A99 vs D600 ISO6400 samples
Started Oct 19, 2012 | Discussions
steven_k Regular Member • Posts: 496
Re: A99 vs D600 ISO6400 samples
John
Nice job on the comparison, my question is in terms of overall IQ. Does the SLT mirror in anyway
hamper IQ over the D600 at base ISO?
(unknown member) OP Veteran Member • Posts: 3,992
steven_k wrote:
John
Not that I could see.
Both units seemed identically amazing at low ISO
Amateur Sony Shooter Veteran Member • Posts: 5,417
Good thread, here is what I think...
A99 is about half stop noisier than d600 but in real life the difference is very small I don't think anyone bought A99 will lose sleep over it. I also think there isn't meaningful difference between A900 and A99 in terms of high ISO noise, maybe 1 stop or so, that's why I am still on the fence undecided about upgrading from A900.
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +5 more
Re: Good thread, here is what I think...
Makes sense.
This may be of interest to you: http://forums.dpreview.com/forums/thread/3286761#forum-post-50102423
Saw that and posted there too. I would sarecompose to A900, A99 require less NR cleaning work and noise pattern is morepleasing, so there is definitely improvement, just not as big as I hoped for (after 4 yrs).
GuyMcKie Contributing Member • Posts: 596
With adjusted tonal curve, the a99 has a more steep contrast in the shadows and a smoother curve in the highlights, they are very close.
Maxeyesore
Maxeyesore Regular Member • Posts: 415
Nordstjernen wrote:
Also, when opening raw files from different cameras with a raw converter, some adjustment is needed to equalise the results. Default is NOT a standard or "neutral" or "true" and different cameras are treated differently!
But this means the D600 could actually be at a disadvantage here on top of still having less noise. The idea that there is gap of grey area makes no difference unless you know which is getting the short end of the stick. All this means is the D600 could be even better, which would be very sad indeed considering the price difference here.
To see is to believe...PENTAX
 Maxeyesore's gear list:Maxeyesore's gear list
Sony SLT-A33 Pentax K-5 IIs
Maxeyesore
Re: ISO6400 isn't everything!
Nordstjernen wrote:
Anyhow, the SLT technology will not overcome the traditional mirror for same generation cameras when it comes to high ISO performance.
Many of us are getting the A99 for OTHER reasons than high ISO noise barely visible behind the D600 at an ISO setting that we rarely use!
Another odd idea here, what reason would you get a a99 over a77? For sports it's a hard sell. Yes, tracking is better IF you have the lenses, but FPS is cut in half. For birding or long range shooting you are losing a lot of reach by going FF. Resolution is the same, 24mp. It would seem that the main advantage the a99 has is better noise performance due to more light gathered on a larger sensor. I am curious as to what reasons exactly so many people are interested in the a99 over a77?
Bruce Oudekerk
Bruce Oudekerk Veteran Member • Posts: 3,019
Re: Same noise day & night!
Nordstjernen wrote:
No, this is not true. Sensitivity of digital sensors is linear, so light level does NOT matter. What matters is exposure! You would get the same noise pattern for an underexposed daylit scene as for an equally underexposed night scene -- given that the same numbers of photons hits the measured area of the sensor.
You are not the first, nor the last, to point this truth out..  And of course you are correct.
There is, however, at least a glimmering of a rationale in believing otherwise, even if it is incorrect.
In dimly lit, yet properly exposed photographs, the entire histogram curve can often be significantly shifted to the dark end.  Thus a significantly greater proportion of the image lies in the noisy, shadow, areas of the picture.  More importantly, in dimly lit photographs (assuming the exposure correctly captures that dimly lit ‘look’) the likelihood is that visually important portions of the image are in this noisy marginal shadow/shade.  Thus the impression can be that the image is noisier than a brightly lit scene.  To make matters worse, often the image can exhibit extreme contrast and that pushes the dynamic range capabilities of the camera.  Since the image has been properly exposed to avoid overexposure and ‘blowing out’ the highlights, when the shadow areas are tweaked, noise becomes increasing apparent and ‘in your face’.  Here’s an example with an older KM7D camera…not that that matters:
The real culprits here are the nature of the lighting and the visual expectations we photographers bring to the fray, not how much overall light was available.  ‘Proper exposure’ determines the ‘amount of light’ that the sensor ‘sees’ at any given ISO.  The bottom line is that you are absolutely correct, but it’s easy for me to see how many photographers would make this mistake when evaluating image noise.
Bruce
...and for what its worth, editing replies in this forum...specifically the image insertion...is terrible. I have no idea how this will be done on a tablet with a touch screen.  I have little faith this will come out correctly now, even though the editing screen looks fine.
http://www.pbase.com/misterpixel
 Bruce Oudekerk's gear list:Bruce Oudekerk's gear list
Sony Alpha 7R II
ET2 Veteran Member • Posts: 3,916
That's like saying what reason someone would have buying APSC camera over 1" sensor camera. Bigger sensor.
A99 can do 10 fps in APSC mode, if/whem higher frame rate is required.
No, you are not, as you can switch to APSC mode on A99 and still get 11 MP photos.
True, but A99 has larger pixels, which would mean the lens would more easily resolve those 24 MP pixels.
Exactly, and that matters.
