Extreme details - jpeg out of A99
Started Sep 25, 2012 | Discussions
alpha604 Regular Member • Posts: 243
sorry he beat me to it :)
Ahh sorry I didn't see the reply already... sorry for the double post!
 alpha604's gear list:alpha604's gear list
Sony RX1R II Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II Sony Alpha 7S II +45 more
Amateur Sony Shooter OP Veteran Member • Posts: 5,417
Re: sorry he beat me to it :)
No problem, and thanks for the invite Courtney!
BTW any idea why A900 can't do 1/160 shutter speed?
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 70-200mm F2.8 G Sigma 10-20mm F4-5.6 EX DC HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +5 more
thubleau7 Contributing Member • Posts: 516
Re: Extreme details - jpeg out of A99
A little shopping goes a long way.
Beautiful, I mean both your result and the girl!
brian14478
brian14478 Senior Member • Posts: 3,703
both show excellent detail-very natural looking also...thanks for the test,beautiful girl and smile...brian
It was a rush 30 second job I can still see some faults in the work but I will remove the photo at the end of the day to avoid any copyright issues etc.
I just did this one to give a rough idea of how to lift the photo a bit
cheers
Endos Senior Member • Posts: 1,237
I don't know what's the problem but I get sharper images than yours with the same lens even wide open and at lower shutter speed (1/125).
Amateur Sony Shooter wrote:
Perhaps I have shaky hands holding 1/200 speed? At the same speed A99 has less vibration due to fixed mirror.
Endos wrote:
My A900 in RAW is a lot of sharper that the samples you are showing here with your A900.
Juan
http://500px.com/endosphoto
http://www.endosphoto.com
check your firmware...
Hey Webb... I finally took a look and my a900 does do 1/160th... no change with or without a flashgun... not that that should matter but I was curious if the attached flash would change anything. I am not sure why it is missing from your camera.
What firmware are you running on your a900? I am actually still on 1.0 on mine! where as the current firmware is 2.0 for both the a900 and a850... I will have to investigate further before i upgrade the firmware...
keep me posted and I will let you know if I find out anything.
sonyphotobug Senior Member • Posts: 1,120
Great "Non-Scientific" test, both show great detail - A99 wins
Love the A99 in JPG mode, can't wait to see what it will do in RAW.
Thanks for posting, it is helping in my view of the A99.
Beauty of the picture is in the eye of the beholder
aardvark7
aardvark7 Veteran Member • Posts: 3,110
On or off shoe?
The on shoe flash will only do 1/160th in straight on HSS mode, but won't in bounce.
For studio set up it depends upon the strobes and triggers (usually 1/200 or 1/250th with sync cord)
2012 : My new year's resolution -
To be decided...
he is experiencing a weird quirk...
there is no 1/160th shutter speed in his A900... i know it sounds weird... but it jumps right from 1/125 > 1/200. I checked it side by side with my a850 and was shocked...
I am hoping we can get to the bottom of this.
Re: On or off shoe?
Well I tried both flas-on and off (no flash attached), there is simply no 1/160 option at all. I am thinking of reset camera but worried of losing all the micro AF adjustment value. It's not that I have to have 1/160 all the time but now I worry what else speed I missed.
I found the reason...
My exposure step was set at 0.5EV, once I changed to 0.3EV I gor all the smaller steps back. problem solved. Phew!
Re: I found the reason...
so simple! It is often the easiest answer that gets overlooked... I always have mine set to 1/3 steps and didn't even think of that.
Glad you got it sorted!
