Upgrading to D600 with these lenses?
Started Oct 15, 2012 | Discussions
robb01 New Member • Posts: 8
I currently use a D90, and with the release of the D600 I'm really wanting to upgrade. My reasons for upgrading would mainly be IQ. I want the best image quality that I can get, while staying within my budget.
My question is, I know my current lenses will work with the D600, but how well will they work? I currently have:
Tokina 12-24
Nikon 35mm 1.8G
Nikon 50mm 1.8d
Tamron 18-200
Nikon 28-105
Is it worthwhile to upgrade with these lenses?
SethG Contributing Member • Posts: 897
Re: Upgrading to D600 with these lenses?
You're going to need some new glass. Most of those lenses are DX lenses. The 50mm is fine, and the 28-105 will work, although I don't know whether that's considered a "good" lens or not. If you want to go cheap, get an 85mm f/1.8 and 35mm f/2. Otherwise plan on getting the 24-120 f/4
- Seth -
webfrasse Veteran Member • Posts: 3,858
Tokina 12-24
DX, will not work properly
Nikon 35mm 1.8G
DX. will not work properly
Nikon 50mm 1.8d
FX, ok
Tamron 18-200
Nikon 28-105
FX, ok
Only FX lenses will work properly on an FX Camera like D600. Buy the Kit with the 24-85 VR lens. It's sharper than most lenses above. Sell the DX lenses on eBay, it will most likely cover the added cost of the kit lens.
Mikael
A. Westreich Senior Member • Posts: 1,195
Tokina 12-24
Nikon 35mm 1.8G
Nikon 50mm 1.8d
FX, ok
Tamron 18-200
Nikon 28-105
FX, ok
Mikael
All those DX lenses will "work properly" on the D600 in DX mode.  Note that the DX mode on the D600 is about a 10.1 mpx file as compared to your 12 mpx D90 file.  The D600 has considerably better noise performance than your D90 - so you give up some resolution and gain some high ISO performance.  If you want to take full advantage of an FX camera, I agree that you want to use high quality FX lenses.
I no longer equate image quality with megapixels.  I have two friends who both shoot 10 mpx cameras (one's a canon, one's a Nikon D100) and both are better photographers than I am.  I have also seen some fine images from a nikon V1.  The question is what about the IQ of your D90 are you not happy with?
 A. Westreich's gear list:A. Westreich's gear list
Nikon D7100 Nikon AF Nikkor 35mm f/2D Nikon AF-S DX Micro Nikkor 40mm F2.8 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR
A. Westreich wrote:
Tokina 12-24
Nikon 35mm 1.8G
Nikon 50mm 1.8d
FX, ok
Tamron 18-200
Nikon 28-105
FX, ok
Mikael
Yeah, spend +2000 on an FX body and put DX lenses on it...I don't call that properly but ok...go ahead. It's not my money.
Mikael
rayman 2 Veteran Member • Posts: 3,228
In your case it could be a good idea to get the replacement of the D7000.....
that will have the 24MP sensor .... in good light it will be as good as the
D600 and in higher iso it will be 1 stop behind the D600..
Peter
herbymel Senior Member • Posts: 5,308
the 12-24 will work okay from about 19mm up...eventually you'll probably want to replace it, but your images aren't going to be too bad with it.
Herby
 herbymel's gear list:herbymel's gear list
Nikon D810 Nikon D750 Nikon AF Nikkor 50mm f/1.8D Nikon AF Nikkor 105mm f/2D DC Nikon AF-S Nikkor 16-35mm F4G ED VR +7 more
EYeye Regular Member • Posts: 247
Try some shots with your 35mm 1.8 DX at 2.8 ish but in FX mode, and see if the vignetting is acceptable. Try each stop and see what you get.
Use the same lens on the same subject in DX mode, and see which makes the "better" image.
I tried this, and was pleased with how well the DX mode worked (but I upgraded from a D80, which had similar MP to D600 in DX) as well as how I could crop out vignetting in FX mode and still have a nice image.
However, I will not use the 35mm for long and will try to find a better FX lens (maybe the 24-85 VR) in that range.
 EYeye's gear list:EYeye's gear list
Nikon D600 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF +6 more
chimphappyhour Regular Member • Posts: 476
Herby
Yup, I use the Tokina on my D700 and now my D600. It works out incredibly well. I originally started using it as a stop gap until I could find a FX wide zoom. That was a few years ago. I'm still using the Tokina.
robb01 OP New Member • Posts: 8
Is vignetting bad with the Tokina, not really quite sure how that works yet
Just another quick question, didn't realize there was a dx mode on the fx cameras, if the d600 in dx is 10.1 mp, what is it on the D800?
Just below 16 MP (15.3, I THINK).
ALSO: you can force DX mode and use an FX lens if you wish, and some say that this "extra reach" is worthwhile, whereas others report that simply cropping the FX image is better quality image due to the 36 MP of a D800 - or a tossup with the D600's 24 MP - (YMMV).
I am still learning D600 and am not sure, but suspect this depends on what focal length AND distance to the image focus point you have chose to crop from or "DX reach".
I think what I'm mostly considering now is selling all of my current equipment, and getting the D600 with the 24-85 f/ 3.5, that will cover all my current focal lengths and be an fx lens
CFynn Veteran Member • Posts: 5,224
Keep the 50mm 1.8d
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF Nikkor 105mm f/2D DC +14 more
bocajrs
bocajrs Senior Member • Posts: 1,594
CFynn wrote:
Keep the 50mm 1.8d
That's what I did (sold my D7K, 16-85MM VR is still for sale on Ebay) and bought 50mm 1.8G to go along with kit lens. Although it's a kit lens, IMO, it has fast AF, great IQ and is very light. Definitely cheaper than the 24-70 2.8 which costs 3X as much.
I also have Siggy 70-200 2.8 OS DG HSM and its superb on this camera.
 bocajrs's gear list:bocajrs's gear list
Nikon D750 Nikon 1 J4 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Teleconverter TC-20E III Nikon 1 Nikkor VR 10-100mm f/4.5-5.6 +2 more
No, it won't.  Consider the crop factor.  Your 18 -200 on your D90 is equivalent to a 27-300 on an FX camera.  Your 12-24 on the D90 is equivalent to an 18 -36 on an FX.  You'll have the middle covered with the 24-85, but not the wide or long end.
That's the oddity of some of the Tokina lenses. With the Tokina 12-24, from about 18.5 to 24mm, you'd be hard pressed to tell it is a DX lens. (The 18mm-19mm barrier seems to vary from sample to sample or user to user but that is where the boundary looks to be.) Once you go wider than that limit, you'll see the black box and internals creep into frame. Not much point in shooting this lens in DX mode since 12mm in DX is roughly the field of view you'll get in FX mode.
krikman Regular Member • Posts: 404
Tokina 12-24
Nikon 35mm 1.8G
Nikon 50mm 1.8d
Tamron 18-200
Nikon 28-105
Tokina 12-24 works fine. You have different options:
- use from 19-24 FF
- use with crop 1.2 from 15mm
- use dx and slill plenty full 12-24 obviuosly.
And you will see vignetting from lens hood and filters  - so take it away. It adds you 1-2mm coverage wide.
in my quick tests there were no degrade in border IQ, even in extremes. Center IQ is better than D300.
toprock03 New Member • Posts: 10
keep the 35mm 1.8.  I did and it works great in FX mode.  You will have some vignetting in the corners but you dont really notice if you use it for low light like i do.  Inside of bars, restaurants or night on the street its nice to have the 1.8 aperture
Is it the sharpest lens in the world in the corners?  probably not, but it works great for what i want to use it for.  Afterall im printing at most 8x10 not 24x36.
If you are doing landscapes chose a different lens.
Tord S Eriksson
Tord S Eriksson Veteran Member • Posts: 5,821
Tokina 12-24
Nikon 35mm 1.8G
Nikon 50mm 1.8d
FX, ok
Tamron 18-200
Nikon 28-105
FX, ok
Mikael
All these lenses will work, but most only in DX mode! I began with roughly the same setup, but already had the 85/1.8G, the 50/1.4G, and the FX-capable AF-S 70-300 VR, but I got the Samyang 1.8/24 to complement the setup.
tord (at) mindless (dot) com
 Tord S Eriksson's gear list:Tord S Eriksson's gear list
Olympus C-8080 Wide Zoom Ricoh GR Nikon 1 V1 Nikon D600 Nikon 1 V2 +20 more
