Why JPEG is not an option for me.
Started Oct 26, 2012 | Discussions
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 6,502
Hi,
Today I have post processed some shots I took over one year ago. The reason is that I have bought a book that deals with post processing in LR and I also downloaded a film emulation plug in.
I wasn't very happy with the images before because the looked rather flat ( out of camera ) but with the new post processing I really like them.
That's why I hope that Fuji and Adobe work together to find a solution to support their X-Trans sensor RAW files. As soon as there is RAW support for the X-E1 I will get it.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Sony Alpha 7R Fujifilm X-T1 Sony a6000 +13 more
Fujifilm X-E1
Joachim Gerstl
Joachim Gerstl OP Veteran Member • Posts: 6,502
Re: Why JPEG is not an option for me.
Wow. I was able to edit my post! Maybe the new forum style isn't that bad at all.
coaltrain Regular Member • Posts: 265
Just curious - you mention Adobe getting together with Fuji about the raw files.
Does Adobe have the only raw editor available?
~Stan~
 coaltrain's gear list:coaltrain's gear list
Panasonic Lumix DMC-LX5 Pentax K-30 Pentax K-5 IIs Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye Pentax smc DA 12-24mm F4.0 ED AL (IF) +7 more
threeOh Regular Member • Posts: 325
Only you can make that decision. For me a better book was how to meter correctly. After that all you need is a good jpeg engine, which the Fuji has. Shooting the X100, I've gone from 90% raw to 80-90% jpeg and will never go back.  My Nikon kit is up for sale.
Vic Chapman Veteran Member • Posts: 4,241
Re: Fuji and Adobe raw - and Apple.
http://forums.dpreview.com/forums/thread/3286994
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +11 more
Vic
Spike Milligan
Thanks, knew about it. I believe it will take a while for XTrans to settle down. Years, not weeks. None of the tools are perfect. However, the Fuji's have great metering, an excellent jpeg engine and SilkyPix works when Adobe does not.  For many, this is not about IQ, it's about not changing software.  How many use NIK for Nikon?  Not all that many yet it renders better.
~Stan~
No, there's RPP, SilkyPix and Adobe in the Mac side. I believe there are a few more in the Win side. I'm an Aperture user and the XE-1 caused me to look at the 3 Mac choices. They all have their pros and cons. Where I'm at now is either Adobe Bridge and ACR with SilkyPix available when ACR just does not get me there with the few xp1 raf files I have to play with. Or Lightroom, again with SilkyPix available.
SilkyPix is actually rather nice. Runs fine on my aging iMac. A cluttered modular interface but it's simple use learn, simple to use and actually does very nice editing. The issues with ACR are supposedly color bleeding and smearing on foilege. I have some xp1 files I'm playing with until the xe arrives with some highly intricate lines of color running though a darker background. Absolutely no color bleeding in either Adobe or SilkyPix. I'm not a landscape photographer. While I would noteither any of the apps crisp, they are good enough for the little foilege that gets into my shots.
~Stan~
Thanks for you indepth reply. At first when I wrote my original post, I was kind of being facetious in a way since I get kind of tired of hearing that Lightroom is the only game in town for image editing. I don't hear that so much here in the Fuji sections as much as in others.
I shoot 100% raw with my Pentax gear with great results and not using Lightroom like 99% of the people. While I agree when it was said above that I am so impressed with the Fuji jpeg engine, and that I can't process raw with my standard software (Acdsee Pro6, Capture One, DxO) that I've pretty much decided to just use my x10 and x-s1 as jpeg shooters. The Silkypix software isn't that bad at all if I want to process some raw files - actually I use the Silkypix software for my Pentax cameras quite a bit.
Thanks for sharing your Fuji raw thoughts. Meanwhile I have been tweaking my in camera jpeg settings and just run with that for now.
~Stan~
57even Senior Member • Posts: 9,476
You can edit JPEGs in LR as well you know.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
nawknai Senior Member • Posts: 1,042
I don't get it either.
He doesn't think that image is achievable when shooting and editing JPEGs?   He could also change the in-camera settings to get the OOC JPEGs closer to what he wants.
 nawknai's gear list:nawknai's gear list
Fujifilm FinePix X100 Fujifilm X-Pro1 +1 more
(unknown member) Regular Member • Posts: 362
I apply film emulations to jpegs all the time in Lightroom. Unless you have the end results from both the RAW and jpeg to compare I really don't get this thread. Nice effect though
Jonathan Robson Contributing Member • Posts: 846
Nice shots. What film emulation plugin did you go with, how do you like it?
Cheers
Jonathan
'When the seagulls follow the trawler, it's because they think sardines will be thrown in
to the sea.' - Eric Cantona
http://jrobfoto.com
 Jonathan Robson's gear list:Jonathan Robson's gear list
Sony Alpha 7R Sony a6000 Sigma 15mm F2.8 EX DG Diagonal Fisheye Sigma 150mm F2.8 EX DG Macro HSM Canon TS-E 24mm f/3.5L II +8 more
Joachim Gerstl
Of course not but since Lightroom came out I use it. I love the interface. I'm not willing to change my workflow just because of a camera.
Joachim Gerstl
Sorry if I wasn't clear enough. It's not about correcting exposure it's about color and tones. I have no problem to expose a shot correctly but I love the flexibility of RAW files to create special looks.
Joachim Gerstl
It's great to see how effective non disclosure agreements are.
But the step is really necessary for Fuji to expand the customer base for their brilliant X-Series.
Joachim Gerstl
Ok. I should have posted the original file too. I will do that when I'm back home.
My point was that I can post process an image I took years ago with todays RAW converter and take advantage of the progress of the software.
There is a difference in handling too. You can't edit an 8 bit file the way you do with a RAW file. Just look at the histogram after the changes. I agree that in camera JPEGs are getting better but flexibility means RAW.
Joachim Gerstl
Thank you. It's Ektachrome and it's for free. It needs to be adapted for portraits because it is far too contrasty but I like the color.
I consider to get the VCO film packs but haven't found a try out version yet.
