Sony A99 ISO6400 RAW files look spectacular....
Started Oct 5, 2012 | Discussions
(unknown member) Veteran Member • Posts: 3,992
12
I've been working with several high ISO RAW images and I have to say that I am very impressed with what the A99 files have to offer. From what I've seen, the ISO6400 are substantially better than the Pentax K-5 at the same sensitivity.
Full size image can be seen here
Keep in mind that this image was processed with default settings, and that output will likely improved with discrete processing.
Pentax K-5 Sony SLT-A99
The_Wicker_Man
The_Wicker_Man Senior Member • Posts: 1,521
Re: Sony A99 ISO6400 RAW files look spectacular....
Very nice - care to forward that to Ma55l for his analysis?
i know what i know, which is a fraction of what i don't
tbcass
tbcass Forum Pro • Posts: 23,685
Since you used +1.3 EV the true iso is only about 2800 or so.
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony SLT-A77 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +8 more
Nordstjernen
Nordstjernen Veteran Member • Posts: 6,876
I know I should not comment this, but I really hope that Ma55l will be able to make an analysis some day -- good for him and better for us!
 Nordstjernen's gear list:Nordstjernen's gear list
Sony SLT-A99 Sony Alpha 7
Nordstjernen
Except if this was needed to compensate for reflective light metering error, which I doubt.
Amateur Sony Shooter Veteran Member • Posts: 5,417
Looks like aggressive NR applied to it. Perhaps this is a better ISI 6400 sample:
http://forums.dpreview.com/forums/post/50001476
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +5 more
danny006 Senior Member • Posts: 1,080
Looks very good indeed !
 danny006's gear list:danny006's gear list
Canon EOS 6D Canon EOS Rebel T6s Samyang 14mm F2.8 IF ED MC Aspherical Sigma 150-600mm F5-6.3 DG OS HSM | S
(unknown member) OP Veteran Member • Posts: 3,992
PS.  I've since updated the image.
As it turns out, the full size link isn't working as intended.
jakobr Regular Member • Posts: 181
Link to the full review including raw files
http://prophotos.ru/reviews/14787-polev ... ny-slt-a99
Hi tbcass,
To my knowledge, ev adjustments has no impact on ISO values.
that being said, I'd also add that this image was slightly underexposed also. And so I can't claim that it was shot to the right either.
Emopunk
Emopunk Regular Member • Posts: 161
On my program, histogram looks perfectly fine. I don't know what you mean.
 Emopunk's gear list:Emopunk's gear list
Sony Alpha DSLR-A200 Sony SLT-A99 Sigma 70-200mm F2.8 EX DG Macro HSM II Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro
Kappels Contributing Member • Posts: 796
No it is not a better high ISO shot because it was shot @f8.
This would never be a "real life" high ISO condition. Using high ISo is for a reason! I usually need ISO6400 at a volleyball game where I have to shoot with my lens wide open (f2.8) and a shutter speed that is just about enough to freeze the action. Once I have reached my "limit" with aperture and speed only then do I increase the ISO.
If I can use an aperture of f8@ 6400 I would be much better off to shoot @ f2.8 and an ISO of in the range of ISO800 which comes to about the same.
Most of the high ISO shots posted so far are NOT real life scenarios as most of them use higher f stops.
Stef.
 Kappels's gear list:Kappels's gear list
Canon PowerShot G10 Sony Alpha DSLR-A100 Sony Alpha NEX-5 Sony SLT-A77 Sony SLT-A99 +21 more
This would never be a "real life" high ISO condition...
Consider this:
If you look at the DOF effect of the actual subject(not the mirror reflection), you will find that it is very carefully rendered with respect to the reflection in the mirror. Therefore, if we take the subject distance and DOF effect into consideration we end up with a very real scenario.
That being said, I'd also point-out that this doesn't mean you own high ISO needs aren't valid either(as I'm sure they are). Though it does help demonstrate that there is much more to photography in terms of needs and circumstances. And one way that I've found to help appreciate that is to try and replicate someone else work. ie. this particular portrait setup becomes a good example of what it can take to get the shot. To which I'd add, may not always be apparent.
Hope this helps.
PS. I've shot many portraits at ISO6400 myself, though I'd try and avoid it based on the amount of work needed to make the images usable afterward.
Allan Olesen Senior Member • Posts: 3,357
johnbee wrote:
Hi tbcass,
Noise is mainly caused by a lack of light, not by the actual ISO setting.
If you take a photo at ISO 3200 with no exposure compensation, and another photo at ISO 6400 with +1 EV exposure compensation, they will get the same amount of light and the same noise once they have been adjusted to the same light level in PP.
In my opinion it is ridiculous to compare noise at the same ISO setting on different cameras with different light metering and different ISO norm. What we should compare is noise at the same amount of light (same scene lightiing, same aperture and same shutter time).
I'd say this works best when EV compensation results in exposing to the right. However since this image is underexposed, I'm thinking this wasn't the case here.
Though I do agree on the issue of having more light in a scene by stopping down. And though this may have been a possibility, I'd again lean on the fact that the scene was underexposed as an indicator that it was likely a legitimate setup.
That being said, there is one other ISO6400 images in the set without EV compensation showing the same amount of noise. And so I'm guessing that were looking at a legitimate noise performance examples in this case.
OntarioJohn
OntarioJohn Senior Member • Posts: 1,959
I like the photo.  But then I'm no spring peeper.
Retired forensic photographer.
London, Ontario, Canada.
 OntarioJohn's gear list:OntarioJohn's gear list
Konica Minolta Maxxum 5D Sony Alpha DSLR-A100 Sony SLT-A77 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM +3 more
GuyMcKie Contributing Member • Posts: 600
With this composition a compensation for the metering system is needed.
Luminance EV of the scene is -2,44, exposure 1/80s at f1.8. Thats very low light.
Made a version with some more tuning in LR and adjusting contrast and the tonal curve in PS. Finally I added some glow to compensate for the hard contrast of the ZA 135.
Steve FStop
Steve FStop Senior Member • Posts: 1,015
Thank you for the link....there are some great sample images on Page 4.
 Steve FStop's gear list:Steve FStop's gear list
Apple iPhone 6
