How little camera sensors have changed in 5 years
Started Sep 28, 2012 | Discussions
Tommot1965 Contributing Member • Posts: 995
ok..after I saw on the main page that the D600 had new studio test done..I thought Id see how the D700 stacks up against the new kids on the block in regards to High ISO
so I downloaded the D600, D800 and D700 files at ISO 6400..then I down sampled the higher res files to match the D700 file..then saved the new files at the same Jpeg quality.
after all this I did a blind test to determine the one I liked best...Ill let you lot have a look...needless to say a 5 year old FX sensor still rocks at high ISO and we are all being brainwashed into needing high MP cameras and so called better ISO ..LMAO
take a look and see what you reckon and to me the D700 files look great
 Tommot1965's gear list:Tommot1965's gear list
Olympus E-M1
Nikon D600 Nikon D700 Nikon D800
Oly Canikon
Oly Canikon Senior Member • Posts: 1,079
Re: How little camera sensors have changed in 5 years
Any chance that affected your result
showmetheprime
showmetheprime Regular Member • Posts: 193
Re: Not sure how you can say that?
Five years ago users of Nikon were pretty much limited to 12MP. Now we have improved quality at 24MP and 36MP that only months ago was limited to a £5k D3X. I'd say there have been massive improvements to provide resolution and quality for the price...
Robin Casady Forum Pro • Posts: 12,898
Is high ISO all you care about? How did you get brainwashed into thinking that high ISO was the most important factor in photography?
LMAO. You think a 900 x 600 JPEG is a good way to compare sensors?
Brainwashed? LMAO. Being able to produce a 20x30" print with the detail of a D700's 12x17" print is an excellent improvement in my book.
The D700 produces excellent images, but that doesn't mean there haven't been significant improvements in sensors.
Here is one significant way the D800E sensor has improved over the D700:
http://home.comcast.net/~NikonD70/Charts/PDR.htm#D800E
Robin Casady
http://www.robincasady.com/Photo/index.html
gl2k
gl2k Veteran Member • Posts: 3,232
Totally agree.
The biggest jump in IQ is from an old DX (eg D300) to a new FX system at high ISO and DR.
An often underestimated role plays the RAW development SW. New versions of ACR and NX2 do a lot better job than their old versions.
gl2k
And how many photogs do really take advantage of this improvement ? The visual improvements are quite subtle and most hobby photogs wouldn't recognize them.
Not to mention that hardly anyone really makes use of 36 mp.
DRode
DRode Senior Member • Posts: 2,815
I've seen many, many shots comparing the D600 to the D700, D800 and D3s. I've seen up sampled and down sampled comparisons and I cannot find a single instance where I thought the D700 noise handling was better than the D600. The D800 as as good or better than the D600 in every instance.
My intention was to buy a D700 this winter because it's such a good body especially for low-light work. For a little more than the cost of a used D700, I can have a new D600 with better noise handling, much higher dynamic range and better edge acuity.
The D700 is a really good body but the D600, based on the samples I've seen, is capable of greater IQ despite the cheaper build.
It's a tough call for me. A better overall body versus better IQ.
-Dan Rode
http://rodephoto.com
Art is not real. Art is an artifice, an invention, the product of the imagination and the creativity of the artist. In short, expecting art to faithfully duplicate reality is a misconception, a misunderstanding of the very purpose of art. - Alain Briot
ZAnton Contributing Member • Posts: 589
If you shoot under perfect lighting - then no
but if you need a DR, or you have to pull shadows on an image ISO3200, then differences come out.
 ZAnton's gear list:ZAnton's gear list
Nikon D600 Tamron SP 70-300mm F/4-5.6 Di VC USD Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G Tamron SP 24-70mm F2.8 Di VC USD
Tommot1965 OP Contributing Member • Posts: 995
I dont think so..as everywhere on this forum people with a D800 make a point of saying that once downsampled a D800 has obvious improvements in High ISo limits compared to a D700 ..so thats what I did to the high MP images...but even when you view the images untouched side but side I cant tell any difference to my eyes..until you hit the Zoom button then more MP shine through.
Olympus E-M1
RP McMurphy Contributing Member • Posts: 571
You have seen at 12mp that the d800 or d600 is as good as the d700 which is what many are saying was not the case so, 1st point, you prove that a 36mp sensor can achieve the same noise handling as a 12mp file
2nd point, you say when conditions are right the D800 can resolve incredible detail, that couldn't happen 5 years ago so things have moved on
Better IQ
The quality of the body does not show up in photographs
-Dan Rode
Robin Casady wrote:
Is high ISO all you care about? How did you get brainwashed into thinking that high ISO was the most important factor in photography?..
LMAO. You think a 900 x 600 JPEG is a good way to compare sensors?...
Robin Casady
no but in this disscusion it about high ISO handling
.No I dont think they are 900x600 Jpegs 1600x1068 but even before the Jpg save in PS there was no differance before you hit the zoom button
and true more MP will give larger print sizes
Olympus E-M1
Im sorry but thats not the point people were making when all the talk of downsampling was being banded about and still isnt ..it because when the D800 appeared and people were viewing the files at 100% at 36mp..the conclusion was the nosie looked worse..and of course it did when viewing at 100%....because of the added resolution..but once viewd at the same res the D800 looked better than the D700...something Im not really seeing in the above images
yes I agree with your second point...
Olympus E-M1
showmetheprime
+100 unless you want it for a war zone
RP McMurphy wrote:
Better IQ
-Dan Rode
DRode
That's the way I'm leaning. As much as I would prefer the D700 handling -- it's nearly a twin to my D300s -- I can live without it. I can even live with the small cluster of AF points. The 1/200 flash sync speed is to only real issue that will have an affect on images (rather than convenience).
I do earn money from photography but I don't do it full-time or earn my living from it. I can afford to be inconvenienced.
RP McMurphy wrote:
Better IQ
Mako2011
Mako2011 Forum Pro • Posts: 20,141
photography freeway
Robin Casady
Then you should go back and print the files at 20x30 and see if things changed.
If you compare in that way...then even a smart phone is close enough.
And that is where you see the real jump. If you never print or crop big then yes...you can get buy easily with older tech and a good NR program.
If you really don't take advantage of the improvement then it really isn't needed in your case.
My new Acura is phenomenally better tech wise than my 10 year old one. If I never get off the free way at 65MPH....i would never know. Get off the photography freeway and run the curvy back roads with a little speed and a sideways slide or two.
Mako2011
And
Oops, I forgot where the biggest dif shows up.....drive in the dim light of sunset or sunrise. Hang out in zone 3 and 7 for a bit
Re: photography freeway
Robin Casady
no I dont belive a smartphone image would be close..compare a D300s at 6400ISO...and thats not even close...in fact its pretty bad..the D700 on the other hand is pretty good
yes I agree if your cropping a huge amount or printing massive the more MP will be a advantage....I do crop...but only print to A3+ size as thats all my printer can handle
but I digress...my point was at ISO 6400..theres not much in it between todays bodies and a body that was released 5 years ago
Olympus E-M1
Robin Casady
oh thats a shame..I just hit the link provided hoping to see a great photo backing your point...but instead it was a chart ..bummer
Olympus E-M1
Mako2011
Robin Casady
At the display size you are using here (in my browser window) to compare...in good light with a little PP...nope a smart phone actully will keep up
Then you really are not doing anything that pushes the limit at all. Shoot in Dim light at Iso 6400 or high crop 50% and print at A3+. Push the shadows for more. The dif really starts to become obvious.
In the way you compare...no not a lot. Many folks don't really push the limits of the technology. Those that do produce some stunning results that can't be obtained with last gen tech. But, i agree, not many really go there.
