2 great alternatives to Olympus Sport Case for RX100
Started Oct 19, 2012 | Discussions
Liz Z.
Liz Z. Senior Member • Posts: 1,267
I had no luck getting the Olympus Horizontal Sport case to work, so I returned it, but I still hoped to find a horizontal form-fitting neoprene case (since I started using a neck strap I've found vertical cases akward). I was perusing the Op/Tech site and they had only a few options that they linked with the RX100, but I decided to delve further, and my delving paid off, with two different but really good options.
My favorite is this one, the Soft Pouch-Snapeez, $9.95 on Amazon. It fits the camera like a glove and closes with a magnet. The back has a belt loop which is so tight it can be used as a horizontal battery pocket, especially if I sew one side shut.
Snapeez closed around RX100
Back view, belt loop
The other one is the Soft Pouch Digital Series--D-Micro, $15.70 on Amazon. This one requires a bit more effort (by design) to get the camera into it--Op/Tech suggests turning it inside out, but I didn't need to. It has an internal "leash" strap and hook that attaches to the camera's strap, and allows the case to stay attached while off the camera. This one has no belt loop. It has two snaps on the underside of the pouch. If I keep it I'd sew velcro to the label and the bottom, as the snaps require more effort than the magnet of the Snapeez.
The part with the label has snaps that close under the pouch. Camera case "leash" on right.
D-Micro, top view with camera
D-Micro bottom view
The caption of the 5th image above disappeared, but that is the side view of the Snapeez, showing the elastic which makes it adjustable.
Liz
 Liz Z.'s gear list:Liz Z.'s gear list
Fujifilm FinePix F31fd Sony RX100 Adobe Photoshop CS6 +1 more
Sony RX100
tonyswash
tonyswash Regular Member • Posts: 195
Re: 2 great alternatives to Olympus Sport Case for RX100
I use a BlackRapid RS-7 camera strap for my D800 and I got a Black Rapid Joey 3 large pocket to clip onto it and it holds my RX100 perfectly. The combination of having both cameras on the same strap is fantastic as they really compliment each other.
Liz Z.
Liz Z. OP Senior Member • Posts: 1,267
The Black Rapid seems like an interesting system!  I had looked at one of their horizontal cases on line (Snapr 10) but it seemed too narrow for the RX100.
Liz
aburman
aburman New Member • Posts: 21
Liz
The RX 100 fits perfectly in the Snapr 10. I have it. Great system.
Alex
 aburman's gear list:aburman's gear list
Panasonic Lumix DMC-FZ1000
John TF
John TF Senior Member • Posts: 1,231
Thanks, Liz. I'll try it out.
Need to take care on Amazon - there are several sizes of this pouch. I think this is the one Liz is referring to:
OP/TECH USA 7301264 Snappeez-Large, Wide Body Horizontal Neoprene Pouch for Camera (4.5 x 2.5 x .75 - 1.25 Inch) (Black)
John TF
Liz Z.
John TF
Yes, that's it. And even though it says the maximum width is 1.25" it requires no effort to get the RX100 into it.
Liz
Liz Z.
aburman wrote:
Liz
Alex
Thanks Alex...Interesting that their posted measurements are off, then. The Black Rapid site says that the Snapr 10 has a width of one inch where the RX100 body is 1.5" or so; it might make sense to let them know that it accomodates a camera that is thicker than one inch. I called Op/Tech and told them the two cases above should be listed for the RX100 in their "Product Finder," which they were pleased to know, but it remains to be seen if they make changes to their website!
Do you find that hanging from the tripod port the camera bangs against your hip as you walk? That's what happened to me when I tried to use a neck strap with a previous camera that had only one attachment point on one side of its body.
Liz
JCB123
JCB123 Senior Member • Posts: 1,255
D-Micro bottom view
Liz
I would recommend using a zipped case. I used to use cases like this or even put my camera in my shirt pocket. Until I got l dust on my sensor (Canon S95) Dirt can work its way through the lens sleeves after a while and sensor cleaning on a fixed lens camera is expensive. You don't want that to happen to your RX100.
Regards
John
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
Liz Z.
Alex
Never mind, I just saw the instructional video--I was picturing the camera on the strap minus the case!
Liz
Liz Z.
I normally keep my camera in my purse, in its case, so I am hoping that this will work--it's worked for previous cameras, anyway. The problem is, with a neck strap a zipped case has to either stay partially open so that the straps can protrude, or I'd have to have a much bigger one to accomodate them.
Liz
Liz Z.
Tried without success to edit my post above, so here's what I meant to say:
I just saw the instructional video again--I was picturing the camera on the strap minus the case. Does it bang in that situation, or do you always have it in its case?
Liz
JCB123
Liz
I guess that should work too. Being a bloke I don't carry a handbag/purse so the zipped case (with the wrist strap tucked inside) is the solution I have adopted for carrying my camera.
So
Girls - do what Liz does (just make sure your face powder doesn't escape into your bag)
Guys - do what I do or something similar. Just don't rely on a 'gappy' case to keep pocket lint away from your camera.
If you notice dust on the lens barrels when they extend then you know you are at risk. Brush, or blow it off before you power the camera off and make some change to how you carry your camera. Uncased in a shirt pocket is not a good idea - learn from my mistake. Dust on the lens barrels will eventually find its way inside and onto your sensor.
Regards
John
DFPanno
DFPanno Veteran Member • Posts: 4,168
Thanks Liz - ordered a snap-ezz
Liz Z.
That's become my favorite, use-all-the-time case!
Liz
langdonauger
langdonauger Junior Member • Posts: 38
My Op/Tech doesn't fit
I just got the "snappeez wide body horizontal large" for a xmas gift from Amazon based on this thread, and there is no way it will fit inside. It doesn't have that Op/Tech logo, and says "made in China" inside. Wifey was pretty excited to give it to me, but oh well.
Liz Z.
Re: My Op/Tech doesn't fit
That's a shame! It sounds as if you got some knock-off. But if you ordered the Op/Tech one from Amazon and they sent you another, you do have very right to return it at their expense, based on their sending you a substitute item.
You can see from the photos that the camera really does fit into the right one!
Liz
