NEW 1Dx owner has settings questions
Started Oct 9, 2012 | Discussions
Jam Contributing Member • Posts: 871
So I'm a new 1dx owner (as of last night)
I plan on spending time  tonight and tomorrow to setup the body for ME.  I plan on making all the appropriate settings changes to accommodate my photo style but I know many people have already been doing this…
So, my questions is – Is there somewhere on the web that breaks down the best settings to use.
I know everyone/everystyle deserves a different setting arrangement – but I'm wondering if there is a standard that I should start with to make the body most successful.
Jam
Canon EOS-1D
Andy Blanchard Senior Member • Posts: 1,034
Re: NEW 1Dx owner has settings questions
You would do worse than to start on Canon Europe's CPN website (or the US equivalent, if you prefer).  There are plenty of tutorials and technical articles (look at the related links section) that explain the features of the camera, including a downloadable guide to the new AF system which is definitely worth a read.
KAllen Veteran Member • Posts: 3,814
Jam
I got my X shot with it solidly on jobs for two days before having time to look at the manual.
Other than knowing the AF settings inside out (and I don't) it's just a camera.
I know I shoot only raw, so I set it for raw mirrored to the second card. I know the shutter speeds for my work I need so I set it to Tv, I know what iso I parameters I like so I set accordingly.
I don't use DPP as my main processor, so no need to bother with lens correction, optimum light enhancer etc besides it can be set afterwards if you do use raw and DPP.
One quick observation regarding DPP and Photoshop, DPP handles shadow noise better straight from download.
The 1D X is just like any camera gone before it, you have four settings that matter, film/sensor iso, aperture, shutter speed and focus. anything else is just fine tuning or a bloody pita.
Kevin.
Jam OP Contributing Member • Posts: 871
yup - eveyones settings are going to be different - and yup the camera is still a camera....
I just thought that someone has probably gone through the effort to determine what might be better - like the button assignment, then other way's.  And instead of me trying to figure it all out, I'd at least have a starting point.  Like don't assign x feature to y button because it's kinda difficult to reach and you may not be able to use it in an "emergency" --- stuff like that.
rbarta Regular Member • Posts: 284
Everything right out of the camera is set nicely and you will likely only change a few options if any.  I would go through the entire manual to figure it all out.
My Menu is set to 1. Spot Meter linked to AF point (on) 2. AF mode (quick) 3. ISO settings, 4. Auto Lighting Optimizer (on) 5. Highlight Tone Priority (off)  6. Communications settings
I am shooting RAW and JPEG (AWB, Faithful) at the largest sizes.  Rarely do I need to use the RAW over the JPEG.
I enabled the silent movie controls but have not shot any video yet.
I set AF AI Server 1st and 2nd image priority to focus priority, it will not take a shot until in focus.
EOS iTR AF ON, selectable AF points ALL, Spot meter linked to AF pt., Shutter release time lag to shortened (I'm usually within 2 stops of wide open)
Once you have your basic settings, you can set M, Av, Tv and save them as alternate cameras 1-3.
I left all the configurable buttons as default....for now.
I had a couple notes on flash usage, I have no solution
1. Don't use the flash in Av mode.  It meters the shutter speed to the background, so if it's dark the shutter will be very long.
2. The flash auto-assist beam will not come on when shooting Servo.
 rbarta's gear list:rbarta's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EF 15mm f/2.8 Fisheye Canon EF 50mm f/1.2L USM Canon EF 16-35mm f/2.8L II USM +7 more
QUINN03 New Member • Posts: 21
Jam,   I shoot sports and wildlife (mainly birds in flight). I am going to touch on some button customizations that I feel will benefit everyone, regardless of what they shoot. These button customizations allow you to make extreme changes very quickly, helping you get "the shot",or just save some time in making adjustments.
1. multi function button 2 has been set to switch between AI servo and one shot AF. This is for when                    static objects start to move or vice versa.
2. M-Fn button is set to scroll from your current shooting mode through any of the custom shooting  modes you have registered. This is awesome for changing shooting modes, by just pressing one button. The sky is the limit on the custom shooting modes you can change just about anything. you can go from 61 point, AI-Servo, high speed continuous drive, auto ISO, metering linked to AF point..... to any other 2 shooting modes you can dream up. one for sports, one for wildlife, and one for portraits.
3. my "set" button is set so when it is held in the ISO speed can be changed with the main dial during metering. This is great for when you are in manual mode with a shutter speed and aperture set  and you want to change the exposure by changing the ISO speed. The change happens while metering, so you can see the exposure meter change as the ISO changes.
4. I put "set aperture range" & "set Shutter speed range" in my menu, so I can set those limits when using AV or TV mode with ISO safety shift.
The clean high ISO speeds allow you lots of freedom with safety shift and auto ISO if you are encountering lots of changes in lighting.
Just my $.02, hope it helps.
I just solved this by putting Flash sync in Av Mode (in the External Speedlight Control sub-menu) setting to 1/250.
Also, I set the auto-ISO range to 50-12800 and the min shutter speed in auto-ISO to 1/250 (the fastest available)
p4pictures New Member • Posts: 23
Note that if you use Av mode with this function set, you also disable High Speed Sync in Av mode.
In essence the three settings available for shutter speed in Av mode are better explained as
Auto - shutter speed to correctly expose the ambient from 30s to sync speed or higher if HSS is on
1/60s - 1/250s - work like P mode, fill-in flash in reasonable light, give up on the ambient in the dark. HSS disabled
1/250s - work like manual with a fixed shutter speed, HSS disabled
I've just spend two days in Dublin teaching sports / news photographers how to set-up EOS-1D X cameras properly.
 p4pictures's gear list:p4pictures's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 14mm f/2.8L USM Canon EF 20mm f/2.8 USM Canon EF 24mm f/1.4L II USM +11 more
Shazza2014 New Member • Posts: 1
How do I set the HSS on the 1DX? The manual is confusing...
superlucifer
superlucifer Junior Member • Posts: 39
In Settings go to C..Fn3:Drive
Press SET on Continuous shooting speed. Set your speed there.
Read my bullet!
 superlucifer's gear list:superlucifer's gear list
Canon EOS 5D Mark II Canon EOS 20D Canon EOS-1D X Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM +8 more
Philippe R Contributing Member • Posts: 928
+1
Phil (Nice, FR)
www.pbase.com/webman06
www.eosdslr.com
 Philippe R's gear list:Philippe R's gear list
Canon PowerShot G10 Fujifilm X100S Canon EOS 30D Canon EOS 350D Canon EOS-1D X +51 more
Mike921 Regular Member • Posts: 296
Like a lot of guys here I set my multi-controlller to select the AF point, still need to push the shutter half way to activate, but for me it's ok.
 Mike921's gear list:Mike921's gear list
Canon PowerShot S400 Canon PowerShot S2 IS Canon PowerShot G12 Canon EOS 7D Canon EOS-1D X +9 more
Megalouis New Member • Posts: 1
Hi, I am also new, where did you go in the settings to set 1dx to save jpeg to one CF card and the raw images to the other CF card?
apersson850 Senior Member • Posts: 1,066
The very first yellow menu item.
Anders
