Updated Third Party RAW of X-Trans
Started 8 months ago | Discussions
Maxster
New MemberPosts: 8
8 months ago
Just came back from D-Clic photo show in Montreal and had the chance to talk with Billy from Fuji Guys. He asked me if I was happy with my X-Pro1 and I said yes, very happy BUT would like Adobe and others to better support it (or at all in the case of Aperture...). I expected him to play it safe but he actually acknowledged the problem right away and told me that they recently signed a non-disclosure agreement with both Adobe and Apple and provided them with specs for supporting the X-Trans sensor !
He said he is also pushing strong with Fuji to add support for TIFF in the camera so that could be another good thing for some.
Lets hope this leads to progress...
TAGGED WITH:
Tack007
New MemberPosts: 12
Re: Updated Third Party RAW of X-Trans
In reply to Maxster, 8 months ago
Hej, if this is true, I will buy bottle of Champain and celebrate
CYF
CYF
Junior MemberPosts: 29
In reply to Tack007, 8 months ago
+1!
awelch100
Regular MemberPosts: 194
I will be overjoyed if this is true
Canon 5D MkII, 24-70 f/2.8, Sigma 50 f/1.4, Canon 85 f/1.8, etc, etc...
Greg999
Forum MemberPosts: 98
LZW compressed 16 bit TIFF would be really nice.
MPA1
Senior MemberPosts: 1,513
I certainly hope that this is the case and look forward to Apple support soon!
Providing TIFF output from the camera from day one would at least have given us a big file with plenty of latitude to adjust whilst we waited for RAW to catch up.
steven_k
Regular MemberPosts: 404
In reply to MPA1, 8 months ago
When Adobe or Apple supports the X-Trans correctly I will buy a XE1 right away.
miniTO
Regular MemberPosts: 177
Wow, if that is true that is great!
I may hold off my purchase of Silkypix DP5 for as long as possible.  Despite the fact that I am starting to get used to it
Edited 8 months ago by miniTO
JasperD
Senior MemberPosts: 2,602
I sure hope this to be true, although I´m only a few weeks from switching from Aperture to LR: X-Trans was just a drop too much in a bucket already full with Foveon stuff because of a DP2x used as street camera.
With the X-Pro1 now taking about half of my pictures, I kind of had it with Apple here.
Maurizio De Cecco
New MemberPosts: 14
In reply to JasperD, 8 months ago
JasperD wrote:
I sure hope this to be true,  [ ... ]
I think they collectively have no choice; it will maybe take some time, but they will get there, together ("they" being Fuij, Apple and Adobe).
Sometimes people call this "market forces" ...
Maurizio
57even
Senior MemberPosts: 2,352
Great news!
Thanks for letting us know!
Brian Davies
Forum MemberPosts: 93
I hope that Phase One get wind of this and jump in too with C1
Best wishes
Brian
http://www.rafikiphoto.com
MikeS2012
Junior MemberPosts: 34
This is good news! I have read a professional opinion that TIFF would have been the preferred standard format over JPEG, had not the (earlier, perceived) limitation of file size not made JPEG so attractive.
==m==
MatW
Senior MemberPosts: 1,338
Great!
That would be great. Lightroom's support for X-Pro1 and X-E1 *really* leaves to be desired at the moment, some images look like they have been painted...
justinwonnacott
Regular MemberPosts: 331
In reply to MikeS2012, 8 months ago
I really do not see any advantage of tiff being stored on the card in camera.
- slower write speeds
- uses a lot of card space
- results in a processed file (even as 16 bit) that does not contain all the RAW data
I would be very happy  to see improved handling of xtrans RAW files in LR though.
CraigArnold
Regular MemberPosts: 299
Re: Great!
In reply to MatW, 8 months ago
The default ACR settings are not optimal. With proper processing these problems are dramatically reduced, to the point where results are already extremely good.
Over time I expet ACR to produce stunning results from X-tans, but posting ineptly processed examples overstates the problem hugely and only spreads FUD.
Blog ------------------------ http://craigspics.net/?tag=blog
X100 Blog ----------------- http://craigspics.net/?cat=6
X100 Quickstart Guide -- http://craigspics.net/?page_id=1345
MatW
Re: Great!
In reply to CraigArnold, 8 months ago
It is what people see when they load their RAW files into ACR/Lightroom, as simple as that.
I am sure you agree that it is not quite as easy as changing a couple of default settings like sharpening, you can tweak sharpening in Lightroom as much as you want, it will not help if the de-mosaicing algorithm is sub par. The branches on the first 100% crop should not be yellow, for example.
awelch100
I think a good temporary fix would be for Fuji to share their lens correction settings with Adobe. This would allow for  1:1 pixel matching between jpegs and raw files in Photoshop. Any artifacts found in the raw conversion could simply be masked and replaced with the data from the jpeg layer.
Perfect? No, but it would befiery useful.
CraigArnold
Re: Great!
People are applying the techniques and settings that have worked with their other cameras, but these don't work well with the X-trans.
On your image above try this:
Contrast: 30
Clarity: 30
Color & luminance NR: 0-10 (way down from the default of 30)
Sharpness:20
Radius: 0.7
Detail: 50
If there are still any overly smooth areas add grain of around 10, 20, 20.
Now compare that print to a 20Mp file from a 5D2/3, D600, Sony A900 or similar.
I'm NOT saying that ACR can't or won't or shouldn't get better, just that a lot of people are botching the conversion and blaming it all on Fuji/Adobe because they assume they have nothing to learn.
baobob
Veteran MemberPosts: 3,054
Re: Great!
In the thread the foliage issue I suggested for foliage to use either Silkypix that comes with the camera or Helicon filter 5 They prevent bleeding and smearing eventhough fine adjustment is not as good as in Adobe
I usually adjust light andd contarst, the record Tif 16 bits that I read with ACR for good c olor, contratsd etc... mastering
It is not the easiest workflow but with it I get all details and excellent results
