Day 2: A99 vs A900 - high ISO
Started Nov 2, 2012 | Discussions
Amateur Sony Shooter
Veteran MemberPosts: 5,415Gear list
Nov 2, 2012
It's a well known secrete that A900 can handle decent high ISO noise (up to 3200) if you shoot RAW. One of the biggest improvement A99 has over A900 is the better noise handling. Just how much better? I did some unscientific test and to my eyes, it's about 1-1.5 stop better. It might not sound much but in real life that means you can more than double shutter speed, extremely useful for long lens users. Here are the test images and various 100% crop (straight from RAW without any NR). Identical setting for both cameras, full manual exposure.
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +6 more
Sony SLT-A99
Bart7D
Veteran MemberPosts: 4,148Gear list
Re: Day 2: A99 vs A900 - high ISO
In reply to Amateur Sony Shooter, Nov 2, 2012
For what I see in these pictures the noise is handled better on the A99, but the fine detail and contrast is better in the A900 series.
Thanks for posting your test images here!
Bart
 Bart7D's gear list:Bart7D's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 Sony a77 II +19 more
Marco Cinnirella
Veteran MemberPosts: 5,088Gear list
In reply to Bart7D, Nov 2, 2012
Bart
I agree - looks like more/stronger on-chip NR going on with the a99?
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Fujifilm FinePix X100 Sony SLT-A77 Olympus OM-D E-M5 Sony SLT-A99 Fujifilm X-T1 +4 more
In reply to Marco Cinnirella, Nov 2, 2012
I don't think A99 has NR applied to RAW files (unlike Pentax). Also the grains are finer, less colour noise too.
Marco Cinnirella
I thought almost all current CMOS sensors have some on-chip NR applied to raw but I am willing to stan corrected if I am wrong...
philbot
Contributing MemberPosts: 846
The A900's could probably look a bit better if you worked on the contrast of the noise,
But clearly, even if you look at the details, it's about a Stop difference in some of the underlying detail.
Considering the SLT light loss, that's quite impressive.
Would you be able to upload say the A900 ISO6400 RAW? I'd like to see if the noise profile could be subdued without losing much detail..?
Ralf B
Veteran MemberPosts: 7,528Gear list
That is one fine Whisky...
... in your selection of test targets!
Thanks for sharing this comparison, as an a900 owner this is quite interesting.
But that whisky - wow:
Ardbeg Supernova
Ralf
www.ralfralph.smugmug.com
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +13 more
newday
Regular MemberPosts: 173Gear list
Re: That is one fine Whisky...
In reply to Ralf B, Nov 2, 2012
Thank you for sharing these. I have loads of Sony/Minolta gear, but I am seriously considering to get a Nikon(600 or 800) because I am so tired of the bad high ISO performance.
The A99 looks interesting, I really like the swivel screen for video and studio work. But I need a camera with good high ISO performance.
The other thing missing is a built in Intervalometer for time-lapse. But maybe they could add this with a software update.
Bart7D
Try to stay on topic, Ralf! Keep clear, see clear...
(The Ardbeg is out of stock anyway...)
Bart
In reply to philbot, Nov 2, 2012
I don't know how to upload RAW file to DPR gallery. These are crops are considered "RAW" quality (strait RAW to jpeg conversion, no modification, no NR).
In reply to newday, Nov 2, 2012
I would say A99 is very similar to D600 interms of noise handling. There are two church interior RAW image posted online with ISO 6400 from both cameras, I can easily make them look the same.
unknown member
(unknown member)
Looks interesting.
Any chance we could see the RAW files?
digitalshooter
Forum ProPosts: 19,604Gear list
Some one go shooot real life high ISo like a school play or football (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Bart
Off topic: actually you can get both 1999 and 2000 release from London Whisky Exchange. 1999 release is suppose to be better.
remylebeau
Regular MemberPosts: 293Gear list
Nice comparisons thanks for the doing the testing.
 remylebeau's gear list:remylebeau's gear list
Nikon D3 Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tokina AT-X 17-35mm f/4 Pro FX +9 more
In reply to JohnBee, Nov 2, 2012
johnbee wrote:
Looks interesting.
If I can figure out how to upload RAW file to DPR I would. These crops are pretty much as "authentic" as RAW since all I did was strait conversion no NR or any other modification.
philbot
johnbee wrote:
Looks interesting.
Yeah, probably too much hassle..  It's just I've found the 'straight' conversions can differ quite a bit between camera's, it looks like the sharpness is way higher or something is causing much higher contrast noise, I'm sure it could be reduced.
But it's not worth the hassle, the detail under the noise is clearly less, and that's the important thing here.. I'm still shocked at the leap in performance Sony have made with their FF sensor.
unknown member
(unknown member)
johnbee wrote:
Looks interesting.
https://www.dropbox.com/
http://www.filedropper.com/
http://wikisend.com/
There is also the option of uploading the files to an FTP server if you are familiar with this.
That being said, there seem to be variances between the samples in terms of processing and shooting. ie, the A99 image seems soft or perhaps OOF. Which is not consistent with the comparison images on Imaging Resource. That being said, at this point, I'd say the results depend greatly on OOC NR and processing which makes it very hard to peer through and assess the overall IQ of each sensor.
tex
tex
Veteran MemberPosts: 6,774Gear list
Mmmmm, tasty whisky. A900 not too bad! /nt
tex_andrews
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Sony Alpha 7R Pentax 645Z Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm 1:3.5 ED AS UMC +15 more
Two action shots
In reply to Amateur Sony Shooter, Nov 3, 2012
Not super high ISO (only 1600) but still showing fine grain even after sharpening applied.
