From what I have heard the D800E's were not affected by the left focus issue, I stand to be corrected  though.
35 to 4 x 5 - NPS Member
 JBP's gear list:JBP's gear list
Nikon D810
kcyuen New Member • Posts: 11
Thanks for the update. I now wonder if it'll be easier to find a good D800e than a good D800. Can you let us know which store you got that from at the end?
KG2002 OP Regular Member • Posts: 334
The 3 deffective ones were from Henry's.Excellent service by the way. Not their fault the cameras had issues. Got the working one from Future Shop. Surprisingly.
PhotoKaz
PhotoKaz Contributing Member • Posts: 513
Maybe you forgot to set it to metric mode?  Camera doesn't measure distance to subject properly otherwise...
 PhotoKaz's gear list:PhotoKaz's gear list
Sony RX100 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
Prairie Pal Senior Member • Posts: 2,462
I feel sorry for the dealers, especially the smaller franchises.  They'e stuck between a rock and trying to keep loyal customers from being ripped off.
VINAPIX Junior Member • Posts: 39
I had a similar experience with a vendor in Mississauga. The last one I got from them has serial number 5010XXX and it too have the left focus aligment issue. I don't think there is a higher serial number around Toronto. All the one at Futureshop has serial number in the 5007XXX range. I have to say the customer service at this Mississauga store is top notch. They returned my money after trying hard to find me a good one.
I noticed all the D800 boxes at Future Shop are open. You can tell the box corners are all worn and the plastic wrap inside is all wrinkled.
There is a Consumer Protection Act in Ontario that prevent stores from selling defective products. Like KG2002 said, if they tell you to send it to Nikon for adjustment then the product is considered defective.
