Auto ISO after firmware on NEX 7
Started Oct 23, 2012 | Discussions
dannylaw
New MemberPosts: 16
Oct 23, 2012
Does anyone know if the auto ISO in Intelligent, Apeture, Shutter, and Program is still limited to 1600?  Is the Auto ISO on the NEX 6 the same, or is it higher?
Sony Alpha NEX-7
ka-spot
Regular MemberPosts: 131
Re: Auto ISO after firmware on NEX 7
In reply to dannylaw, Oct 23, 2012
on my NEX 7 in A mode is 1600, so I assume that is still 1600 in all modes. just try in your room at f8 and you'll see its 1600
tesilab
Senior MemberPosts: 2,477Gear list
The feature changes of the upgrade are comprehensively listed. Broadening the auto-iso range is not something Sony would do without mentioning it in the release notes.
 tesilab's gear list:tesilab's gear list
Sony RX1R II Sony Alpha NEX-5 Olympus Air Panasonic Lumix DMC-GX8 Panasonic Leica D Summilux Asph 25mm F1.4 +13 more
dannylaw
New MemberPosts: 16
Thanks for the info.  Do we know if the NEX 6 is limited to 1600 auto ISO in the modes mentioned above?
dannylaw
New MemberPosts: 16
In reply to dannylaw, Oct 24, 2012
Can anyone that has the NEX 6 check to see wht is the max auto ISO? Thanks
Daniel
DuncanDovovan
Senior MemberPosts: 1,277
In reply to tesilab, Oct 24, 2012
It is still 1600. If you use AEB with AUTO-ISO, it actually selects different ISOs for the shots. 1600 is the highest it uses to keep exposure of the bright shots acceptable.
I'm a peaceful person looking for clarity and harmony and willing to help. If you believe my post had the intention to harm you in some way, you are probably wrong. =;-) Please verify first before assuming something bad happened to you. I can be a bit too brief at times. =;-)
dansenor1
Regular MemberPosts: 141Gear list
I'm actually reading the user's manual and  nex6's auto iso goes up to 3200
kinglau711
Forum MemberPosts: 50Gear list
It's 3200 ISO on mine.
DuncanDovovan
In reply to kinglau711, Oct 24, 2012
"mine" as in "my NEX-6"?
I just tested in A mode on the NEX-7 and it shoots at ISO1600 max in auto.
kinglau711
In reply to DuncanDovovan, Oct 24, 2012
Yes, but not better than the ergonomic of the NEX-7 in my opinion.
dannylaw
New MemberPosts: 16
That seems odd, NEX 7 auto ISO is 1600 and NEX 6 auto ISO is 3200. That's a stop higher, do we know why?  More importantly, what happens if you shot in Apeture priority and the scene (indoor) calls for ISO between 1600-3200? I did test out the NEX 7 about six months ago and could not commit.  However not having it now, I cannot remember what it would do in such situations.  Did it slow the shutter below the built in benchmarks or did it just under expose the frame, please help.  I'm asking because I placed an order on the NEX 6 on release, but the firmware update has me thinking second thoughts.  I'm an original NEX 5 shooter so either is a good upgrade for me, but I'm a family shooter, and indoor-well I just want the best of the two anyway. Thanks
Daniel
tesilab
Daniel
Sure we know why. The NEX-7 has a higher megapixel count. Pixel peeping at 3200 on the NEX-7 makes people unhappy. Not so with all the other NEXes of the last two generations, whose 100% crops look fantastic.
While the high iso damage is actual minimal *for the same size output*, 100% crop comparisons suffer. That is why Sony limited it 1600. Safer than having customers complaining about the crops.  If they would just trust us to set our on maximum iso (and min shutter speed--please!), they could just default it to 1600.
dannylaw
New MemberPosts: 16
In reply to tesilab, Oct 28, 2012
Still trying to figure this out. From the forum input NEX 7 auto ISO maximum is 1600, and NEX 6 auto ISO maximum is 3200.  So my question is what happens when you compose a shot is a PASM mode and the exposure requires something more than ISO 1600. Obviously, things give a little, such as the Apeture opening into its highest setting, or the shutter slowing down to a lowest limit (don't remember, but maybe lens specific) but what does it do after that, if anything?
For example, lets say the lens minimum f stop is 3.5 and the metering requires ISO 3200. Will the camera keep reducing the shutter until you reach 1600? Is there a lower limit setting on shutter speed?  Alternately, in Shutter mode same situation, whaah happens, because the Apeture will not go any wider?
please help if you know the answers.
Daniel
tesilab
In reply to dannylaw, Oct 29, 2012
DuncanDovovan
Daniel
Yes.
In A mode, the strategy with AUTO-ISO is to maintain acceptable shutter speeds by adjusting ISO first up to the point where 1600 has been reached. After that, the camera has to reduce the shutter speed to get a proper exposure.
There is no minimum shutter speed. Would it have one, you would have under exposed pictures at a certain point.
So either you are in A mode and check the shutter it selects with every shot or you go to M mode and select a shutter and minimum aperture and then use ISO to correctly expose.
tesilab
In reply to DuncanDovovan, Oct 29, 2012
Oops, I made an error in my post above. There is an applicable minimum shutter speed based on the lens for some situations, that isn't applicable to this case.
In aperture priority, with insufficient light, the shutter will be set to as low as 5 seconds, but aparently no lower.
k0mit
Junior MemberPosts: 28Gear list
In reply to dannylaw, Nov 3, 2012
Daniel
Daniel, the camera's first priority is "exposure", so it will continue to lower the shutter speed in an attempt to properly expose the image. Sony has to give us some credit for taking the time to notice when this shutter speed gets low and do something about it. Either, brace the camera or put it on a tripod, or manually increase the ISO to something that will allow a fast enough shutter speed to prevent movement blur in your image. Another option would be to go to Manual, Shutter Priority, Program, or iAuto.
Mike
 k0mit's gear list:k0mit's gear list
Panasonic Lumix DMC-LX100 Olympus OM-D E-M10 Olympus Zuiko Digital 35mm 1:3.5 Macro Voigtlander 40mm F1.4 Nokton Classic Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
DimitriDV
Regular MemberPosts: 361
In reply to dansenor1, Nov 3, 2012
Just confirming (just tested) that it goes till 3200 on my Nex-6
