Question: Low light performance comparison between the SX40HS and the SX50HS
Started Oct 30, 2012 | Questions
Laif New Member • Posts: 7
I just received the SX40 from Amazon, today, and am seriously thinking about returning it in favor of the SX50.
The only reservation I really have, is the higher minimum aperature of the SX50. Some reviewers on Amazon agree that compared to the SX40, the SX50 is much harder to use in low light situations. One even goes so far as to say that because of this, the camera really isn't a good all-around camera, but should only be considered a specialty tool for birders and other wildlife photographers.
http://www.amazon.com/review/R39AVZ1B09VG8Q/
Can anyone here confirm or deny this?
Dansby Junior Member • Posts: 28
Re: Question: Low light performance comparison between the SX40HS and the SX50HS
I've had my sx50 for a week ,I think it does a decent job.
garage party
ViragSharma Junior Member • Posts: 44
On paper it seems low light performance is not going to be good. But if you see pic from both cam , then you hardly able to make difference. also chekc following thread
http://forums.dpreview.com/forums/post/50126881
Panet Regular Member • Posts: 114
I think that the difference is more conversational than practical.
At wide angle maximum, SX40 has f/2.8 and SX50 f/3.4, but how often does one use f/2.8 in this focal distance?
At 40mm., SX40 has f/4.5 x SX50 has f/3.4.
At 200mm, SX40 has f/5, SX50 F/5.6.
At 525mm. SX40 has f/5.8 up to 840mm, versus SX50 f/5.6 way up to 950mm
A tie, I would say...
Laif OP New Member • Posts: 7
Thanks for your help!
Are you using the camera's flash, there - or just the indoor lighting?
just the garage light
RDCollins Contributing Member • Posts: 936
Your measurements at 40mm don't quite comport with those in this thread:
http://forums.dpreview.com/forums/thread/3288973
Doug Collins
Hermosa Beach, California
