Does Nikon Flashes do TTL on Xpro 1?
Started Oct 31, 2012 | Discussions
JMaldonado01 Regular Member • Posts: 316
JMG
 JMaldonado01's gear list:JMaldonado01's gear list
Nikon D50 Nikon D200 Olympus PEN E-PL2 +1 more
a l b e r t Senior Member • Posts: 1,434
Re: Does Nikon Flashes do TTL on Xpro 1?
No.  Only A mode works.
 a l b e r t's gear list:a l b e r t's gear list
Fujifilm FinePix F31fd Fujifilm FinePix X100 Fujifilm X10 Fujifilm X-E2 Fujifilm XF 35mm F1.4 R +7 more
2482 Regular Member • Posts: 197
so does it have to be on manual the nikon flash? Any kind of automation or ttl?
www.dougiewallace.com
 2482's gear list:2482's gear list
Fujifilm X100S Sony RX100 II Sony Cyber-shot DSC-RX10
M4cr0s
M4cr0s Contributing Member • Posts: 955
Only thing that works with X-Pro1 and the X100 and Nikon speedlights is full manual. At least it's that way with my SB-600, 900 and 910s. Only the Fujifilm units will get TTL. However, curiously enough some of the Canon extension cords (OC-3) have the same pinout as the Fujifilm units, thus giving TTL.
Mac
Captain Tom L Forum Member • Posts: 71
I had used SB600 on the XPro1. Works in full manual mode with a caveat. When you snap a shot while the flash is in sleep mode, the flash does not fire. So you have to "wake" it up before the shot.
alexzn
alexzn Senior Member • Posts: 1,714
Anyone was able to use Canon 580II in Auto mode with XPro-1?
A related question: has anyone been able to use the Canon 580II flash in Auto (thyristor) mode with XPro-1.  I am worried what the similar pinout configuration between Canon and Fuji would do to the camera when the wrong brand flash is mounted.  Do you need to use a dumb shoe to make it work?
