Sharpest lens?
Started Oct 5, 2012 | Discussions
SirSeth
Veteran MemberPosts: 9,682Gear list
I think both that you listed.
In reply to Starred, Oct 6, 2012
"Sharpest" is a moot point beyond a certain level of bliss.
Seth
What if the hokey pokey really is what it's all about?
wallygoots.smugmug.com
wallygoots.blogspot.com
 SirSeth's gear list:SirSeth's gear list
Olympus E-1 Sony Alpha 7 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Sony FE 28-70mm F3.5-5.6 OSS +4 more
sansbury
Regular MemberPosts: 231
Re: Empirical Data Not a Qualitative assessment
In reply to dcassat, Oct 6, 2012
dcassat wrote:
Alas sharpness can be measured.
Yes, but to what end? The only thing these tests are really good for is relative ranking: they can tell me that Lens B is sharper than Lens A, but they can't tell me how my pictures will look taken with either of them.
As an example, I'm trying to decide whether to upgrade from the kit zoom that came with my OM-D. It's the widely-reviled 14-42, which I chose for its size. Lens tests show that the Pany 14-45 is sharper by a decent margin, and that the Pany 12-35 is slightly sharper still.
The problem is, I don't take pictures of liquor cabinets. So, SLRGear's reviews don't really tell me how often the 14-45 will produce better-looking pictures than the 14-42 (when not pixel-peeping) or whether the 12-35 is enough better to be worth another $900. In fact, they told me nothing useful I couldn't figure out better from listening to actual owners on these forums.
dcassat
Senior MemberPosts: 1,187Gear list
Edge to edge too!
In reply to sansbury, Oct 7, 2012
The thing about the 75mm is that not only is it sharp but consistently sharp from edge to edge.  The 45mm also has this characteristic at f5.6.  Not all lenses, in fact few, can claim this.
So what does it mean?  If you want the best, there it is.  Now some would say it's too clinical or find other faults with a lens of little character
If you're interested in landscape and want consistency across the frame this lens sets that standard.
If you're a portrait or macro or bird shooter then you could feel you want character...
Dan
 dcassat's gear list:dcassat's gear list
Sigma DP1 Merrill Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica D Summilux Asph 25mm F1.4 +5 more
Starred
Starred OP
Regular MemberPosts: 341
Re: Edge to edge too!
In reply to dcassat, Oct 16, 2012
The 75 seems to be significantly sharper than the 60...
75/1.8
60/2.8
TrapperJohn
Forum ProPosts: 12,455
You need to ketchup with the latest lenses
In reply to Detail Man, Oct 16, 2012
From user shots I've seen, both the 60M and 75 1.8 appear to be wicked sharp. But, looking at them, I can't say they could slice a tomato. Crush one, perhaps, but the lack of weathersealing might discourage that activity.
OTOH, those pricey metal hoods could probably cut a nice cylinder out of a tomato. Probably make a pretty good cookie cutter, too.
Geez, is this a disintegrating thread, or what?
mpgxsvcd
Veteran MemberPosts: 8,092Gear list
There is no m4/3s lens that is sharper on center than the 14-140mm @ 14mm
In reply to Starred, Oct 16, 2012
There is no m4/3s lens that is sharper on center than the 14-140mm @ 14mm. It is very good across the whole lens @ 25mm as well.
The 7-14mm is great at everything but 14mm.
The 45mm F1.4, 20mm F1.7, and 25mm F1.4 are no slouches either. However, those lenses all need to be stopped down a bit(ie: F2.0-F2.2) before they become very sharp.
Check out some of the dpreview lens reviews to see what I mean.
14-140mm
http://www.dpreview.com/reviews/panasonicdmcgh1/page17.asp
7-14mm
http://www.dpreview.com/lensreviews/panasonic_7-14_4_o20/4
 mpgxsvcd's gear list:mpgxsvcd's gear list
Panasonic Lumix DMC-LX100 Panasonic Lumix DMC-GF1 Olympus PEN E-PM2 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GH4 +4 more
mpgxsvcd
45mm F2.8 is not good
In reply to mpgxsvcd, Oct 16, 2012
Everyone seems to think the 45mm F2.8 Panasonic lens is a sharp lens. The Dpreview test results show otherwise. I really want to like that lens because I really need a stabilized mid focal length bright lens. However, its test results are pathetic for its price.
Hopefully, the 35-100mm F2.8 will fit my needs. Even though its cost is quite steep.
http://www.dpreview.com/lensreviews/panasonic_45_2p8_o20/3
Ulric
Senior MemberPosts: 3,215Gear list
Re: Sharpest lens?
Starred wrote:
Which M43 lens is currently the sharpest?
Oly 75/1.8, Oly 60/2.8, or...?
According to the test at lenstip.com, the Olympus M.Zuiko Digital 75 mm f/1.8 ED is ​almost​ as sharp as the Voigtlander Nokton 25 mm f/0.95 in the center.
http://www.lenstip.com/351.4-Lens_review-Olympus_M.Zuiko_Digital_75_mm_f_1.8_ED_Image_resolution.html
http://www.lenstip.com/276.4-Lens_review-Voigtlander_Nokton_25_mm_f_0.95_Image_resolution.html
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
Art_P
Veteran MemberPosts: 9,730Gear list
The sharpest lens...
is useless if it's not the focal length you need.
Art P
"I am a creature of contrast,
of light and shadow.
I live where the two play together,
I thrive on the conflict"
 Art_P's gear list:Art_P's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +2 more
gandalfII
Senior MemberPosts: 1,806
In reply to sansbury, Oct 16, 2012
Real world result for pana 14-45.  Pixel peepers can see full size in my gallery
Adrian Harris
Veteran MemberPosts: 3,168Gear list
Re: Sharpest lens?
I use 2 Voigtlander manual primes which are STAGGERINGLY sharp through the entire F-stop range.
90mm Apo-Lanthar f3.5
75mm Color Heliar  f2.5
These are available second hand very reasonably and only need a £15 adapter.
Treat yourself, go get one - or both
reon3010
New MemberPosts: 24
Re: Sharpest lens?
Been using the Nokton 17.5...they say its one of the sharpest from f2-f4...panny 20mm is also one of them....the 60mm comes into play too...
exdeejjjaaaa
Veteran MemberPosts: 7,469Gear list
Re: 45mm F2.8 is not good
DPReview is the last place to go to see any test results :-)... they are good in terms of blah-blah-blah writeups... but if you actually want tests you go to places like DxOMark, SLRGear or similar... no wonder that DPReview abandoned its testing and instead decided to cooperate w/ DxOMark...  plus the question is - at what sensor to target distance you are going to test a macro lens ? that makes a difference when you are talking about macro lens which is optimized to deliver its best for macro work first of all and not necessarily keep the same at a longer distances.
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +19 more
Jon Stock
Senior MemberPosts: 1,608Gear list
Lens rentals has tested lots of micro 4/3rds lenses
In reply to Starred, Oct 17, 2012
Standard range:
http://www.lensrentals.com/blog/2012/05/standard-range-micro-43-imatest-results
Wide angle:
http://www.lensrentals.com/blog/2012/05/wide-angle-micro-43-imatest-results
60mm
http://www.lensrentals.com/blog/2012/09/quick-look-at-the-olympus-60mm-f2-8-macro
12-35mm
http://www.lensrentals.com/blog/2012/06/a-weekend-with-the-panasonic-12-35-f2-8
No 75mm test yet.  Too bad, I am looking forward to seeing it tested. My 75mm seems like the best lens I have for sharpness. Better that my 12-35mm, 25mm 1.4 and my 45mm.  It seems as good as my 4/3rds 50mm macro.
Jon
 Jon Stock's gear list:Jon Stock's gear list
Epson R-D1x Olympus E-5 Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +12 more
JCB123
Senior MemberPosts: 1,248Gear list
Re: You need to ketchup with the latest lenses
In reply to TrapperJohn, Oct 17, 2012
It certainly is. - I find that the weather sealing on tomatoes is actually quite good - for a while.
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
jim stirling
Veteran MemberPosts: 7,356Gear list
Re: Sharpest lens?
In reply to ppotka, Oct 17, 2012
ppotka wrote:
Lumix 20mm is my most used lens but no, it has not same quality wide open as ZM 45 or 75mm. It does not come even close to ZD 12-60mm zoom at same apertures and FL.
-p-
pekkapotka.com
The 12-60 is F3.2 at 20mm and is easily outperformed by the 20mm even with the 20mm set at F2 especially at the extreme edges. I owned the 12-60 until recently and have had the 20mm since the GF1 came out, so I am comparing results from using both lenses on the same cameras.
Here are the slrgear charts showing the respective performance with the 12-60 at F3.2 and the 20mm at F2
The 12-60 is an excellent kit lens for FT and its only lets downs on mFT are its relatively large size and weight combined with its poor AF performance. I think there is a certain degree of snobbery amongst some Olympus users who seem to work under the impression that no one else can make decent lenses. I am certainly not claiming the 20mm is the sharpest just that it easily manages to in this instance out do the zoom.
Horses for courses, a zoom is far more flexible but for me the small primes combined with small mFT bodies eloquently define the attractiveness and worth of a smaller system.
Jim
 jim stirling's gear list:jim stirling's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Nikon D810 +12 more
steveTQP
Regular MemberPosts: 169Gear list
In reply to TrapperJohn, Oct 25, 2012
Hi Trapper. FYI, I believe the Oly 60 Macro does have weather-sealing. I too, am interested in maximum sharpness, which is why I'm considering the OM-D EM-5 with the Oly 60 macro and/or the Oly 75. Thanks.
Steve Solomon steve@totalqualityphoto.com
 steveTQP's gear list:steveTQP's gear list
Nikon D5300 Fujifilm X-T1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +1 more
grumpyolderman
Senior MemberPosts: 1,085
Re: Lens rentals has tested lots of micro 4/3rds lenses
In reply to Jon Stock, Oct 25, 2012
Am I getting this wrong, but the lens rental test shows again the 20mm is the sharpest tool in the box? even wide open, of course 1t 1.7 it get beat by some who only go to e.g. 2.4, but at e.g. 4, unbeaten?
I found it to be very sharp, even wide open, hence my wife hates it...
JL
JL
dotborg
Veteran MemberPosts: 8,215
Re: Sharpest lens?
In reply to Starred, Oct 25, 2012
It's funny how that's always the most (only?) important aspect of a lens. To hell with angle of view, overall contrast, flare resistance, maximum aperture, light falloff, distortion, aberration, bokeh rendition, etc.
Johann D
Contributing MemberPosts: 608
Re: Sharpest lens?
In reply to dotborg, Oct 25, 2012
Every lens has it's use. It's up to the photographer to figure out that use to get the best out of it. I have an OM 55 f1.2 that is pretty soft, but takes beautiful photos. Portraits and still life are it's forte.
Carry on with numbers and charts...
