Help: SX50 Digital Zoom
Started Oct 9, 2012 | Discussions
Bev
Bev
Regular MemberPosts: 248Gear list
Oct 9, 2012
Here's my problem. In the Menu, on the Camera tab, the second option is "Digital Zoom."
I have set Digital Zoom to "Off."
Only now, I can't find a way to turn it back on! The Digital Zoom option is grayed out and the scroll bar skips over it, going from AF Frame at the top, directly to AF-Point Zoom.
What do I need to do to enable digital zoom again?
Thanks for any help!
Bev
 Bev's gear list:Bev's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 70-200mm f/4.0L USM +6 more
mingleby
Regular MemberPosts: 169
Re: Help: SX50 Digital Zoom
In reply to Bev, Oct 9, 2012
I suspect you have the camera in 'Auto' mode?
Try changing the mode dial to 'P' and then going back into the menu options.
Mike.
Bev
Bev OP
In reply to mingleby, Oct 9, 2012
Mike.
Thanks for the idea, I appreciate it. That wasn't the answer, but your suggestion led me to it! I shoot in aperture priority. But when I put the camera in Auto mode while I was checking out your idea, the digital zoom option became active again!
The camera comes out of the box set to Auto mode, so when I got it and started going through the menus, I naturally set digital zoom to off (which I usually do with my cameras).
Apparently, digital zoom is available ONLY in Auto mode?  Is this true?
Bev
Lin Evans
Forum ProPosts: 16,479
That's the way it is on mine - digital zoom only available in "Auto" mode...
Best regards,
Lin
learntomakeslidshows.net
VisionLight
Senior MemberPosts: 3,599Gear list
If Digital Zoom is only available in AUTO, then this would be a downgrade from the SX40 where I can use it in Tv, Av and P (although I only use its TC variants, but the full Digital Zoom is available).
Now on the SX40, you can not use AF-Point Zoom when Digital Zoom is engaged (AF-Point Zoom grays out, or if previously selected as on, automatically turns itself off). Possibly on the SX50 there is a similar relationship, but reversed. Try turning off AF-Point Zoom while using Tv, Av or P and see if the Digital Zoom becomes active again.
Vision
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Bev
Bev OP
In reply to Lin Evans, Oct 9, 2012
Best regards,
Lin
Thanks, Lin!
Bev
Bev
Bev OP
In reply to VisionLight, Oct 9, 2012
Vision
Vision, thanks for the ideas. I have AF Point Zoom set to Off and Digital Zoom is still grayed out in anything but Auto mode. I tried turning AF Point Zoom on, no change.
It's odd that the users manual doesn't mention that DZ can only be used in Auto. I don't have a problem with it because I normally keep DZ turned off, anyway. But I was curious to see the quality of it on this camera. That's when I discovered this apparent limitation.
Bev
Woiana11
Regular MemberPosts: 120Gear list
Just checked my Camera.
Digital Zoom is available in P mode.
It can be changed to Standard, Off, 1.5X or 2.0X.
You must have accidentally changed some other settings.
Maybe try a camera factory reset under Menu - Tools- Button: "Reset all"
Hope this helps
Eric
 Woiana11's gear list:Woiana11's gear list
Canon PowerShot G1 X II PowerShot SX700
VisionLight
Vision
Bev
Ok, just went to page 266 of the SX50 manual. It shows that Digital Zoom IS available in Av, Tv and P modes. But between page 266 and 267 also shows options where it is not available. Maybe going thru this may help you drill down to something you may have turned on that is preventing DZ from showing up. If I notice anything, I'll come back in and let you know.
Vision
Lin Evans
I discovered....
That if I choose JPG only, I can use digital zoom in the other modes. On the other hand if I choose RAW and JPG, I can only use digital zoom in the Auto mode. It appears that RAW is not supported with digital zoom except in the jpg mode with other than Automatic.
Best regards,
Lin
VisionLight
Re: I discovered....
Best regards,
Lin
Good catch, Lin. Since SX40 doesn't have raw, I wouldn't have found it. And it makes sense since DZ is an in-camera process that goes against the "spirit" of raw. But then that confuses me as to how it would be applied to the raw image when in JPEG/raw and AUTO mode. Does it only apply DZ to the jpeg and leave the raw at optical settings, or is it a cropped "mini" raw file?
Can you try it and let us know.
Thanks,
Vision
Bev
Bev OP
Lin, Eric, and Vision...
Thanks for all your help!  Yes, I shoot RAW + JPEG, so that is likely causing the limitation. I wonder if RAW is disabled when shooting in AUTO mode?  Back to the manual...
You guys are great!
Bev
Lin Evans
Hi Bev,
Yes, you nailed it. RAW is disabled in the Auto mode and that's why it allows digital zoom when the camera is set to RAW plus jpg.  Bottom line, digital zoom is only available as a jpg and the camera simply ignores the RAW setting when in Auto mode. In other modes if RAW or JPG plus RAW is chosen, it ignores digital zoom.
Best regards,
Lin
Bev
Bev OP
It all makes sense now!
Bev
Lin Evans
VisionLight wrote:
Best regards,
Lin
Thanks,
Vision
As it turns out - RAW is not supported in the Automatic mode and only a cropped jpg is saved when using digital zoom. So regardless of whether or not you have RAW chosen the camera doesn't save a RAW when using digital zoom and won't use a digital zoom if RAW is selected except in the Automatic mode where RAW is ignored.
Best regards,
Lin
