Lightroom Lens Profiles for Olympus Lenses
Started Oct 15, 2012 | Discussions
saisrujan Junior Member • Posts: 45
Hello!
I've been a forum member since 2009 but haven'e been participating much. I've moved from a D90 setup to Olympus - sold all my gear and got myself an OM-D E-M5 with the kit 12-50 and 75-300. The results are great and I attribute my decision to a lot of 'passive' research on this forum. Thank you all for that.
The only thing that's bothering me now is the distortion at the wide-end of the 12-50, when shot in RAW. LR doesn't have the lens profile. I've installed the Adobe Lens Profile Downloader, but it didn't have any matching profiles. I've looked around on the internet, but didn't find any.
The reason I'm looking for help from the community is because the distortion, sometimes, is complicated and I'm not happy with my manual corrections, the results always look a little off. And without good straight-line references, it becomes even more difficult.
Have any of you developed a lens profile for the two lenses above? I'd really appreciate it if you can share them.
Nikon D90 Olympus OM-D E-M5
19andrew47
19andrew47 Forum Pro • Posts: 21,460
Re: Lightroom Lens Profiles for Olympus Lenses
One option is to correct the lens distortion in Olympus Viewer.  It has auto correction and recognizes this lens.  Save the image and then edit in your selected program.  Adobe does not treat Olympus images as well as Viewer does, but it is much more versatile.  Viewer came with the OMD and the newest version is available for download if you were not aware of this.
saisrujan OP Junior Member • Posts: 45
Never tried the viewer. I will give that a shot. Still, the workflow's a lot easier if I can get this done in LR. So, let's see.
Anders W Forum Pro • Posts: 21,465
saisrujan wrote:
Hello!
LR doesn't need lens profiles to correct distortion for MFT lenses. The correction instructions are embedded in the RAW files themselves. I don't have the 12-50, but LR automatically corrects the distortion on all my other MFT lenses without problem.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +28 more
OldDigiman Senior Member • Posts: 1,956
All m4/3 raw files have lens data embedded in the files.  LR reads the data an applies corrections, there are no "external" profiles such as with the usual DSLR lenses.  However, per Eric Chan of Adobe, the correction applied by LR is on the conservative side.  You can use the Adobe Lens Profile software to create a external profile that will modify the baked-in corrections.  Alternatively, you could tweak the correction for a given focal length and save it as a preset in LR.
___________________
ODM
www.ahfairley.com/gallery/index.html
www.olmstedactupuncture.com
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,022
I'm curious as to what sort of subject you're addressing, as I find LR pretty good in this area (though some extreme cases call for extreme measures).   Though, it took some patient practice initially to make it relatively quick work as I do now.
...Bob, NYC
http://www.bobtullis.com
/"Well, sometimes the magic works. . . Sometimes, it doesn't."/ - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +15 more
MatsP
MatsP Senior Member • Posts: 1,498
New to my OMD I was a little confused at first that LR4 had no lens corrections for oly lenses but as I couldn´t see any distorsion or CA or light falloff I simply thought my lenses were superb in those respects and didn't need correction, but now I know better...No, to be honest, I guessed there was some "invisible" correction in LR and now I know that this is the fact. Is this true for all m43 lenses?
 MatsP's gear list:MatsP's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus 12-40mm F2.8 Samyang 7.5mm F3.5 UMC Fisheye MFT
Hej Mats och välkommen till forumet!
Distortion is generally auto-corrected for all MFT lenses although a few of them (at longer FLs) have so little distortion that hardly any correction is needed. Lateral CA is auto-corrected only for Panasonic lenses when used on a Panasonic body. Longitudinal CA is not auto-corrected. Vignetting is not auto-corrected either except as a by-product of distortion correction (which in the case of barrel distortion moves the extreme corners out of the frame). However, some MFT cameras (e.g., the E-M5 and the GX1) have an option for so-called shading compensation, which, if enabled, corrects the RAW files for vignetting (at the expense of increased noise towards the edges). While the correction for distortion and lateral CA take the form of an instruction to the RAW converter embedded in the RAW file, the shading compensation option changes the RAW data values themselves.
John Bean (UK) Forum Pro • Posts: 18,034
It is the case for all micro 4/3 lenses. Only Panasonic cameras provide CA correction data, but the lack of CA correction by Olympus cameras is a moot point if using Lightroom 4 - it applies CA correction automatically to any lens on any camera as long as you enable the "Remove Chromatic Aberration" option on the "Color" tab in the "Lens Corrections" section.
John Bean [BST (GMT+1)]
Ulric Senior Member • Posts: 3,513
I've been tinkering with Lightroom. It seems to me that it corrects distortion whether I click the "Turn on lens corrections" button or not. That's annoying because for most images it is IMHO unnecessary to correct for distortion and it actually makes corner resolution worse.
On the other hand, if I turn off lens correction entirely, I also turn off chromatic aberration removal, which is a much more useful tool.
I came to these conclusions by editing the same images in Aftershot Pro, where obvious distortion is corrected if and only if I click the "Enable correction" button.
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +9 more
Oh, and one other thing: surely not all m43 lenses do the automagic correction trick, right? I'm thinking of the completely manual Voigtländer lenses, for example.
Yes. The geometric corrections are always applied from data embedded in the file, it is not a user-selectable option. Other things like CA may also be, depending on the camera. Everything else that is done by LR itself (like CA on a non-Panasonic camera, for example) can be turned on or off as required.
The CV lenses are completely unknown to the camera, just like any "legacy" lens on an adapter.
They may have been designed to fit a micro 4/3 camera without adapters but they are not native system lenses in the sense they do not conform to the micro 4/3 standard for communication with the body.
So there is no way to get the uncorrected image in Lightroom? Interesting.
Michele Cocci New Member • Posts: 17
Hi Anders, some time ago you wrote: "The OM-D has an option for shading compensation which corrects for vignetting but this will apply to OOC jpegs only".
So, what's the truth? E-M5 "shading compensation" applies to OOC JPGs only, or it changes RAW data?
I enabled this option, but if it affects RAW file too, i'll disable it.
cosmoxl Contributing Member • Posts: 597
a profile will help!
contrary to what many are saying, profiles made with the adobe lens profile creator or downloaded with their lens profile downloader will help you!
for example, check out this thread with quick tests I did with the micro 9-18 lens.  the profile available with the adobe lens profile downloader does a great job of fully correcting for distortion and vignetting.
http://forums.dpreview.com/forums/post/42067580
 cosmoxl's gear list:cosmoxl's gear list
Panasonic Lumix DMC-FZ50 Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +5 more
Did I? Can't remember that. What I might have said is that I had been told by other people here that the shading compensation option on earlier Oly bodies affected OOC jpegs only. Since I have no personal experience with these models, I can't tell for sure whether that's correct or not.
With respect to the E-M5 it is definitely the case that the shading compensation affects the RAWs, not only the OOC jpegs. I tested how it worked shortly after I bought the camera and reported my observations in the thread to which I link below.
http://forums.dpreview.com/forums/thread/3255277
As you can see, there were some problems getting this feature to work with Pany lenses, at least with the firmware I had at that point (1.1.). Don't know if anything has changed in this regard in FW 1.5.
Yes, for a variety of reasons, spelled out in the thread I link to, I decided against using it too.
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,040
Yes it's automatic, but it's not perfect.
The correction data for the Olympus 12-50 is not perfect. At the wide end the lens shows more barrel distortion than the correction data tell the RAW converter to correct for, so some additional (like +5) additional barrel distortion correction needs to be dialed in. (I use CS6 with ACR, not LR)
The correction is typically good enough but when you have a straight vertical line near the edge of the image you can see that some barrel distortion is left. So for most pictures I do not apply extra correction but occasionally it is too visible to leave it without correction.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 +5 more
Re: Yes it's automatic, but it's not perfect.
OK. I now see when I check the Lenstip review that the 12-50 leaves as much as 2.25 % barrel distortion after correction, which is certainly enough to be noticeable in cases like the one you describe. Can't remember seeing such a high figure after correction for any MFT lens. As a rule, they are corrected to a value of about 1 % or less. But in this particular case, it might be a good idea to add an LR profile in order to reach that neighborhood.
rrr_hhh Veteran Member • Posts: 6,019
I think that there is a plugin named "recover edges" that would do that, but I'm not 100% sure of that; it is able to recover the whole 4:3 format, even if you had chosen 3:2 or 16:9 at the time of shooting and I seem to remember that it will also deliver the uncorrected picture. It is an Adobe plugin and can be downloaded here :
http://labs.adobe.com/technologies/lightroomplugins/
there is another plugin available there which seems to correct vignetting or something  restituting a "flat view " (?)
Here are instruction on how to install it
rrr_hhh
 rrr_hhh's gear list:rrr_hhh's gear list
Sony Alpha 7R Olympus OM-D E-M5 Canon EOS 6D Olympus E-M5 II Sony Alpha 7R II +4 more
