Noise Pattern Evaluation: D800/E, D600, A99
7 months ago
I managed to snag this little demonstration showing a noise pattern comparison between the A99, Nikon D800 and 800E as well as the D600. Samples were all taken from ISO6400 NR0 in RAW.
Make of it what you will, but I think the A99 holds its own quite well against the competition.
Re: Noise Pattern Evaluation: D800/E, D600, A99
In reply to JohnBee,
7 months ago
This shows my initial thoughts. Better noise performance than D800 and about the same as the D600.
Thx for sharing.
7 months ago
If this is what to expect, I should preorder the A99 today!
There is a lot to like with this new camera. Better & more reliable AF than the A77 (excellent when configurated for the actual situation), better vignetting control than the A900, more detail due to the lower sensor/new AA filter design, lightweight and not that bulky. Even if the noise level isn't significantly better than the A900 I am sold!
A note on the sample: Sony 50 mm f:1.4? Hot spot? Not even lit background?
7 months ago
The A99 seems to have lowest noise of these 4 cameras. I think it beats the D600 by a very small but noticable margin.
In reply to mick232,
7 months ago
I don't know how scientific your test might be, but for what I see, A99 clearly has the best output of this bunch. I look forward to owning one very soon..!!
7 months ago
Whats with the non even lighting across the A99 shot? Looks a little weird
7 months ago
Can you also include the Nikon D4 and D3s.
7 months ago
johnbee wrote:
[...] Samples were all taken from ISO6400 NR0 in RAW. [...]
Thanks for sharing this, John.
Since we know that the lighting conditions affect noise level a lot, this test proves nothing, until we know more about the test protocol.
If now the 4 cameras had exactly the same protocol (what we guess...) it would be very encouraging!
Kind Regards,
Michel J
In reply to Emopunk,
7 months ago
Judging the visual appearance, I would agree. However, I actually just wrote a little program that calculates the standard deviation for the R,G,B channels. If the ideal image here would be uniform grey, calculating for each pixel how much it is off from grey and summing that up (squares actually) should allow us to estimate the noise, right?
The result: the A99 came out worst.
But I don't think it is due to the noise. If you look closely, the A99 image seems to have some kind of vignetting effect. Slightly brighter in the middle than on the borders. Unfortunately, this probably renders the test useless at least for the A99.
In case you are interested, here's the result (lower = better):
d600.png: 6.7744590090235 6.010670902528859 8.070111508983086
d800.png: 8.7797877073513 7.287356209770788 10.947690877804124
d800e.png: 8.398218004457668 7.149128388812794 10.186271161400114
a99.png: 10.859560376781483 9.218291222220033 10.923016082630252
7 months ago
If I only take the center part of the A99 image, the result is:
a99_2.png: 7.872076207344561 6.568750458448936 9.543053084661068
Worse than D600, but better than D800(e).
7 months ago
mick232 wrote:
Judging the visual appearance, I would agree. However, I actually just wrote a little program that calculates the standard deviation for the R,G,B channels. If the ideal image here would be uniform grey, calculating for each pixel how much it is off from grey and summing that up (squares actually) should allow us to estimate the noise, right? [...] If I only take the center part of the A99 image, the result is [...] Worse than D600, but better than D800(e)
Of course!
Since we know that cheating to reduce noise does not help to get the best color rendition, you demonstrated the opposite!
Compared to Alpha DSLR-T's, Nikon has never been as good in these colour features:
It's probaly due to the fact of the Sony heritage:
http://sensing.konicaminolta.us/products/cl-500-illuminance-spectrophotometer/
Kind Regards,
Michel J
7 months ago
mick232 wrote: I actually just wrote a little program that calculates the standard deviation for the R,G,B channels. If the ideal image here would be uniform grey, calculating for each pixel how much it is off from grey and summing that up (squares actually) should allow us to estimate the noise, right?
I assume your program works on the raw data (as does RawDigger), otherwise all bets are off. In that case the mean is supposedly the 'uniform grey' level and you are calculating the patches' standard deviation. Make sure 'uniform grey' values are the same for all cameras you wish to compare: if not it's best to compare SNRs.
Jack
Re: Noise Pattern Evaluation: D800/E downsampled to 24MP?
7 months ago
Were the D800/E downsampled to 24MP and the data captured by the same outfit (which one?) with the same parameters and methodology? If not we are really looking at oranges and smugly think that their skin isn't as smooth as our apple's
In reply to Jack Hogan,
7 months ago
Jack
Good idea. But what Jack suggest dosen't work, since we know that the three channels (RGB) are not aligned (in-camera)
Here before demosaicing:
Here what you see on the LCD:
It seems to be aligned but it's not...!
Btw, the level of noise is not the same for every channels. Here:
(Red VS Green (dcraw -h processing))
Every factory had his own soup (due to a compromise between daylight and thungsten or so...)
So, most of the time the luminance channel is blown up. So we can't deduct something right from that.
See the thread of Iliah Borg for more.
Kind Regards,
Michel J
In reply to Michel J,
7 months ago
Michel J wrote: But what Jack suggest dosen't work, since we know that the three channels (RGB) are not aligned (in-camera)...
And?
Sure we can, perhaps not from these patches (see my other post), but in general mean and standard deviation measurements of the raw values is how one determines SNR and DR performance. Raw values only came in R*, B* and G* flavors, and studio samples are designed not to blow them where it counts (the patches above are not blown). Assuming all other things are equal (including the light source - see my other post) measuring and comparing data from those is the first step in fairly comparing the noise performance of two cameras.
Jack
7 months ago
And?
Jack
Ok you can! If, and only if you:
Then, you can get what you are looking for (a near to perfect grey pattern). I seriously doubt the O.P. nor mick232 have done that?
Just my two cents.
Kind Regards,
Michel J
7 months ago
Here's another pixel peeping tidbit that I found interesting:
ISO6400, RAW, ACR, RGB
ISO6400, RAW, ACR, Blue Channel
In this detailed examination, it would appear as though the A99 sample is showing slightly more chroma noise in the blue channel than with the D600 sample toe to toe. Though the differences seem quite small to the naked eye.
That being said, I'd say the A99 will likely do very well for itself.
7 months ago
Thanks for sharing again John.
Well I don't the cause of this, but one of them is the fact that wavelength of the blue chanel have less relative power (here the D65)
Source: wikimedia.org/wikipedia/commons/d/d0/SPD_D65.png
So... As usual, by ETTR and filtering the luminance channel, that can increase the relative power of the Blue channel (and according to the filter, also the Red if so...)
It would be interesting to apply the Iliah Borg workflow at this point, because we have really no idea of what Nikon do with this blue channel and if the colour channels are already at the same level in-camera to compensate something (or not) before demosaicing. imho...
Kind regards,
Michel J
Re: Noise Pattern Evaluation D600, A99
7 months ago
Michel J wrote: we have really no idea of what Nikon do with this blue channel and if the colour channels are already at the same level in-camera to compensate something (or not) before demosaicing. imho...
Clearly the blue channel, having a lower absolute QE, would exacerbate the weaker camera's performance. But without disturbing Mr. Borg, as long as the light source, testing methodology and photographic parameters are the same we really do get an idea of what the relative performance of the two cameras would be like - in this particular situation. It would be useful to know what the situation is, though (John?).
