How little camera sensors have changed in 5 years
Started Sep 28, 2012 | Discussions
J Mankila
J Mankila Veteran Member • Posts: 4,234
The practical differences...
Tommot1965 wrote:
Robin Casady wrote:
Too technical for you? Need to have it explained?
yes..and yes please...but without condescension
It's showing the photographically usable dynamic range at various ISOs. In practical terms, it shows you how much you can dig up the shadows until they become too noisy to be considered useful.
For the differences to really show, you're expected to do some tone mapping with your images (not talking about special software, but rather tweaking of the tone curve in the raw converter). Especially in B&W photography it's extremely useful, as the colours don't get washed away (although masters will create impressive, realistic HDR images in colour, too). The D700 isn't very good at that, whereas the D800 is one of the best. No, not really - it is the best, medium format digital backs included (to my limited knowledge).
regards
Janne Mankila, Finland
Alejandro Daz del Ro Fery
Alejandro Daz del Ro Fery Veteran Member • Posts: 3,735
Re: How little camera sensors have changed in 5 years
Maybe the same bodies ... but sensors? They've changed the same than from D200 to D700.
Overall DxOMark sensor scores ... D800/E (95/96), D700 (80), D200 (64).
Tommot1965 wrote:
stany buyle wrote:
Tommot1965
How little camera sensors have changed in 5 years.
Several people try to convince themselves that their old gear is as good as the latest, but unfortunately it's not.
Bingo.
Trying to make a point with a comparison of some downsampled pics of bottles, cards and coins in perfect studio light with a 5 year old 12mp camera against a 24 or 36 Mp cam doesn't prove anything. Even my 10 or 12 year D1H will keep up quite well in such a comparison and that kind of light...
If you compared the potential of each of your mentioned cameras about resolution, detail, DR and noise(noise in real lowlight) your conclusion and results would be very different.
Kindest regards.
Stany Buyle
http://www.nikonuser.info/fotoforum
I like better one good picture in a day than 10 bad ones in a second..
Stany
I agree with you mate..but im sure many upgraders try and convince themselves that the new camera they have just done $3000 on will make their images so much better than before..something Im sure is not the case
also as good as your D1H may have been..I doubt very much it could have held its ground in the comparisons I've made...in fact a D300s thats much better than a D1H is terrible at 6400ISO..so im pretty sure the D1h would have been worse
Im not trying to say that the current sensors aren't better..its just that over a D700/D3/D3s theres not been much improvement in 5 years ..and people seem to think that 5 years is a huge amount of time in the Digital world ..something im not seeing too much off when comparing a D600/800 to the aforementioned
Un saludo.
stany buyle Senior Member • Posts: 1,957
Tommot1965
I thought it was clear that mentioning my collectable D1H in such a comparison was meant ironic...
I use D800E, and the difference in potential compared to my D700 is simply enormous, just because of the sensor.
Kindest regards.
Stany Buyle
 stany buyle's gear list:stany buyle's gear list
Nikon D1
Robin Casady Forum Pro • Posts: 12,898
Re: The practical differences...
To add to this description, the chart is interactive. You can select or deselect cameras on the right. Then compare their dynamic range. Roll over one of the dots on the chart line and you will see the ISO & PDR numbers.
Everything is relative, but I would give the D700 more credit. I would say it is good, the D2x is poor, and the D800 is rather amazing for such a high res sensor. The D2x produces great color in controlled lighting, but dealing with bright scenes and dark shadows is challenging.
Another thing that is useful about the chart is that you can see how much dynamic range you lose as you increase ISO. At 100 ISO the D800 has over 11 stops of useful dynamic range. At 800 ISO it drops to 8.6 stops, and a 3200 ISO, it is down to 6.8 stops.
At base ISO (200) the D700 only has 9 stops. However, the difference between the D800 and D700 narrows to about half a stop at 800 ISO.
The best the D2x can do is 7.8 stops; dropping down to just under 5 stops at 800 ISO and less than 3 stops at 3200 ISO.
Noise is not the only consequence of using high ISO. Loss of dynamic range is also significant.
http://home.comcast.net/~NikonD70/Charts/PDR.htm#D2X,D700,D800
lancespring Veteran Member • Posts: 3,843
I'm amazed that no one corrected your math error
The D700 was released back in the Fall of 2008.
Dude, that is 4 years ago, not 5.
 lancespring's gear list:lancespring's gear list
Sony Cyber-shot DSC-RX10 Nikon D600 Sony a6000 +1 more
JohnMcL7 Senior Member • Posts: 2,085
D3 was launched in 2007 with the same sensor
I assumed it was referring to the D3 which uses the same sensor as it was launched in 2007 rather than 2008.
John
Re: D3 was launched in 2007 with the same sensor
As DxOMark, the D3 and D700 have different low light ISO and overall scores.
Anyway, 5 or 4 years in HW or SW development are notorious.
JohnMcL7 wrote:
... D3 which uses the same sensor as it was launched in 2007 rather than 2008.
John
Un saludo.
Clark Hampton
Clark Hampton Senior Member • Posts: 2,856
I can still get to the store in a Model T Ford.....but
incremental improvements to the internal combustion engine makes newer much better.
But I agree with you that 5 years ago, sensors produced stunning results. Howevre, they were not as good at dynamic range, speed, noise, etc.
I tend to use a digital camera for about 5 years before upgrading. It is right around that point where I am so glad I did.
I plan to use my D800 for a long time. Many pros used their D1 and D1x for a very long time.
But no one is being brain washed. The newer cameras are better.
 Clark Hampton's gear list:Clark Hampton's gear list
Nikon D100 Nikon D200 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 135mm f/2D DC +4 more
Tommot1965 OP Contributing Member • Posts: 995
J Mankila and Robin...thank you for your explanation and guidance when talking about the dynamic range chart vs the relative ISO...and Robin I know the thread title reads " How little camera sensors have changed in 5 years" and that throws all sorts of comparisons on the table...but to be honest ,in my mind only thinking of the High ISO type shots...and as you say that at 800 ISO there’s only around Half a stop between a D800 and a D700...not much really…so apologies for not making that clear with a perhaps misleading thread title
also when I’ve seen many posters here at DPR explaining the importance of the high ISO as a reason to upgrade or not , I find it quite a compelling argument that the capabilities from the current sensor to one that’s 5 years old haven’t changed much in that time
Don’t get me wrong D800 owners..I’m not knocking your new camera…just pointing out that in a lot of shots taken at the higher ISO you will see little difference between today’s sensors and the one in either the D700 or D3…and perhaps a tad behind the D3s ?...hence “How little camera sensors have changed in 5 years"
However the shot that mako 2011 posted of the mountain bike forks does show a difference to me between a D700 and a D800….so more comparison shots would be good to get a handle on that
But looking at a D700 versus a D300s..the difference is night and day at 6400ISO…Im not seeing that huge leap from a D700 to a D800 though..Again talking higher ISO shots here.
But to brutally blunt….I’ve yet to see many D800 if any images that couldn’t have been captured equally as well on a D3/D700…unless your cropping huge that is..then 36 MP shine through..so more latitude in that area in PP is a welcome addition I guess…but that does come in a trade off as well, between huge file sizes and lower framed rate…but I digress as my original comparison was about the higher ISo shots these cameras produce
 Tommot1965's gear list:Tommot1965's gear list
Olympus E-M1
John
thanks for pointing that out John..and yes your correct ....
Olympus E-M1
stany buyle wrote:
Tommot1965
Kindest regards.
Stany Buyle
sorry Stany..I missed that from your origanl post ...but thanks for pointing it out, as I did have a WTF moment when you added the D1h to the table
Olympus E-M1
freddyNZ Senior Member • Posts: 2,611
gl2k wrote:
Totally agree.
The biggest jump in IQ is from an old DX (eg D300) to a new FX system at high ISO and DR.
Wow, the D300 is hardly "old" DX.
In some ways the OP's heading is correct.
D2x -> D300 you gained about 1.6 EV
D300 -> D7000 - you gained about 0.7 EV, but a nice little boost at base ISO 100.
http://home.comcast.net/~nikond70/Charts/PDR.htm#D2X,D300,D7000
All other things being equal, FX will always have an advantage of more than 1 EV over Dx.
Of course if you believed every claim made in these forums about every new camera since the D1, we'd all be shooting at ISO 1,000,000.
moving_comfort
moving_comfort Veteran Member • Posts: 8,203
Couple problems with your comparison
Your example images are taken in good light and are not really large enough to show much of a difference.
Take a more light-challenged shot, then downsample the D800 to 12MP, take an equal-area crop of both the downsampled D800 and native-size D700 shots, and compare those crops. You should see more detail and finer noise-grain in the D800 shot.
This translates directly to a more 'real', pleasing print at the same sizes.
The D800's finer noise tends to clean up better without destroyng detail when you apply NR as well. (The bike fork crops in this thread are pretty good examples, and show what I see when shooting my D700 & D800 side-by-side.)
That said, the D700 didn't all of a sudden become a crappy camera because the D600/800 appeared It's still a fantastic low-light performer with magical AF and sweet pro features and build. And it's a lot easier on the workflow and storage.
Here are a few of my favorite things...
---> http://www.flickr.com/photos/95095968@N00/sets/72157626171532197/
 moving_comfort's gear list:moving_comfort's gear list
Pentax K20D Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 20mm f/2.8D +10 more
VadimOm Senior Member • Posts: 1,903
I did the same thing, except, I pixelpeeped at 100% and put them side by side:
D800, D4, D600 and D700. Each one was opened (RAW) in Capture NX2 and slight sharpening (not USM, the in-camera sharpening) was added to each file to make details show up as best as possible without destructing any deatail. I figured it would be fair comparison if I adjusted all of them to look their best because each camera has different strength AA filter, so you have to account for that. Anyways, I don't recall exact values, but I think I went from +3 to +5 sharpening on D800, about the same on D4, +7 or +8 on D600 and D700 would only go to +4 before sharpening started doing more damage than good. Here you go, look at the dime, compare level of details.
D800, D4, D600, D700 at ISO 12800:
With D700 being what, 3 years old? The difference is quite noticeable.
But what if you're not into high ISO shooting? Let's compare D800 to D3s, which was until recently the king of everything in Nikon's camp:
D3s, ISO 100:
D800, ISO 100 (same lens, same S and A settings):
The difference in DR and level of details is stunning.
So, I'd say, the progress is quite noticeable
antoineb Veteran Member • Posts: 6,032
you downsample before comparing?
Uh, I don't get it: you take a higher-res image, then take away the higher-res, then claim that there was no progress.
You could also take a current processing chip, take away its extra million cycles, and conclude that processing chips haven't progressed.
And so on.
I don't see the point of testing newer products by taking away what they have added, before concluding that there was no progress.
But perhaps it's just me?
 antoineb's gear list:antoineb's gear list
Panasonic Lumix DMC-FZ8 Panasonic Lumix DMC-FZ18 Panasonic Lumix DMC-ZS7 Olympus TG-610 Nikon D7000 +5 more
Oly Canikon
Oly Canikon Senior Member • Posts: 1,079
Re: you downsample before comparing?
And so on.
He said later that was exploring the claim that "even downsampled images look better". However the conclusion that there has been "little change in 5 years" comes out of left field.
primeshooter Senior Member • Posts: 3,160
Re: Couple problems with your comparison
Well said. I loath these dumb comparison shots at web resolution shot in good light to test High ISO. Guess what if I shoot at ISO 6400 in broad daylight noise is non-existant more or less!
Riker D
Riker D Contributing Member • Posts: 802
You should get it. If you take all the above shots and do some normal processing that you would be doing anyway it looks to me that the D600 is holding its own quite well. What the above poster is showing is that the D600 looks to be an improvement and it is!
Photo eye
 Riker D's gear list:Riker D's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E PZ 18-105mm F4 G OSS Sony FE 35mm F2.8 Sony Alpha 7R +5 more
