Hands-On and Images of the Fujifilm X-E1 & 35mm f/1.4R lens
Started Sep 25, 2012 | Discussions
drxcm Regular Member • Posts: 111
MF behaviour
Can you comment on the functionality and handling when using manual focus on this camera?
ispress Forum Member • Posts: 96
Re: Hands-On and Images of the Fujifilm X-E1 & 35mm f/1.4R lens
RAW not supported?
The X-E1 supports RAW.
 ispress's gear list:ispress's gear list
Fujifilm X-E1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
webgeek OP Regular Member • Posts: 323
Hi Elliot;
I shoot with the bigger Sony A77 as well as NEX-7 and really think the EVF is nice and quick. I successfully shoot many panning shots with great results even with fill-in flash while panning.
When I read the spec of the X-E1 EVF with OLED 2.3 megapixels I was happy because I really don't like the Hybrid Viewfinder implementation on the X-100. I am totally happy with just EVF only. However, after shooting with this camera, I always noticed the EVF lags and it happens in all situation, not just dark places. I notice it even in good day light shooting. So I think the processing power for the EVF refresh rate is still not quite good enough on Fujifilm X-E1.
This aspect really make for a not-so pleasing shooting experience. If this EVF is the same as the Sony NEX-7 and A77 then I have no hesitation to buy this camera at all.
ELLIOT P STERN wrote:
Thanks for the great images. I too have concerns about the lag time. That is now and was before my only concern. I can make one note however. I just got back from doing a workshop in Cape Cod Ma which my company ran and I did some comparison shooting with my Olympus OMD bodies and the Fuji X pro 1 (prior to upgrade to 2.0 on Fuji.
I was surprised to suddenly find that the Olympus also had a shutter lag. The imaging from both cameras was superb. I have not shot with the Nex 7 so I cannot make a lag time comparison but for most of what I shoot from street to Landscape, the lag has not been a major problem. 95 percent of the time it does not cause me to lose a shot.
This seems to be an inherent problem with LCD finders, not only with Fuji but others as well.
El
Gear. 2 Omd, all the lenses, Ep3, Ep2, Ep1 infrared, Fuji X100, Fuji x pro 1, all the Fuji lenses, Voigtlander 15,21,28,50,75,90,180. Nikon 55 macro, 200 macro and Zeiss 100mm macro, Induro Tripods and heads, etc. Ricoh GXR and modules including Leica M
ulrikem Regular Member • Posts: 221
ispress wrote:
RAW not supported?
The RAWs out of the box are unlikely to be supported by any raw converter right now - I think that's what he meant. (Because they are tagged as being shot by the X-E1, which none of the converters supports right now).
Of course you could hex-edit the RAWs and replace every occurrence of "X-E1" by "X-Pro1" to make the raw converter happy. (There should be no difference between pictures shot by these 2 cameras otherwise)
 ulrikem's gear list:ulrikem's gear list
Fujifilm X100S Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +1 more
Re: MF behaviour
Hi;
I did not try manual focusing with the camera so I have no direct experiences.
Sorry to misinform. What I meant was Lightroom and PS Camera Raw currently does not have RAW support for this camera yet. The camera itself does take RAW. My main post-processing is Lightroom 4.
ulrikem wrote:
ispress wrote:
RAW not supported?
moimoi
moimoi Veteran Member • Posts: 3,660
webgeek wrote:
Just wanted to share some images I took using the new Fujifilm X-E1 and my first impression. I am in the market for a 2nd camera to compliment my Sony NEX-7 and this is one camera I am thinking of buying. I have used all X-Series Camera and sold them all simply because I cannot live with the slow AF. To me AF is the most important decision. So I am eager to see how this camera perform with the new improved AF that Fujifilm claim. I really like the images that comes out of this camera. I have only shoot JPEG since RAW is not supported. Great ISO up to 3200.
Goods:
  • Awesome Dynamic Range
  • Awesome ISO up to 3200
  • Love the Fujifilm color styles implementation
  • Love the AF button to allow me quick focus point selection
  • I like the Menu, better than my Sony NEX-7
  • Love the Macro feature to allow me to get closer and shoot
  • Good battery life, Fujifilm improve in this respect
  • Love the click and shutter sounds, very nice and elegant
  • Great Fujinon lens, very sharp and contrast same as my Carl Zeiss 24mm
  • Made In Japan quality and the body is extremely nice all metals
Looks like a very appealing system.
Bads:
  • EVF lags even at focus and bad when panning
  • AF is still slow, not as snappy as my Sony NEX-7. I missed a lot of shoot
I am surprised you found the AF performance too slow for your taste. From what I have seen thus far, the AF performance has improved dramatically from the X-Pro1.
  • Write to card is slower than most other camera I have tried
Which SD card did you use? Did you use the fastest card available?
  • Don't like how they implement the lens cap on the lens, I drop it and almost lose it twice. Also with the lens cap on the lens is bigger than it needs to be. I would like the caps to put on reverse when not in use.
  • Cannot rotate the LCD, I use this a lot on my SOny NEX-7
Not that it matters much I think. I think it could be easily fixed with a firmware.
  • No Focus Peaking feature
That's indeed a heck of a feature to have in hands while shooting manual focus. Too bad
  • NO Wifi and apps feature
That would have been a nice addition...oh well
  • EV compensation only up to +-2EV
  • Not enough lens to select at the moment
That may change in 2013, check the Fuji road-map. On the other hand, the NEX lens lineup is very poor.
  • Quality of LCD is not as good as others, only 2.8" and 490,000 pixels
Will make mostly no difference by doubling the pixels, and probably consumes less battery power.
  • Cost $1600 with the new 18-55mm f/2.8-4.0 coming out with it
Nope, 1399 USD with the zoom lens. The big question is how the kit zoom lens will perform. If not sharp, I will pass on this.
Personally, the only major drawback is the RAF files, which are not well supported by Adobe yet. Hopefully, they will be able to find a solution to the demosaicity issue with the X-trans sensor.
 moimoi's gear list:moimoi's gear list
Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Canon EF 35mm f/2 IS USM Canon EF 16-35mm f/4L IS USM Canon EF 35mm F1.4L II USM
awelch100
awelch100 Regular Member • Posts: 386
This is also likely to be the reason for the perceived lag when writing to a card. The amount of time needed to process the sensor output into a raw file or jpeg is probably the reason for the delay, not the actual writing of the data itself.
 awelch100's gear list:awelch100's gear list
Fujifilm X100S Sony Cyber-shot DSC-RX10 II Fujifilm X-E1 Fujifilm X-T1 Nikon D750 +5 more
hellocrowley Senior Member • Posts: 1,271
Re: Here are the images ....
Vietnamese here. Great shots, awesome colors. Is this a temple in Saigon?
Hello;
Yes this is a temple in Saigon. It is called Ngoc Hoang Temple. Very famous with lots of tourist visitors. My favorite temple to test ambient lights and dark mood with high ISO.
I agreed. The total experience of EVF lags and writing to cards is somehow noticeable in the process of taking pictures, whereas it is seamless in my other cameras. I hope Fujifilm can fix these issue for a better shooting experience. Otherwise, I will be again not buying the camera after 4 tries (X-100,X-10, X-Pro1 and now X-E1).
It's a shame because I really like the sensors and images.
TThorne
TThorne Senior Member • Posts: 3,013
LOL, that isn't what he meant. The camera shoots RAW but the RAW support is not universally there yet.
Lakeview Man wrote:
RAW not supported?
Happy I bought the X-pro1 then.
Very nice pictures!
A lie gets halfway around the world before the truth has a chance to get its pants on. - Sir Winston Churchill
 TThorne's gear list:TThorne's gear list
Leica M Monochrom (Typ 246) Leica M Typ 240 Leica SL (Typ 601) Leica Summilux-M 35mm f/1.4 ASPH Leica Summicron-M 35mm f/2 ASPH +11 more
