A99-1600-3200-6400 raw with LR4 crops
Started Oct 6, 2012 | Discussions
GuyMcKie Contributing Member • Posts: 600
5
Applied the same settings for all three. Tried to make a good compromise between detail, color detail and noise.
Sony SLT-A99
Clyde Thomas Contributing Member • Posts: 540
Re: A99-1600-3200-6400 raw with LR4 crops
You can't publish these samples!  What will become of the NaySayers?
Thanks for posting.
Here to help. Here to learn.
Audiophiling Contributing Member • Posts: 673
Cool. Try applying no luminance noise reduction and only get rid of the colour noise. This is what I do. Sometimes the grain can look good.
Shield3 Senior Member • Posts: 2,440
Hey, where can I get an A99 so I can shoot indoor shots???
 Shield3's gear list:Shield3's gear list
Canon EOS 5D Mark III Canon EF 135mm f/2.0L USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 85mm f/1.2L II USM Canon EF 24-70mm f/4L IS USM +2 more
GuyMcKie OP Contributing Member • Posts: 600
3200 ISO, no sharpening and no luminance noise reduction
Ahh, I get it - I must have to own a house that nice to get an A99 early!
Nordstjernen
Nordstjernen Veteran Member • Posts: 6,876
Impressive!
I opened these with Photoshop and Lightroom, and I have to say that I am impressed with the results. Not only is luminance and croma noise well controlled. The noise pattern is pleasing and the amount of detail at high ISO is amazing! So this led me to preorder the A99.
 Nordstjernen's gear list:Nordstjernen's gear list
Sony Alpha 7 Sony SLT-A99
Forgot to remark. Credit for publishing the raw files online are for user AlexId.
http://forums.dpreview.com/forums/post/50010525
oo cool. thanks
J Birn Contributing Member • Posts: 770
Re: Impressive!
Indeed. I already pre-ordered, but seeing that ISO 6400 can make clean, usable shots is exactly what I was hoping/expecting to get. (In fact, if I weren't getting a huge upgrade in high-ISO performance compared to my crop-sensor camera, I would cancel my pre-order. This is what going full frame is all about.)
Jeremy Birn
 J Birn's gear list:J Birn's gear list
Sony SLT-A99 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-300mm F4.5-5.6 G SSM Sony 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +1 more
Nordstjernen
Impressive - part II
5
LOL! One thumb down for this!
No fanboys are allowed to this forum?
Impressive!
Steve West Veteran Member • Posts: 5,526
These look great!  Finally Sony produces a camera with higher ISO capabilities. 24 MP in FF had to be a winner.  Time to dump my 24 MP APS noise machine!!
I just got my Lightroom updated, and downloaded some of these myself.
The 1600 ISO doesn't fall into what I'd call "high ISO" at all. With a modest amount of noise reduction if looks as detailed as what I'd expect at 100 ISO from a 12 or 16 MP camera.
The 25600 ISO has some noise, but still cleans up very nicely, and looks acceptable for most everyday photography. If I'm at a party, I'd go all the way to 25600 any time it allowed me to use my choice of apertures or shutter speeds.
Wow. Now all I need to do is wait for my a99 to arrive...
Jeremy Birn
brian14478
brian14478 Senior Member • Posts: 3,703
they look great i wnder how long before very low noise and extreme iso 'trickles' down to 2/3 format?thamks for the reference samples,..brian
Michel J Veteran Member • Posts: 4,009
Thanks for sharing.
Do is it 100% crops? If yes, it's impressive.
But you suggest you PP your photos with some enhancement... So, what about the untouched originals .raw shots?
Btw, do you have the same shots with the in-camera .jpg ?
Kind Regards,
Michel J
 Michel J's gear list:Michel J's gear list
Sony SLT-A77 Sony SLT-A37 Konica Minolta Maxxum 7D Sony DT 18-55mm F3.5-5.6 SAM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +10 more
robert614 Senior Member • Posts: 1,322
Here's a link to the original raw files.
Robert
http://fil.io/FL82vTNAq/Different%20ISO%20tests
tesch Regular Member • Posts: 437
I just looked at these in LR4 and I'm not convinced it's worth an upgrade for me yet.
I've been doing a lot of stock photography and noise is my main reason for rejections.  In this group of RAW files I don't think I would get anything above ISO 800 accepted by Shutterstock. Even with the NR turned up to 80, the shadow area in the lower right of the frame doesn't clean up very well.
This is still about 2 stops better than the A77 though as I never shoot anything over 200 on the A77 for stock.
 tesch's gear list:tesch's gear list
Sony SLT-A77 Sony Alpha DSLR-A100 Sony Alpha DSLR-A500 Sony Alpha 7 Sony DT 16-50mm F2.8 SSM +6 more
linslus Contributing Member • Posts: 738
So what camera would be needed to be accepted on Shutterstock with shots above iso 200?
