Macro lens suggestions for FZ200 ... HELP
Started Nov 2, 2012 | Discussions
leerob
leerob Senior Member • Posts: 1,389
I need to buy excellent macro lens. Is B+W close-up lens any good?
I'm hoping for !:1 ratio or better, if possible.
Please help.
Thanks!
 leerob's gear list:leerob's gear list
Leica X Vario Leica C Leica D-Lux (Typ 109) Nikon D7100 Nikon D750 +1 more
Panasonic Lumix DMC-FZ200
TanukiSan
TanukiSan Regular Member • Posts: 193
Re: Macro lens suggestions for FZ200 ... HELP
 TanukiSan's gear list:TanukiSan's gear list
Panasonic Lumix DMC-TZ1 Panasonic Lumix DMC-GM1
privateman
privateman Contributing Member • Posts: 702
Please help.
Thanks!
You have started several macro threads in the last few weeks and got excellent answers, including myssvictoria's post http://forums.dpreview.com/forums/post/50067062. The most popular lenses have been discussed here, except your B+W close-up lens. I would only consider it if it were an achromat.
I have shown some of my own macro shots here: http://forums.dpreview.com/forums/post/50054581. These shots correspond to your desired focal length of up to 1.5'.
Or do you want to be this close? Also Olympus, A-LifeSize macro.
 privateman's gear list:privateman's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-LX7
leerob
leerob OP Senior Member • Posts: 1,389
I have chance to buy at reasonable price Leica Elpro VIa or VIIa, but don't know, if it's any good or what diameter (tread size). Comments.
Do I have to mount close-up lens on LA7? If so, then I need 55mm thread, right?
Thanks!
leerob
Re: Macro lens suggestions for FZ200 ... HELP Common guys
privateman
No, macro lenses can be mounted directly onto the FZ200 lens, which has a 52mm thread. Depending on the macro lens you may need an appropriate step adapter.
Balifly
Balifly Regular Member • Posts: 170
Which new Macro lens would you recommend for the FZ200 in the 52mm size?
I have an old set of Prisma +1, +2, and +3  (52mm) filters.
Not sure if they would work with the FZ200 though.
 Balifly's gear list:Balifly's gear list
Donald B
Donald B Veteran Member • Posts: 5,400
without a second look the canon 500d is amazing screw it straight to the lens.
cheers don
Balifly
Much thanks for the recommendation, found it!     (^_^)
leerob
Thanks!
I wasn't sure, because Panasonic recommends LA7 and I thought why, so better to double check.
BTW tomorrow I should get my polarizer and step-up ring for DC58A, so I'll try it out soon.
I guess I'm not to good at improvising to fit stuff on my camera.
leerob
okay, bought 500D from B&H. Should have it on 7TH
RevsCam
RevsCam Forum Member • Posts: 83
Many years ago I bought one of those simple +1, +2, +3 close-up lens sets. That was back in my analogue SLR days in high school, and I couldn't afford anything else. Made by Coastar.
I dug them out of my "old camera" drawer and tried them on my FZ150. I was disappointed by the results. Too much obvious CA, even on the +1 lens. In my SLR days I was shooting Tri-X and Plus-X almost exclusively, so CA wasn't such a big deal.
Since you have them, give them a try.
If I were going to buy a macro lens for the FZ150 I'd look first at the Raynox DCR-150.
 RevsCam's gear list:RevsCam's gear list
Olympus C-7000 Zoom Panasonic Lumix DMC-FZ150
Balifly
Thanks for the reply!
What is "CA", I am not familiar with the abbreviation.
I have found the Raynox DCR-150, it is about the same price as the  Canon 500D Close-up Lens.
There should be some previous forum postings comparing the two lenses.
The FZ200 is relatively new to me, I have only had it for about six weeks.
It has been great as a travel camera on my recent trip to Kuta, Bali and Shanghai China.
Too bad I did not have a close up lens for the tropical flowers, next time.
RevsCam
Chromatic Abberration. It means not all colors focus at exactly the same point. It results in a slight color fringing around high contrast boundaries. Usually blue on one side, red on the other.
I think for flowers, you'd probably be fine without a macro lens. Just use full telephoto and set the focusing to macro. Sure, you will be about 2 meters away but it works well. There's another recent thread called "FZ150 First butterfly" that would give you a good example. The 200 should be about the same.
Balifly
Thanks again, I will  go  do some reading of the "Butterfly" post.
Danninvan New Member • Posts: 2
I have been asking a lot of people including professionals about this without getting an answer yet. Hopefully someone here can shed a little light. What is the difference between mounting a 55mm closeup lens on the LA7 adapter (in which case this lens remains stationary while the main lens moves in and out behind it) and mounting a 52mm closeup lens on the lens itself and consequently the closeup lens moves with the main lens? Is there a difference in quality or technique? I would appreciate any comments regarding this. Thanks
sherman_levine
sherman_levine Forum Pro • Posts: 10,037
Mounting the lens on the LA7 can give you some vignetting as you back off the zoom, but that's rarely an issue because you'll generally be in the high zoom range.
The closeup lens is a "fixed distance to subject" lens - so if you mount the lens on the LA7, you can change zoom without moving the camera, and the subject will stay in focus.  If you mount the lens on the camera itself, then you'll need to move the camera when you change the zoom, which can be a nuisance
I know of no difference in image quality
Sherm
 sherman_levine's gear list:sherman_levine's gear list
Panasonic Lumix DMC-FZ1000 Nikon Coolpix P900
Thanks very much for that Sherm.
Ric Cheng Regular Member • Posts: 223
Raynox 150 (I have this, very good)
Raynox 250 (I don't have this, but I have seen many nice macro photos)
aVolanche Veteran Member • Posts: 3,637
In addition to what Sherm said about the tube...it acts as a nice "protector" for the lens (against bumps and dirt/ dust).
I have a Raynox 250 and the Kiwi tube (Ebay-model LA-55F200). I added a 55mm-43mm step down ring to mount the Raynox to the tube. Also added a 49mm pinch-style lens cap to the Raynox. This is a nice combination.
 aVolanche's gear list:aVolanche's gear list
Olympus OM-D E-M10 Nikon D810 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +1 more
