Some possibly dumb Q questions
Started Sep 26, 2012 | Discussions
ispress Forum Member • Posts: 96
Almost ready to pull the trigger on a Q10, but I have just a couple of questions of current Q owners (I'm assuming these details won't change for the 10). Thanks in advance for indulging. Sorry if these are dumb.
1. If you attach a filter, can you see what the filter is doing through the LCD screen? In other words, if I'm using a circular polarizer, will I be able to get a live view as I twist it?
2. Similarly, for in-camera "effects," do those display in live view?
3. Unrelated, are there reliable, cheap third-party batteries available for the Q?
Thanks again.
 ispress's gear list:ispress's gear list
Fujifilm X-E1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
Pentax Q10
snostorm Senior Member • Posts: 2,035
Yes, yes, and yes
Hi ispress,
There are usually no dumb questions.
1. Since it's "live view", any filters will effect the light getting to the sensor, so you'd see the effect on the LCD.
2. All of the in-camera filter effects display on the LCD in LV -- pretty cool!!
3. It's a pretty commonly available battery -- luckily -- and they can commonly be found for under $6 USD each on Amazon or Ebay. I bought 1 Pearstone from B&H and 3 from Wasabe with their 120V home / 12V car charger. I've had them about 1 year, and they all are working pretty much like the original.
Scott
 snostorm's gear list:snostorm's gear list
Pentax K-3
ispress OP Forum Member • Posts: 96
Re: Yes, yes, and yes
Thanks much. Very helpful.
GeoffNS Contributing Member • Posts: 593
Scotts answered all your questions and I agree fully. Re filters, I'd just add that if you already have 49mm filters for other Pentax cameras you might consider getting a 40.5 to 49mm step up ring and you can use your existing filters rather then having to buy new ones for your Q. Cheers, Geoff.
John Sheehy Forum Pro • Posts: 17,773
I bought my 3rd and 4th batteries from an Amazon side store for something like $7 for the two, including shipping.
If you don't use the "Power Saver" function (far too aggressive, IMO), you will need at least 3 batteries for a day's shooting. When I had just 2 batteries, and used the Q with a Canon EOS telephoto with an adapter, with "Power Saver" off, both batteries were dead halfway through the day.
John
Zvonimir Tosic
Zvonimir Tosic Senior Member • Posts: 2,545
Q10 --> better battery life
According to Shigeru Wakashiro, Pentax system camera development manager (as noted in an interview with PentaxForums during Photokina) Pentax Q10 has improved battery life.
Zvonimir Tosic
"I want to be the tripod, the light meter, the motor drive."
— Eve Arnold
 Zvonimir Tosic's gear list:Zvonimir Tosic's gear list
Fujifilm FinePix X100
waxwaine
waxwaine Contributing Member • Posts: 981
Re: Some possibly dumb Q questions
The questions were fine answered, and I want to add that you have to look for batteries that replace the next models:
KLIC 7004 (Kodak), P-50 (Fuji) and of course D-LI68 (Pentax). It 's the same battery. All of them must be at least 1000mhA.
